Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #16 (permalink)
Old 02-09-2012, 09:43 PM
ctubutis's Avatar
ctubutis ctubutis is online now
Garage is empty, add now
ctubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant futurectubutis has a brilliant future
ctubutis ctubutis ctubutis
There very well may be some sort of official adjustment/alignment procedure available, I really don't know as I haven't owned an automatic transmission since around 1990.
What we tend to have here in this forum - with ~30 yo trucks - is ripped-out wiring, hacked wiring, crossed wiring, stuff like that.
All I'm saying is, IMHO there's a much larger chance some PO has messed with your wiring for some reason and that's the cause of your problems, I don't think I've ever seen talk here about adjusting the NSS to make things work.
Now, watch, out from the woodwork will come all these people talking about adjusting the damn thing, prolly including Franklin......
__________________
About the bra
  #17 (permalink)
Old 02-10-2012, 04:32 AM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a great reputation on FTE.81-F-150-Explorer has a great reputation on FTE.81-F-150-Explorer has a great reputation on FTE.81-F-150-Explorer has a great reputation on FTE.81-F-150-Explorer has a great reputation on FTE.81-F-150-Explorer has a great reputation on FTE.
From the woodwork, hence I commeth...
There is a adjustment proceedure for the NSS.
The Linkage must be correctly adjusted first, before the NSS adjustment. It sounds like the hanes manual has the proceedure for adjusting a used one. The new ones come with a pin usually, simular to a new Ignition switch.
Just a word of advice, if the NSS is covered in Oil, or tranny fluid, I'd think highly of replacing the thing.
Also make sure the wiring isn't tampered with. The PO, might have rerouted the wires and bypassed the NSS.
But you are right Chris, adjustment usually isn't an issue, except when you can only start your truck if you lift up on the gear lever type symptoms.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
