Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Towing, Trailers & 5th Wheels SPONSORED BY:
  #16 (permalink)
Old 02-12-2012, 09:33 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
Garage is empty, add now
RV_Tech has a very good reputation on FTE.RV_Tech has a very good reputation on FTE.RV_Tech has a very good reputation on FTE.RV_Tech has a very good reputation on FTE.
The best source for informaton regarding the contents of the Ford Owner's Manual is the owner's manual itself. These trucks' capabilities are the subject of ongoing debate on FTE.
As to what is legal, private users are unlikely to run into legal problems regarding weight.
My two cents worth,
Steve
__________________
RVDA/RVIA Master Certified RV Technician
You think you're confused?
2002 F350 Dually, Rhino Liner, Edge Evolution (running in stock mode), 4" exhaust, 6.0 cooler
2010 F150 super cab, box stock, bed slide, ARE bed cover
  #17 (permalink)
Old 02-12-2012, 10:45 PM
RickBraden RickBraden is offline
RickBraden is starting off with a positive reputation.
I will get weights of axles as soon as I install the air bag springs & hook up trailer.
  #18 (permalink)
Old 02-17-2012, 06:39 PM
Bigpipes 35. Correct. If by chance I will overload my Grosse Rear Axle Rating or 8800 of GVWR by towing it to a Cat scale, I ordered a Sherline trailer tongue scale. This way I can take just my truck to Cat scale & weigh both axles.
Then I'll use trailer tongue scale on the 5er pin. Then hopefully by adding Rear Axle weight to pin weight my GVWR & my Rear axle wont be over limit. I sure hope so.
__________________
'04 F250, 50 gallon fuel tank, Pre-luber, by-pass oil filtration, 4" exhaust with down-pipe, Only Rotella 5w-40 full syn.
  #19 (permalink)
Old 03-17-2012, 09:26 PM
DrCharles DrCharles is offline
1984 Ford F-150
My Garage
DrCharles is starting off with a positive reputation.
Question How about GCWR for '65?
Any ideas what the GCWR for my '65 F-350 dually should be?
The only specs I have on it is the door plate which shows GVW 10,000, and the service manual says front axle rating 3,800 lb, rear axle 7,200 lb. The truck weighs almost exactly 7,000 with me in it. (Not sure how much of that is on each axle though).
I currently have it registered with a "Year of Manufacture" (1965) 18K truck plate. (In MO the plates are for the combined weight). So with that plate I'd need to stay under 18,000 anyway. This is personal, non-commercial use.
Thoughts?
thanks
Charles
  #20 (permalink)
Old 03-18-2012, 08:00 AM
spud57's Avatar
spud57 spud57 is offline
spud57 is starting off with a positive reputation.
Quote:
Originally Posted by RickBraden View Post
I found decal on door jam & it lists Front GAWR 5200 lbs, Rear GAWR 6084 lbs, & GVWR 8800 lbs. I need to know what the trucks Gross Combined Weight Rating is to verify a 5er that shows 11,300 lbs. Thanks for any help.
Here is the link to Ford's 2004 towing guide. Gives you both max trailer weight and GCWR depending on you rear end ratio, cab and engine.
https://www.fleet.ford.com/showroom/...r_F250_350.pdf
__________________
2008 F250 SC LB 4X4 V10
2006 Escape XLT 2WD
2010 Outback 321FRL
  #21 (permalink)
Old 03-18-2012, 10:46 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.BPofMD has a spectacular reputation.
I doubt that a 2004 guide is going to be accurate for a 1965 truck!
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC 2012 - VW Passat SE TDI
Join the Maryland Chapter click HERE
  #22 (permalink)
Old 03-18-2012, 05:09 PM
terryknight's Avatar
terryknight terryknight is online now
terryknight is starting off with a positive reputation.
My two cents worth,
Steve
smart man right there
  #23 (permalink)
Old 03-19-2012, 06:18 AM
spud57's Avatar
Quote:
I was responding to the OP who has a 2004 and was asking what his GCWR was.
__________________
2006 Escape XLT 2WD
2010 Outback 321FRL
  #24 (permalink)
Old 03-19-2012, 09:44 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
OOPS!!! Looks like too many hangers on to this thread....people have to start starting their own posts if they have a question.
__________________
BPofMD - Bud
  #25 (permalink)
Old 03-19-2012, 12:33 PM
MDSuperDuty's Avatar
MDSuperDuty MDSuperDuty is offline
MDSuperDuty is gaining momentum as a positive member of FTE.MDSuperDuty is gaining momentum as a positive member of FTE.
As a general statement (not directed at the OP) I just wouldn't want to be in the defendents chair because of a serious accident, whether caused by the driver or not, and have someone be able to say that you were overloaded based on Ford's reccomendations. Unlikely.....probably, but hard to argue numbers when they're in black and white and a lawyer is not going to use just DOT laws or stickers on trucks. Negligence is just that...negligence. Again unlikely scenario but even if you are the perfect driver and some bone head pulls out in front of you and you're overweight........
__________________
2008 F350 CC, DRW, SWB, V10, 4x4 LEER Cap.
2002 Taurus (THE WINTER BEATER!!!)
2006 F250 Ext Cab, LWB, 5.4V8, 4x4 (traded 07/11)
2005 F150 Ext Cab, SWB, 5.4V8, 4x4 (traded 01/08)
1996 F150 Ext Cab, SWB, 4.9 I6, 5spd, 4x2 (Sold) This truck started it all!
Tags
2004, 60, colorado, combined, diesel, duty, f250, f350, find, ford, gcrw, gcvr, gcvw, gcwr, gross, rating, super, table, vehicle, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
