33's on my 91 Bronco
Are you planning to re-gear axles when you do this? If not, be prepared to lose mileage and "umph".
OEM backspacing a between 4.5" and 4.67" and it is a little deep for 33's. 4" to 4.25" is better. I ran 33's on 92 & 93's (front clip styling change) and actually had good luck with 3.5 to 3.75" backspacing without fender rub. 91 should be fine with that as well as I believe there is a bit more room in the front with the earlier style front clip.
the General brand tires I am looking at call for 8.5" to 11" rims. I will be doing more street driving than wheeling.
coal country bronco
1978 - 1996 Big Bronco
12-17-2002 11:33 PM
