Need a little advice
Im starting to work on an old truck my dad gave me. It's a '91 F-250 with the 7.3. The first issue I have to address, is the weird "woosh woosh woosh" sound out of the tail pipe, which Im told is a burnt exhaust valve. I have a spare engine, so that shouldn't be an issue. But I am open to advice on this as well.
Also, I want to list it. What is the easiest way to lift one of these trucks with the split D44 front axle ? I'm wanting to run 37x12.50's on it.
Next, when my dad stopped messing with it, it was in the middle of an auto to manual swap. I just want to find another Auto trans for it, and sell this 5 speed I have. The 5 speed came out of a '91 F-SuperDuty. If Im missing any small parts to put it back together, where is the best place to find these ?
Thanks in advance for any help you can give !
Light duty 250s had the d44 front with 8lug wheels. Not sure if the diesel had that option though. Do you have a free flowing exhaust. My 93 non turbo 7.3 with 4" straight exhaust and tweaked pump/timing sounded badass from the exhaust (way different then a gasjob).
The ttb frontend isn't too bad to lift. And really you don't even need to lift it. I've put 40s on my 87 truck a number of times with no lift. I'd say get a cheap 3" body lift and call it good. Roll or cut the front fenders to fit.
It has the 10.25, with 3.55 gears.
Since I got two trucks out of this deal (will add pics tomorrow). Im thinking of selling off parts from one to fix the other. Im sure the ZF 5 speed and Dana 80 has to have some value to someone. I just need to find a good working E4OD.
By the way, is there any power to be had by cranking the injector pump wide open ?
