In need of info - 460 intake for thermoquad - Ford Truck Enthusiasts Forums
Old 02-08-2012, 12:40 AM
8man 8man is offline
8man is starting off with a positive reputation.
Cannot find a picture, casting # info, or pretty much anything about it.
I have a project (not truck related) that I think this would be perfect for.
I am in need of one of these intakes as well.
Got one to sell? PM me, please.
Thanks
Old 02-08-2012, 01:26 AM
redmondjp's Avatar
redmondjp redmondjp is offline
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
You're talking about a Carter Thermoquad such as the 60s-70s Mopars used?
I know that my 1971 429 had a square-bore intake manifold on it, but it was cast iron.
What are you trying to accomplish?
Old 02-08-2012, 09:24 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Many of the Lincoln 460s used Rochester Quadrajet carbs, those manifolds would be spreadbore like you need. If you want a spreadbore carb, I would highly recommend the Q-jet over the Thermoquad. The phonelic (sp?) body of the T-quad warped and leaked a lot.
Old 02-08-2012, 09:35 AM
I have read that the thermoquad was a california item.
Thunderbirds and trucks, maybe some others.
I have the TQ carb. Ford #D4AE-BC
Now, I need the intake. I think it's D4VE-B1B. ??
I shoehorned a 429 into my 67 cougar, but I have to run a low profile
intake, for hood clearance. Currently using and AFB. (not an E-brock)
Runs great, but I want to try out that phenolic bowl.
Old 02-09-2012, 10:57 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
The 74 California 460s used a Carter Thermoquad which is a little different bolt pattern than a Quadrajet. The only 385 series engines I ever saw with a Q-jet were the 429CJ engines in the Torinos and Montegos. They were iron manifolds. I have one of the CA spec TQs, it showed up in my shop one day and the guy who had it wanted $25 for it, I still have it. Good luck on an intake.
Old 02-10-2012, 09:59 AM
jas88's Avatar
Wow, I did not know that. I have only seen TQs on big-block Chrysler products.
Old 04-21-2012, 11:15 PM
AerostarDad's Avatar
AerostarDad AerostarDad is offline
AerostarDad is starting off with a positive reputation.
Would a TQ fit on a '78 460 cast-iron stock manifold? They came with the Motorcraft spreadbore carb.
Old 04-22-2012, 08:03 AM
I think from what I remember that the 4300D, TQ and Qjet were all just a little bit different. I believe the 4300D and TQ bolt patterns were the same, but the bore spacing/ locations and size were different. Best bet would be to see if you can find mounting gaskets for the two and match them.
Old 10-24-2012, 11:02 AM
Michael G Michael G is offline
Michael G is starting off with a positive reputation.
Thermoquad bolt patterns
Thermoquads and Quadrajets share the same bolt pattern, but not the same base gasket, the Thermoquad is unique in its base gasket, and you will have a vacuum leak if you use a q-jet gasket on the tq. The tq is a great carb when working properly, producing good fuel mileage and torque without sacrificing top end power when you want it.
Old 01-16-2013, 01:30 AM
wm1224 wm1224 is offline
wm1224 is starting off with a positive reputation.
Thermoquad
Hey I was wondering if anyone has one of the 460 thermoquad carbs Ford (#D4AE-BC) forsale that is all there and rebuildable or rdy to be put on? Thanks
Old 01-16-2013, 09:35 AM
The one I have would need rebuilding as it has been sitting for a number of years. I can get some pictures of it if the weather ever improves.
Old 01-16-2013, 11:11 AM
Ok that would be great! Thanks so much!
Old 03-14-2013, 07:56 PM
oldeford oldeford is offline
oldeford is starting off with a positive reputation.
460 Thermoquad Carburetor
If you still have the thermoquad carburetor I would be very intersted in purchasing it. Thanks
Old 03-14-2013, 08:10 PM
I haven't been able to locate it. The one TQ I saw, turned out to be a MOPAR version. If I still have it, it is probably buried under something else.
Old 03-14-2013, 08:51 PM
Ford 460 Thermoquad
Thank you for responding to my post, if you locate the 1974 460 Thermoquad carburetor please let me know. Serious buyer, not wasting your time.
FE Motor Intake Question Martin Torres 1957 - 1960 F100 & Larger F-Series Trucks 4 09-23-2016 01:08 AM
351m/400 intake question? BigCountry1978 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-04-2016 10:37 PM
Turbo help 1989f250IDI General Diesel Discussion 11 08-14-2012 06:34 PM
Engine Info needed Fexx22 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-09-2011 10:28 PM
Need Intake Hat for ATS Turbo on 90 atvtrailrider Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 08-13-2011 01:02 PM
Tags
429, 460, 74, 86, aluminum, carb, carter, d4veb1b, d4vec1, f350, ford, intake, lincoln, thermoquad, tq
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
