75 f250 supercab 12v cummins finally outta the garage - Ford Truck Enthusiasts Forums
Old 02-10-2012, 11:00 AM
pruitt's Avatar
pruitt pruitt is offline
pruitt is starting off with a positive reputation.
so a quick little run down of what i got
75 supercab body
78 frame
79 dana 60 front with 6 in lift superduty springs, limited slip, 4.10 , crossover steering, custom shackles
95 sterling 10.25 rear 4.10 detroit true-trac, 04 chevy springs and front hanger, shackle reversal
12v cummins p-pump, 4k springs, afc mods, 16.5* timing, he351cw charger, bhaf, 4in pipe, nv4500 trans, np241 t-case
33 gal bronco tank 1/2 draw straw
hydroboost brakes
so frome the intercooler to the t-case this truck has a 94-98 dodge trans plant . except for the electric fans
Old 02-10-2012, 11:05 AM
pruitt's Avatar
i will get some pics up of the finished engine compartment.
Old 02-10-2012, 12:04 PM
Jon351m Jon351m is offline
Jon351m is starting off with a positive reputation.
That is beautiful. I wish I could afford a diesel.
Old 02-10-2012, 12:17 PM
msperlazza msperlazza is offline
msperlazza is starting off with a positive reputation.
Great looking truck, Hope to complete one of my own some day.
Old 02-10-2012, 08:50 PM
1978-BBB's Avatar
1978-BBB 1978-BBB is offline
1978-BBB is starting off with a positive reputation.
looks great im very jealous
Old 02-10-2012, 10:19 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Nice! Mad props to ya!
Josh
Old 02-10-2012, 11:06 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Would you mind telling us how much $$ you have in it?
Old 02-11-2012, 05:43 AM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
USArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant future
Looks good man.
About your steering how close does it come at full bump?
Old 02-11-2012, 02:09 PM
pruitt's Avatar
Quote:
Well. I sat down the other day and done a few calculations and come up with 13 k . But I rebuilt every piece other than the body and interior. That's next after I replenish the bank a little. This price is including buying a truck for the body and the bluebird school that I used the motor out of.
Old 02-11-2012, 02:12 PM
pruitt's Avatar
Quote:
Originally Posted by USArmyTaterness View Post
Looks good man.
At full lock the bolts that stop the nuckle against the axle housing has 1/4 in gap. I need to weld me a nut to them so it will touch
Old 02-11-2012, 03:34 PM
Could be worse I suppose did it come with crossover or did you fab it in yourself
Old 02-11-2012, 04:47 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Awesome!
Old 02-11-2012, 07:29 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Quote:
Took the words right out of my mouth!
Old 02-11-2012, 09:15 PM
pruitt's Avatar
I fabbed it up... I started this thing with a blasted frame setting on two 55 gallon barrels and a quart of por15......
Old 02-12-2012, 01:26 AM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
Did you build the Frame Perches and the custom cross member or did you buy em? If you bought em where from?? and you said you used the dodge trans?? how did it line up with the original trans cross member??
New Tough Country Bumper and Nfab Steps 11350KINGRANCH 6.7L Power Stroke Diesel 17 04-02-2014 11:37 AM
HOLY SCORE, BATMAN!! vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 49 03-16-2014 05:42 PM
'49 ford f-1 build 2345.coupe Projects 34 12-25-2013 05:19 PM
Cleaned her up good! dixie_boysles 2004 - 2008 F150 5 10-25-2012 02:42 PM
Ford Trucks at the Houston Rodeo. 11350KINGRANCH 6.7L Power Stroke Diesel 17 03-27-2011 10:04 AM
Tags
12v, 1980, 75, 94, conversion, cummins, diesel, electric, f250, fans, ford, sale, supercab, truck, w
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
