PCM pinout - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
PCM pinout
Old 02-10-2012, 03:13 PM
sprint406 sprint406 is offline
sprint406 is starting off with a positive reputation.
PCM pinout
Can someone help? I need the PCM pinout for a 2000 7.3 powerstroke, if possable the wire schematic would be nice also.
Thank you
Old 02-10-2012, 03:23 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Thank you
Try this recent thread. The files should be attached there.
http://www.ford-trucks.com/forums/11...27-pinout.html
Old 02-10-2012, 03:33 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Here is the PCM pin-out.
Use THIS LINK to go to my last post in your other thread for an Engine Control Schematic I attached there.
Edit : No more back and forth. Here is the Engine Controls Schematic
42 Pin Connector. GPR control leads pass through it on there way to the PCM. See my post in your other thread.
Old 02-11-2012, 03:01 PM
Sorry about making you dizzy really not my intention. The wire schematic and pinout are wonderful thank you. So today I have checked the glow plug controler output or pin 101 on the pcm pinout. The wire checked out ok both by ohms and by no negative or positive power. But when computer is hooked up and the wire hooked up to GPR I run a start cycle on the motor so it activates the glow plugs then the wire will have 6 to 7 volts showing. Is this normal (not acording to my research)?
PCM Connector Pinout 1972RedNeck 6.0L Power Stroke Diesel 1 03-12-2016 01:29 PM
2005 5.4 F150 XLT PCM Wiring Pinout/Diagram Needed nfazer 2004 - 2008 F150 0 12-20-2014 07:35 PM
2007 6.0 PCM Pinout 07Stroke 6.0L Power Stroke Diesel 5 09-25-2014 09:37 PM
pcm pinout on e99 F350 psd needed MONAVIERONJON 1999 - 2003 7.3L Power Stroke Diesel 3 06-10-2013 08:17 PM
pcm pinout diagram needed quackrz 6.0L Power Stroke Diesel 4 05-21-2012 09:52 AM
Tags
1999, 2000, 2003, 73, 73l, diagram, expedition, f250, ford, pcm, pin, pinout, pins, powerstroke, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
