Rear end options with a crown Vic ifs? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-30-2014, 07:45 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
Quote:
Originally Posted by flowney View Post
So what rear axle set-up is most compatible with an 03-07 CV IFS in an F-100 dent side? Factors to consider might include:
  • matching the dual calipers and huge rotors on the front
  • matching bolt pattern (16" wheels required, right?)
  • using a compatible distribution block, master cylinder and booster
  • keeping wheels inside fender line avoiding any rubbing
  • readily available (reasonable cost)
The disk brake conversion systems for the stock 9" I've seen so far don't score well on cost and matching what comes with the CV IFS.
I can't help you but others on here may , if not you might try posting this in the dent side forum . I spend a lot of time there and a few of them are using the CV IFS under their dent sides.
Old 07-30-2014, 12:40 PM
Johns53f100's Avatar
Johns53f100 Johns53f100 is offline
Johns53f100 is starting off with a positive reputation.
I used a 1980 f150 rearend.
Old 07-30-2014, 06:00 PM
flowney's Avatar
flowney flowney is offline
flowney is starting off with a positive reputation.
@Johns53f100, how does the 1980 reared compare with the CV IFS with respect to:
  • width
  • diameter of rotor
  • number of caliper pistons
Old 07-30-2014, 07:29 PM
If I remember right it is 65.25 inches, that's close enough for me. I bought it cheap and it's limited slip so I'm going to use it. These 80 model trucks had drum brakes not disc but that's fine with me.
You can look at me gallery and see it installed and it does have 9 inch wheels on back.
Old 08-05-2014, 12:31 PM
BrockGrimes's Avatar
BrockGrimes BrockGrimes is offline
BrockGrimes is starting off with a positive reputation.
80-83 ford f100 had a 9" with 5x4.5 bolt pattern.
You'll have to adjust the spring perches, possibly shock mounts too.
Old 08-05-2014, 12:54 PM
flowney's Avatar
Thanks. I'd need to convert drums to disk as well. What I was hoping for is a 9" unit that had the 5x4.5 bolt pattern AND disc brakes. I guess that I'm just too greedy/cheap.
Crown Vic IFS rhino3 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-30-2015 01:49 PM
crown vic IFS swap question northerndave 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-11-2015 08:31 PM
Lincoln Town Car Rear End Under My '74 F100??? mikeh74 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-09-2015 12:44 PM
Crown Vic Rear? gfw1985 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-09-2014 08:45 AM
crown vic rear axle question tymatt67 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-10-2014 01:24 PM
Tags
2001, 88, 96, axle, crown, eand, f100, ifs, inches, rear, rearend, swap, vic, victoria, wide, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
