1979 F350 Dually with dump bed - Ford Truck Enthusiasts Forums
Old 02-09-2012, 10:02 AM
Yegger Yegger is offline
Yegger is starting off with a positive reputation.
I need the wiring diagram that tells you what wires hook into the externanal voltage regulator, and what goes to the alternator, wiring is all messed up...... when the alternator is hooked up, voltage surges blow the voltage regulator, and then fry the ignition module. Please help...
Anybody know of any fixes, also have the idea of swapping a wiring harness from a 1977, same engine, diff trans, into it. Have all the complete componets there, thanks alot if anybody can help me.
Old 02-09-2012, 03:02 PM
OldStyle's Avatar
OldStyle OldStyle is offline
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
I have seen better examples but here is a simple diagram.
Alternator Hookup Question midniteblue 1978 - 1996 Big Bronco 5 08-31-2015 04:32 PM
G1 alternator mattparham1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 39 09-26-2013 01:27 PM
1978 f150 alternator/regulator wiring ktz78 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-21-2010 12:10 AM
PLEASE HELP!! Voltage Regulator Burned Up carprojects 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-13-2010 12:44 PM
'86 F250 diesel alternator wiring BigJake86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-09-2009 11:39 PM
Tags
1979, 1980, 79, bed, conversion, dually, dulie, dump, easy, f350, ford, harness, pickup, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
