Installing overhead mgp console in 99 xl - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-08-2012, 09:17 PM
krane operator's Avatar
krane operator krane operator is offline
krane operator is starting off with a positive reputation.
In the process of adding an overhead console with mpg to my super duty. I need to connect a wire for the "injector cycle duty", where can i find this? I pulled the pcm where it was supposed to be either pin 9 or pin 43 and there is nothing there. Thanks
__________________
Old 02-09-2012, 06:31 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The 99 F250 does not have a wire that specifically carries an "injector duty cycle" signal to the PCM. You'd have to tap off one of the injector firing signal wires to get that.
PCM pin 9 is for the fuel gauge sender, pin 43 is the Data Output Link for the OHC, if equipped.
Old 02-09-2012, 06:53 AM
Thanks sho for the response, u are very correct about that information, infact my truck being an xl it has no pin 9 nor 43. can u tell me which wire at the injector to tap ? thanks again sho.
Old 02-29-2012, 05:24 PM
Update for mpg 2 door console install
Well the 2002 -2004 2 door console with mpg install is done in my 1999 f250 superduty 5.4 xl. This is not as complicated and expensive is it may sound. There is a guy by bird who sells these and it CAN get expensive , even 100 dollars for the wiring book for the mpg to work. I just went to wrekn yard and got a console with computer for 40 bucks and was able to cut off the harness conector that plugs into the console and made the rest of the harness . You can find all over the net how to cut the liner and wire the temp sender, but to wire the mpg computer into an xl, there is not a whole lot of info. There are 3 things required for mpg to work, speed sensor,fuel tank level sender, fuel flow. All these are at the pcm PINS, and not always in the harness. So i just unpluged pcm harness and drilled slot and added these wires into the plug harness and it is working. Here are the pin numbers for the 1999 5.4 superduty
At pcm on drivers side near fender well
pin 9 yellow/white wire = fuel tank sender
pin 58 gray/black wire = speed sensor(this is only wire that was in pcm harness)
pin43 orange/light green = data output link fuel flow
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 01-12-2014, 10:03 AM
TNScrambler's Avatar
TNScrambler TNScrambler is offline
TNScrambler is gaining momentum as a positive member of FTE.
Sorry to bring up an old thread.... We are installing a console in a early 99 xl 7.3, we have pins 9,43, and 58 but we are unsure on the power source...the diagram we have says to pull from "iso bus 70" but we can't find that on any ecm pinouts.
Thanks!
Justin
2001 F150 Lariet asterof Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 04-30-2016 02:29 PM
overhead console tcjhkbjt 6.0L Power Stroke Diesel 3 01-09-2014 07:08 AM
overhead console wiring and pin connector info njneer1 Excursion - King of SUVs 2 11-22-2011 01:00 PM
Console Air Temp Sensor Location twobuchs 1999 to 2016 Super Duty 3 06-07-2009 02:19 PM
overhead console buckcreek 1987 - 1996 F150 & Larger F-Series Trucks 3 02-24-2005 08:16 AM
Tags
1999, 54, 99, connection, console, cycle, duty, f250, ford, injector, manual, online, overhead, owners, pcm, pin, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
