fuel injector rebuilding/cleaning/flow checking - Ford Truck Enthusiasts Forums
Old 02-09-2012, 10:46 PM
jborushko's Avatar
jborushko jborushko is offline
jborushko is starting off with a positive reputation.
im just going to leave this right here
this is a tread in process
i did this as part of my engine rebuild. i swapped to the newer ev6 injectors because i had a set laying around and one of my older ev1 wasnt passing the resistance test.
i am in the process of building a bench cleaner and flow/test stand.
since step one of cleaning a injector is to replace the filters ill just post up a quick how to now, and when i finish the cleaner/test stand ill add that to this thread.
BTW THIS SHOULD BE THE SAME FOR ANY EV6 BOSCH INJECTOR
"rebuilding" is easy all you really do is change out the filter and the o-rings. you can order up a kit online. this is pretty standard on how to do but to cover my butt... this is a bosch ev6 injector from a 4.6 merc, same injector in the 5.0s and some 5.8s it is 18.25lbs/hr
step one: check resistance aross the coil in this case 11-18ohms. just run your mulitmeter to each of the injectors electrical prongs. all of my EV6's checked 14ohms...
step two: remove the old o-rings and cap
step three: wipe off all the dirt you can find
step four: remove the old filter
step five: install new filter, o-rings and cap
step six: finish beer and start a second... or third... or fourth cus your DONE
the next step would be to flow clean but that'll wait till im done building circut cards -more on that later
Old 02-11-2012, 03:11 AM
xxshine xxshine is offline
xxshine is starting off with a positive reputation.
But is it worth all that doing when new ones are affordable enough. Yea it's something cool to tinker with though.
Old 02-11-2012, 04:50 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Thanks for sharing the illustration. I'm sure it will help some guys out.
I've heard of people soaking them in Berryman's or similar cleaner. I wonder if thats a good idea or not.
Old 02-15-2012, 12:21 AM
jborushko's Avatar
affordable yes... but the kit (for 8) is $25 bucks... and i dont see the need for replacing with NEW for more money when these check good. and like i said this is the begining of a bigger tech thread for cleaning/flow checking injectors to this can be done with about any kind of EV6 bosch injector like the 30lb injectors that are stock in some turbo volvos that ARNT as cheap. I had these "new" EV6's in the garage from a previous tear down.. but out of pull apart they are $3ea? or the pocket discount price of $free.99
i am hessitant about soaking anything that has a electrical connector in any fluid expecially a solvant
Old 02-15-2012, 12:45 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Ryan has some great injector cleaning tips here: Fuel Injection Technical Library Fuel Injector Cleaning
Manual Injector Cleaning - The How To Thread nstueve 1987 - 1996 F150 & Larger F-Series Trucks 56 08-26-2015 04:06 PM
EV1 vs EV6 Injectors RZAR Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 08-11-2015 10:36 PM
92 bronco 5.0l - New fuel system but won't start 75_92_95 1978 - 1996 Big Bronco 13 07-22-2015 09:47 AM
EV1 Injector Revamp and Install Evan_P 1987 - 1996 F150 & Larger F-Series Trucks 2 06-07-2013 09:10 PM
I think I neutered my truck...:( Shake-N-Bake 1999 - 2003 7.3L Power Stroke Diesel 19 02-13-2010 11:22 PM
Tags
50, 92, clean, cleaning, enthusiasts, f150, ford, fuel, injector, injectors, rebuild, resistance, run, testing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
