Removing Doors - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Removing Doors
Old 02-11-2012, 06:40 PM
eatfish's Avatar
eatfish eatfish is offline
eatfish is starting off with a positive reputation.
Removing Doors
I have a 2000 Excursion and I just got side swiped by another truck. I want to remove both driver side doors (front and rear). Is there a plug that can be unplugged on the wire harness to remove the doors, or do I have to unplug each component in the door (ie locks, windows, speakers...) and leave the wires hanging from the wagon?
Old 02-12-2012, 12:39 PM
dennis350 dennis350 is offline
dennis350 is starting off with a positive reputation.
Book says to unplug each connection behind the door panel and label them
Old 02-12-2012, 12:42 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
The whole harness in the door has to be disconnected and pulled out of the door. In 2008 they added a disconnect plug on the door jamb that makes it a lot easier.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
