Antifreeze
Mike I use this
What's New!
What's New!
Mike thanks for starting this thread, will be very helpful when I do my oil cooler and coolant flush.
Glenn
It's available either way, premixed or concentrated.
Fleet Charge 50/50 Specifications Sheet
Fleet Charge Specifications Sheet
---http://www.fleetchargeantifreeze.com/--
Pasted it like that incase the auto link does not work
seems like the auto links are working now
Same as Rodneys post. I could not get the links to work a while ago.
Thanks for asking but you will not believe it. It was leaking out of the metal cover plate where you access the bolt for the HPOP!! It was running down the front cover behind the alternator bracket to the top edge of the oil pan. Then it ran to the back of the engine and I thought my rear main seal was leaking, LOL
Where have you been and did you ever find that miss?
Yes Mike we have
The miss is still there, cant seem to find it. Rick thought that there is some sort of ground or somethin on the inj 1,2,7 from the codes so I went and looked.
Cant find em. I think it maybe in the solinoids yet. How ever it comes and oges now. One day it will run like a top.
So no helicoils needed for yours hu?
I been working my tail off. So its hard to drop in here.
Or Glenn were you talking about this Miss?
Miss Texas 2011
Miss Texas 2011
#28
