Overhead console removal? - Ford Truck Enthusiasts Forums
Old 02-10-2012, 03:37 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
Does anyone happen to know the trick to removing the overhead console? I went out and pried on it a bit looking for screws or clips but had to stop because I could feel that 'WTF' thing coming on and that usually results in broken parts.
Old 02-10-2012, 03:48 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
It just pulls down. I know it's scary, but it really is just clips holding it in place. Helps to wiggle side to side as you pull. Wiggle the console that is
Old 02-10-2012, 05:07 PM
Quote:
LOL! I'll just pull on it with a little more enthusiasm and if that doesn't work, I'll get the wife to lend a hand.
Thanks for the tip.
Old 02-10-2012, 05:22 PM
Teds's Avatar
Teds Teds is offline
Teds is starting off with a positive reputation.
mine broke when i took it off....be careful pulls straight down
Old 02-10-2012, 05:32 PM
Quote:
Dang, that's what I'm afraid of. Were you able to repair it or was it trashed?
Old 02-10-2012, 06:04 PM
Teds's Avatar
broke 3 tabs off bought new one....
Old 02-10-2012, 06:31 PM
pmoney1983's Avatar
pmoney1983 pmoney1983 is offline
pmoney1983 is starting off with a positive reputation.
What is the reason you dont want it anymore?
Old 02-10-2012, 07:09 PM
Quote:
My compass reads about 270degrees off so I'm trying to get into it so I can fix the compass chip and do a write-up so everybody else can see how it's fixed.
Old 01-09-2013, 09:45 PM
walker williams walker williams is offline
walker williams is starting off with a positive reputation.
upper console
Quote:
Once you have removed the upper console, can you replace the LED's that show compass, gas mileage etc?
Old 01-09-2013, 10:46 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
There is another thread about this very topic that was started today (console removal).
It is a common problem for the circuts to come loose (soldered connections come loose internally over time).
The other thread had a nice write-up with links to pictures.
As well, there was a link to a company that you can send the unit to and they will repair and test it for you for around $35.00 (seems well worth it to me).
Good luck,
Old 01-09-2013, 11:42 PM
Z-MAN's Avatar
Z-MAN Z-MAN is offline
Z-MAN is starting off with a positive reputation.
http://m.ford-trucks.com/forums/showthread.php?t=441601. $16.00 at radioshack for a low watt soldering pen and a steady hand is all it takes. read post with red links and your good. by the way was my first attempt at soldering anything, just make sure to not cross any circuits with. the solder.
Old 01-10-2013, 08:57 AM
Whitey Ford's Avatar
Whitey Ford Whitey Ford is offline
FTE-Spread The Knowledge
Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.
David can repair your Overhead Console for $22.00 with lifetime warranty.
http://item.mobileweb.ebay.com/viewi...id=19289165983
David Ruberg 507-429-4489
Never have to worry about it again OR spend anymore $$. Just a thought!
Old 01-10-2013, 10:06 AM
Sark Sark is offline
Sark is starting off with a positive reputation.
Thumbs up
Here's another site. I used them for my console repair & they had a quick turnaround.
FORD F-series Overhead console kits and Parts
Old 01-10-2013, 10:08 AM
Got Diesel?
Quote:
Ford F150 F250 F350 Super Duty Temperature Compass Overhead Console Disp Repair | eBay
Now this is what I call service at a reasonable price... think I will try taking off my overhead console.
Excursion Overhead Console Removal dvrjump Excursion - King of SUVs 6 07-30-2013 09:33 PM
How big of a hole in the headliner will there be if I remove my overhead console? 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 2 02-26-2013 09:53 AM
Overhead display console not working Kdr358 Excursion - King of SUVs 4 04-04-2012 05:56 PM
04 Expy XLT - overhead console removal? Morris08 1997-2006 Expedition & Navigator 16 07-22-2008 08:24 PM
overhead console buckcreek 1987 - 1996 F150 & Larger F-Series Trucks 3 02-24-2005 09:16 AM
Tags
1999, 2004, 2006, ceiling, console, disassembly, f250, f350, ford, head, navigator, overhead, removal, remove, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
