Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-12-2012, 12:50 AM
bobyunker bobyunker is offline
1959 Ford F-100
bobyunker is starting off with a positive reputation.
Would you consider this as a good swap option for my 59 F100?
Found this ad....
THIS IS A COMPLETE 82 FORD 1 TON VAN WITH A GOOD FORD 351 WINDSOR V8 AND C6 AUTOMATIC TRANSMISSION.... I BOUGHT THE VAN AND DROVE IT HOME TO USE THE 351W AND C6 IN MY RESTORED 56 FORD F100.... THE VAN IS COMPLETE WITH GOOD TIRES AND BODY WHICH COULD BE SOLD.... THE MOTOR AND TRANSMISSION WERE EXCELLENT WHEN I DROVE IT HOME. I PLANNED ON MAKING THE SWAP WITHOUT REBUILDING EITHER AS I FELT THE MOTOR WAS FINE AS IS BASED ON MY INSPECTION AND WHEN I DROVE IT AND BOUGHT IT.... SELLERS INFORMATION WAS THAT THIS COMBINATION HAD BEEN INSTALLED IN THE VAN IN THE RECENT PAST BY HIS FATHER.... I HAVE REMOVED THE GRILL, FRONT BUMPER, RADIATOR, ETC FOR ACCESS TO THE ENGINE BUT ALL PARTS ARE IN THE CARGO PORTION OF THE VAN....I HAVE DECIDED THAT I MAY JUST REBUILD THE 312V8 Y BLOCK AND KEEP THE 56 F-100 STOCK AS ORIGINAL. THE ROLLING CHASSIS COULD ALSO BE SOLD, IF FOR NOTHING MORE THAN SCRAP AFTER REMOVING THE ENGINE....
VAN COULD BE PUT BACK TOGETHER AND DRIVEN AS EVERY PART IS THERE....I MAY JUST DO THAT WHEN IT WARMS UP. ...ORIGINALLY I WAS THIS IS A COMPLETE 82 FORD 1 TON VAN WITH A GOOD FORD 351 WINDSOR V8 AND C6 AUTOMATIC TRANSMISSION.... I BOUGHT THE VAN AND DROVE IT HOME TO USE THE 351W AND C6 IN MY RESTORED 56 FORD F100.... THE VAN IS COMPLETE WITH GOOD TIRES AND BODY WHICH COULD BE SOLD.... THE MOTOR AND TRANSMISSION WERE EXCELLENT WHEN I DROVE IT HOME. I PLANNED ON MAKING THE SWAP WITHOUT REBUILDING EITHER AS I FELT THE MOTOR WAS FINE AS IS BASED ON MY INSPECTION AND WHEN I DROVE IT AND BOUGHT IT.... SELLERS INFORMATION WAS THAT THIS COMBINATION HAD BEEN INSTALLED IN THE VAN IN THE RECENT PAST BY HIS FATHER.... I HAVE REMOVED THE GRILL, FRONT BUMPER, RADIATOR, ETC FOR ACCESS TO 1982 THE ENGINE BUT ALL PARTS ARE IN THE CARGO PORTION OF THE VAN....I HAVE DECIDED THAT I MAY JUST REBUILD THE 312V8 Y BLOCK AND KEEP THE 56 F-100 STOCK AS ORIGINAL. THE ROLLING CHASSIS COULD ALSO BE SOLD, IF FOR NOTHING MORE THAN SCRAP AFTER REMOVING THE ENGINE....
ONLY INTERESTED IN THE MOTOR AND TRANSMISSION BUT IT IS AN EXTENDED FORD E 350 VAN AND COULD BE USED AS A WORK VAN. IF IT SELLS I WILL JUST REBUILD THE 312 V8 IN THE 56 AND KEEP IT STOCK. IF IT DOESN'T I MAY GO AHEAD WITH THE MOTOR SWAP. I HAVE SEVERAL CLASSIC CARS SO THERE IS NO HURRY EITHER WAY AND CLASSIC CARS ALWAYS TEND TO BE ONGOING.
Last edited by bobyunker; 02-12-2012 at 12:52 AM. Reason: Forgot to mention something
  #2 (permalink)
Old 02-12-2012, 05:09 PM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
Garage is empty, add now
GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.
The 351W and C6 would give you good power but gas mileage isn't going to be great. Expect about 10-12 MPG. I'd also be leary of an engine I had not personally heard run unless you plan to rebuild it...
__________________
Vern
1949 F-1
  #3 (permalink)
Old 02-12-2012, 06:30 PM
1959 Ford F-100
Quote:
Re: MPG would it be any worse than a 390?
  #4 (permalink)
Old 02-12-2012, 07:52 PM
Quote:
Probably not...
__________________
Vern
1949 F-1
  #5 (permalink)
Old 02-12-2012, 08:41 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Hey Boby, are you already running an auto?
  #6 (permalink)
Old 02-12-2012, 11:11 PM
1959 Ford F-100
Quote:
No, in fact my 3 speed with OD tranny is going out. My engine & granny is from 78 Granada straight six.
  #7 (permalink)
Old 02-13-2012, 08:07 PM
spurredon's Avatar
I have a carburated 351W/C6 in my '86. 10-12 mpg is just about right. I don't have a 390 now but have a 352/C6 in my '66, and it is about the same. I can make the mpg's worse if I enjoy take-offs on a continual basis.
GreatNorthWoods is right on with his mpg estimate. I don't drive very far so mpg's don't get me too excited. I will attest to the reliability of the C6 though. Do you know how long it has been sitting idle. Definately a fluid and filter change to start with.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
