Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics
Sign in using an external account
Register Forgot Password?
Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics SPONSORED BY:
  #1 (permalink)
Old 02-09-2012, 05:36 PM
KR-SD KR-SD is offline
Garage is empty, add now
KR-SD is starting off with a positive reputation.
Question 2006 F250 no 16pin conector
I am looking to upgrade my radio to an oem nav unit from an 07+ superduty because i would like to have an aux port. I have searched this forums on guys installing their AUX adapters and noticed something different.
I have a 2006 F250 King Ranch, with factory 6cd changer, i took out the radio and noticed that i only have a 24pin connector on my harness connected to the radio and NO 16pin connector from the truck but there IS a spot for the 16pin connector on the radio. Even looked all under the dash for the 16pin harness and found nothing. My steering wheel controls work fine. All the pictures i've seen of other superdutys have both the 24 and 16 pin connectors from the harness and the radio plugged in.
What exactly does the 16pin connector do? I bought this truck from the dealer and now wondering if that radio was the true original one or not. Any help would be great. Thanks.
  #2 (permalink)
Old 02-10-2012, 06:21 AM
glruff's Avatar
glruff glruff is online now
2005 Ford Ranger
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
This was posted by discountcarstero.com, maybe this provides what you need.
http://www.discountcarstereo.com/pdf/frd04-aux.pdf
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4/05 Ranger 4.0 FX4/10 Expedition EL LTD/12 Explorer LTD EB
  #3 (permalink)
Old 04-04-2012, 11:23 AM
DMarafino DMarafino is offline
DMarafino is starting off with a positive reputation.
The 16-pin connector is for Can-Bus data transmission. It's not uncommon for F150s and F250s from those years to not come with a 16 Pin plug. You can still add a NAV with an aux port, but you will need to make sure the NAV is both capable and programmed to accept 12v+ turn on. Newer Ford radios do not have accessory power supplied to them, but rather use a Can-bus data signal to turn on the radio.
Tags
16, 16pin, 2004, 2006, conectores, connection, connector, discountcarstereocom, f150, f250, ford, pin, pins, radio, ratings, sc4100, stereo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
