spare tire lock? - Ford Truck Enthusiasts Forums
spare tire lock?
Old 02-08-2012, 11:08 AM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
Towmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to all
spare tire lock?
So I get a message from my BIL: "Where can I get a spare tire lock cover for the rear bumper of a Ford 06 F150?... Pretty sure it's part number 402A36."
It's the keyed lock where you slide the crank in through the bumper to lower the spare tire.
I drive an OBS '92 so I'm not sure on these. Gimme a direction here other than just a dealer which is the obvious first response.
Old 02-08-2012, 11:11 AM
gengine gengine is offline
gengine is gaining momentum as a positive member of FTE.
I don't know... Maybe try typing the part number into Ebay. I find a lot of stuff that way.
Old 02-08-2012, 11:26 AM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Might want to ask in that forum too they may be able to help. Could also try O'Reily's they seem to have more parts then most places do.
Old 02-08-2012, 05:41 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
The only problem is that it uses the ignition key to lock/unlock. He would need a second keys if it didn't match the ignition
Old 02-08-2012, 11:05 PM
Quote:
The glove box is a good spot for that second key. How often do you need your spare tire?
Old 02-09-2012, 12:44 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
For my F250, I was told to contact McGard since they provide the locks for Ford.
Not sure if that is correct for your truck though.
Stewart
Old 02-09-2012, 02:28 AM
Towmanjbo's Avatar
Okay thanks for the replies, I'll have to check into McGard
Old 02-09-2012, 02:34 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
With the VIN and a trip to the local dealer the correct lock can be had for about $45.00 may take a few days to get it.
Old 02-09-2012, 05:40 AM
danorules's Avatar
Quote:
Excellent point. I just envisioned more keys on the keyring, like a janitor
Old 02-09-2012, 07:59 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
The lock?, or just the lock COVER? LMC has lock covers for about $20-$25 I think.
Old 02-09-2012, 10:31 AM
Towmanjbo's Avatar
The lock I believe, they went skiing a few weeks ago and upon leaving they had a flat, AAA had to break the lock to get the spare down
Old 02-09-2012, 06:48 PM
theduke308 theduke308 is offline
theduke308 is starting off with a positive reputation.
those locks are bad business in emergencies
Old 02-10-2012, 12:00 PM
Great visualization!!!
Old 02-10-2012, 03:57 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
Quote:
Not if you clean them in the spring after snow is gone and add some grease to the back side behind bumper will keep water out and not rust also some lube in key side a few times a year works like a charm.
Old 02-11-2012, 09:26 PM
senders88's Avatar
senders88 senders88 is offline
senders88 is starting off with a positive reputation.
spare tire lock rear bumper 2004-08 f150
got mine from an auto parts yard called allwestparts 4415 76 Ave NW Edmonton, AB T6B 0A3
<table class="ts intrlu" width="100%"><tbody><tr><td valign="top"><nobr>(780) 465-4730</nobr></td></tr></tbody></table>. for $ 35.00 US. Included cover lock & key.
regards
The key for the spare tire lock inverted99 1999 to 2016 Super Duty 40 09-28-2012 08:18 AM
Can't lower spare tire. IslandBlueV10 1999 to 2016 Super Duty 14 07-25-2012 12:21 AM
super camper special spare tire cover? chad85 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-10-2011 10:43 PM
spare tire access brcman 2009 - 2014 F150 7 02-03-2011 08:38 PM
Spare Tire Lock Key? 90F250351 1999 to 2016 Super Duty 17 09-27-2009 09:44 PM
Tags
06, 150, 2008, 402a36, f150, f250, ford, frod, lock, locks, lower, parts, spare, tire, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
