Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 02-09-2012, 09:19 AM
fastblkford fastblkford is offline
2005 Ford Expedition
My Garage
fastblkford is starting off with a positive reputation.
Exclamation Cam Phasers!!!!!
I have an 05 Expedition that is needing cam phasers and I can't seem to find them anywhere but at a Ford dealer. If anyone can help me locate them for cheaper than $248/each I would greatly appreciate it. I also need the wedge specialty tool as well. I know there are some guys on here that said they got them for under $200 so your input and info would be nice!!! Thanks in advance!!
Jeremy
  #2 (permalink)
Old 02-10-2012, 08:43 PM
galaxie641 galaxie641 is offline
Garage is empty, add now
galaxie641 is gaining momentum as a positive member of FTE.galaxie641 is gaining momentum as a positive member of FTE.
Try Rockauto.com for starters. I'll assume you tried Napa
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'92 Grand Marquis
'97 F150 5.4L
'08 Bullitt #3947
  #3 (permalink)
Old 02-10-2012, 08:48 PM
My Garage
Napa and o'reilly doesnt carry the phasers or the wedge i called and asked with specific part numbers.
  #4 (permalink)
Old 02-22-2012, 07:18 PM
cobrajoe's Avatar
cobrajoe cobrajoe is offline
cobrajoe is starting off with a positive reputation.
cobrajoe cobrajoe cobrajoe
$248 is high, we usually pay around $175. Try searching some of the Ford dealers online. A lot of people I know use Gaudin Ford in Las vegas. I would also do the lifters and rockers while you are in there.
  #5 (permalink)
Old 02-23-2012, 06:26 AM
JWA JWA is offline
2000 Ford E-Series Van
JWA has a very good reputation on FTE.JWA has a very good reputation on FTE.JWA has a very good reputation on FTE.JWA has a very good reputation on FTE.
Quote:
We have a few sponsors here in FTE who are online Ford OEM dealers too. Horizon Ford (Seattle area, www.partsguyed.com ) and Tousley Ford (Tousley Ford Parts Depot) Both seem to have better pricing than the average consumer enjoys through their local Ford dealers. I've used Ed's outfit a few times although he's no longer working for them.
HTH
  #6 (permalink)
Old 02-23-2012, 08:31 AM
My Garage
Well i think i talked the dealer into buying the phasers for me. He said to bring it in and he would have it fixed in two weeks. Well two weeks is too long without my vehicle so i told him to get the parts and i would do it myself. I have already thought about doing the lash adjusters and rockers while in the engine. Guessing i can get those from the places yall suggested as well?? What about the wedge?? I will need that as well. Anyone out there that can loan it to me for a week or so?? Thank yall for the input and advice!
Jeremy
  #7 (permalink)
Old 02-23-2012, 09:51 AM
cobrajoe's Avatar
I would definetly do the lifters and rockers while your in there. Your dealer should have those in stock. The wedge should be available from your local tool supplier Mac, Cornwell or SnapOn.
  #8 (permalink)
Old 02-23-2012, 10:20 AM
My Garage
Thanks man, are there any other specialty tools i may need to complete this job? And about how long will this process take? I am wanting to set aside a weekend to do this hoping that will be enough time.
  #9 (permalink)
Old 02-23-2012, 10:48 AM
cobrajoe's Avatar
You should be able to do it in a weekend no problem. I've done a half dozen or so of these and it ususually takes around 5-7 hours. The worse part of the job is getting everything apart so you can get the valve covers off.
The only specialty tool you need is the wedge. You will, however, probably have to drain and recharge your AC. Just be sure to wedge the tool in firmly to hold the chain and make sure to mark the chain on one of the two timings marks and reinstall the same way when you do the phasers.
If you search this forum, you should be able to find several topics discussing this proceduresuch as this one with pics:
http://www.ford-trucks.com/forums/79...placement.html
Good Luck and we're here if you have a problem.
  #10 (permalink)
Old 02-23-2012, 11:34 AM
My Garage
Thanks for all your help!!
Tags
03, 2006, 54, 97, cam, camshaft, expedition, f150, navigator, phaser, phasers, problems, recall, tool, triton, tsb, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
