Hello, I have a 1984 F-150 XLT with some minor problems, this one is rather annoying. my truck wont start with the column mounted ignition switch, so the PO rigged up a push button from the solenoid. all the other functions of the ign switch work, just not the "start" position. I replaced the ign switch and the solenoid and still no go...could some one please help, this is rather aggrivating....
The red/blue wire connects to #5 on the solenoid, this is what activates it (the solenoid).
If auto trans, there is a NSS (Neutral Safety Switch) in between the solenoid & ignition switch; clutch switch for manual trans I think was added at some point but don't remember when (but it was after 1981 as I don't have one).
My ignition switch might be all out of whack. It is rough to turn the lock cylinder. I try to move the steering wheel back and forth to relieve the bind, but , it doesnt help. I must have messed something up whenever I installed the column.
actually i dusted off my old haynes and it said there is, you losen the bolts and stick a drill bit in the holes and make shure they line up. or so i read...
