where to mount a cb radio? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-09-2012, 10:31 PM
tpolley tpolley is offline
tpolley is starting off with a positive reputation.
i just picked up a 98 expedition eddie bauer.
i'm looking to mount a cb radio. its a larger radio, uniden grant lt.
i've also got an 102in stainless whip i'm thinking about mounting to the rear bumper.
so where would be a good place to mount this thing? i'm toying with the idea of pulling the cd changer out of the center console and mounting it there.
pictures would be appreciated.
Old 02-10-2012, 03:29 AM
etewald etewald is offline
etewald is starting off with a positive reputation.
I take it it won't fit in the console with the changer in there?
Old 02-10-2012, 08:09 AM
It probably would fit with the changer. I'm planning to yank the changer anyway in favor of one of those auxiliary adapters for an mp3 player. I dont have much use for cd players.
Old 02-10-2012, 07:29 PM
totalrecall totalrecall is offline
totalrecall is starting off with a positive reputation.
Even though CB's are generally low wattage, consider that if you do have it encosed anywhere some amount of heat will build up - does it matter I don't know, just that any radio will have some heat.
So have you considered simply mounting it up next to the side of the console, slightly ahead of the drivers seat. If that doesn't work for you, how about some way to remove the push in and out cupholder - if that model has them and maybe it would squeeze in the dash with some room around it?
Mike
Old 02-10-2012, 09:48 PM
Boat Tug Boat Tug is offline
Boat Tug is gaining momentum as a positive member of FTE.
Two years ago I needed one and ended up buying a handheld Midland 75-822 unit and put an extension w/magnetic antenna on the roof.
The battery comes off when using the 12v power connector.
That leaves a small handheld speaker/mike connected to the power cord (plugged into the rear facing 12v outlet at the back of the center console).
When I need it it just sits in the console tray, if not I disconnect and stow it.
Installing a CB Radio in 2004 (Heritage) F150 XLT BigNish2 1997 - 2003 F150 9 06-19-2015 06:09 AM
Radio FM VHF install jle70 1987 - 1996 F150 & Larger F-Series Trucks 7 08-24-2008 08:30 PM
CB's Jspafford 1999 to 2016 Super Duty 34 03-31-2007 09:10 PM
CB Radio! taxabel General NON-Automotive Conversation 66 10-10-2004 01:59 AM
Any suggestions for mounting a CB Radio antenna? rikosintie Excursion - King of SUVs 11 07-30-2004 08:58 AM
Tags
06, 2004, boss, cb, diesel, f150, mount, mounting, pickups, places, powered, radio, radios, ram, satellite, truck, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
