Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Sign in using an external account
Register Forgot Password?
Modular V10 (6.8l) SPONSORED BY:
  #16 (permalink)
Old 02-14-2012, 06:46 PM
britt britt is offline
Garage is empty, add now
britt is starting off with a positive reputation.
DKF...thats what I'm trying to figure out...not loaded unless you count a toolbox full of tools and a generator, not driving like a madman (most of the time ) high mileage...just passed 250,000...but truck has never pulled like youd think a v-10 would. at least from what i pick up on here.
By the way wher'ed you get your avatar? wife was giving me flak while I was typing....
  #17 (permalink)
Old 02-14-2012, 08:30 PM
Front Runner's Avatar
Front Runner Front Runner is offline
2002 Ford Excursion
Front Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputation
Quote:
Originally Posted by shorebird View Post
Winter blend gas with ethanol Will kill MPG.
You're absolutely correct. I normally get about 350-375 to a tank with my work tahoe but when I run E85 ethanol I get 225-250 at best.
__________________
2002 Excursion Limited, 4x4, V10, 4.88 gears, 6" PC lift , 20" XD Hoss wheels, 35" Pro Comp tires
1999 VW Beetle GLS 1.9L Turbo Diesel (170K 46mpg city 50+ hwy)
1997 C5 Corvette
  #18 (permalink)
Old 02-15-2012, 09:28 PM
russ3or8 russ3or8 is offline
russ3or8 is starting off with a positive reputation.
well i filled up with 92 octane non-ethanol and it seems to be worse like 40 miles on a 1/4 tank worse so idk...has to be something else cuz the owner of the fuel company where i got the fuel said she uses that in here 'burban and gets alot better mpg and performance...by the way britt what is a mode 6 scan cuz i am wondering if i might have a fuel pressure prob or vacuum leak or if its spark related as in the coil pak boots.
  #19 (permalink)
Old 02-15-2012, 10:11 PM
Russ, These trucks are set up with a obd 2 connector under the dash, however "Big Brother" decided that they only had to be obd 1 compliant because they were considered a Heavy duty truck...meaning these trucks hardly throw a code...for example in the 10 years ive had mine ithas only thrown one cel light for a O2 sensor. My buddy teaches auto shop at the high school and he used his snap on scanner to force the computer on the truck into Mode 6 which if I understand correctly is a forced self diagnostic loop. he checked whole she-bang and found nothing out of normal. when I switch back and forth from ethanol to non, it takes a couple of tanks for everything to settle down. I know its rough..I fill up every three days...90 bucks a pop. If you have access to a scanner that data logs you can hook it up while your driving and it will check fuel trim and pressure and save it for review. some of the higher end ones at advance auto do this ...Mine is an actron cp 9180. its ok but no where near the diagnostic capabilities of the professional units.
I swapped out my fuel pressure regulator when my mileage started to nosedive a couple of years back, cant think it made a whole lot of difference ....i m right there with ya,I cry every time I pull up to the pump...keep plugging and if i figure something out, I'll let you know...you do the same.
  #20 (permalink)
Old 02-15-2012, 10:24 PM
Russ , almost forgot...when We pulled the scan on my truck the other day we found a p 1876 which is something to do with the transfer case, It was a intermittent or pending code meaning that the computer in the truck has to read that fault a whole bunch of times before the cel will illuminate.
I'm sure some one here has WAY more knowledge on this than me, maybe they'll chime in...
  #21 (permalink)
Old 02-16-2012, 02:11 PM
britt do u get better mileage with non than w/ethanol and i can get the non reg grade and the non prem grade except for the obvious price difference is the premium better or will the reg do the trick too...i still only got 40 miles to 1/4 tank with the premium non-ethanol so far but is first tank trying this solution no pulling and no heavy accel
  #22 (permalink)
Old 02-16-2012, 03:27 PM
Russ, yes i get better mpg with non ethanol versus ethanol. I try to fill up with a good gasoline...chevron etc.sams and wally world is generally a low quality gasoline...
I'm sure some here will protest but thats just my 2 cents worth...mid grade is my general choice...let me know...I dont get why some of these trucks are un affected by ethanol and others are...
  #23 (permalink)
Old 02-24-2012, 06:38 PM
Russ...any update on mileage/fuel?
  #24 (permalink)
Old 02-24-2012, 07:41 PM
V10ZILLA's Avatar
V10ZILLA V10ZILLA is offline
V10ZILLA is starting off with a positive reputation.
I to am thinking a stuck or dragging brake caliper
__________________
2009 F250, XLT, 4X4, V10, CC, LB, 4.10's
Member-Southern California Chapter-FTE
  #25 (permalink)
Old 02-24-2012, 08:01 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Quote:
Drove my van to work for the first time in 3 years today.
It has been sitting with out being driven more than around the block.
Both front calipers stuck and are going to be replaced Sunday.
$90.00 for the calipers and $50.00 for ceramic pads
77,053 miles on it.
It's my fault for letting it sit.
But as I have had the tow truck 24/7 for the last 3 years I just plainly neglected it.
Even having to replace the fuel pump a few months back and now the calipers and pads I'm still ahead as I've not had to buy gas for it.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #26 (permalink)
Old 03-09-2012, 08:14 PM
hey britt i tried the non-ethanol 92 octane for a tank and got about 220...this tank is regular with ethanol but with a bottle of Sta-Bil fuel treatment to get rid of ethanol and so far have got 150 on about 3/4 tank so...hell idk...the onlother difference is i am buying my fuel thru a local wholesaler who also does our business fueling so i know the fuel is good...gonna check out some other stuff this weekend will update thanx again
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
