loss of fuel at upper rpms?
Well this is my first time posting
Heres my problem I bought my ts 6pos tuner and exhaust and installed them both 2weeks ago. I thought everything was great then I noticed up top around 2500-3000 it feels like its not getting enough fuel. I turned it to my smoke setting and WOW it was fast no hesitations at all.
I did a buzz test and every injector came back fine. changed the fuel filter still no change. I replaced the lift pump back in Oct.I did a fuel pressure test and the needle was jumping from 40psi to 90psi at idle. I am so lost could it be a bad fpr? I know the previous owner did the fpr mod with the bb.
When I ran the scanner I got a code p0196 but I am going to double check to make sure my truck was at operating temp to be safe. Forgot to mention I got my chip from KT performance
Thanks for any help
Joe
<!-- / message --><!-- sig -->
Thanks for any help
Joe
Welcome to the site Joe. That is a heck of a jump, usually they may jump 20 or so psi, not 50. Maybe pull that spring and check it out along with the bb mod. Try it without the bb for curiosity.
Maybe you are running out of oil at higher rpms with the chip.
Give us some more info on your truck too.
Well I replaced the eot sensor hopping that would fix it but it didn't. I noticed it runs fine in the tunes when its and not at operating temps I wasnt a fan of doing that...but I had to try.
I talked to kt performance and they say that it's basic tunes but he told me to send it back and he'll Reburn them. I really don't know what else to do or check.
