Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-11-2012, 04:59 PM
Pilgrim Pilgrim is offline
Garage is empty, add now
Pilgrim is starting off with a positive reputation.
power window problem
2008 Expedition
Drivers window quit. Cable broke. Got new regulator assembly and disassembled the door today and replaced the regulator. Now it doesn't work at all. Other 3 windows work.
Removed the "black box" from the motor (the one that's just on the driver's motor. Jumper cables directly to inner terminals on motor and the motor turns. So, my problem is either in wiring or the "black box" which is part of the motor assembly. I have no clue how to trace the wiring in this setup. Am I safe to assume there's something burnt inside the box and replace it? Or is there something else to diagnose the problem?
Any help is greatly appreciated.
Pilgrim
  #2 (permalink)
Old 02-12-2012, 05:46 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Did you replace motor and regulator or just the regulator? Did the motor work before replacement?
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 02-12-2012, 05:58 AM
The motor was working when the regulator/cable broke. The window slipped down so I pushed it up and taped it there until I had time to fix it. The switch may have inadvertently been pushed a few times since.? I'm thinking either the switch or motor went in the meantime and I'm sort of betting it's the motor.? It's been taped for a month or more. The other three work fine.
Pilgrim
  #4 (permalink)
Old 02-12-2012, 02:17 PM
critterf1's Avatar
Tap on the motor with a screw-driver handle and see if it runs.
__________________
  #5 (permalink)
Old 02-12-2012, 02:33 PM
Quote:
The motor does run if I by-pass the black box. The box is part of the motor assembly, though.
Pilgrim
  #6 (permalink)
Old 02-12-2012, 03:33 PM
critterf1's Avatar
Are the pins/connector in the pigtail making proper connection? And you are getting power to the motor? May be time to replace it.
__________________
Tags
08, 2007, 2008, 2009, escape, expedition, foprd, ford, navigator, power, problem, problems, recall, truck, window, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
