Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #1 (permalink)
Old 02-07-2012, 08:42 PM
sixty9cougar's Avatar
sixty9cougar sixty9cougar is offline
Garage is empty, add now
sixty9cougar is starting off with a positive reputation.
Is my IPR bad????
My truck has had unusually long cranking time since I purchased it in 09. After sitting all night or all day when its cold it takes about 5-7 secs to turnover. I got a SG II recently and I have been monitoring the ICP and IPR values. Here's what I got.
Key in start position:
ICP = 0
IPR = 14.4
Cranking motor:
ICP = 65
IPR = 77
I run all OEM filters and caps. The batteries are strong and I test them every six months. The alternator was replaced 5 months ago, and the FICM was replaced two years ago. I'm quite sure that I have a HPO system problem, but I'm not sure were to start. Should I replace the IPR and see what that does? Or should I look some where else?
  #2 (permalink)
Old 02-07-2012, 09:14 PM
eagleinms eagleinms is offline
eagleinms is starting off with a positive reputation.
Ed Haas
69, not sure what you are reading with icp and ipr. You want to look at psi on the icp and duty cycle % on the ipr. I have an early 04 and have been going through this for the past 3 months. So far I have only found a bad pigtail on the ipr. I also had a battery drain that I hope I have found and fixed. Check the voltage on the ficm, check all wiring and connections around the ficm, icp, ipr. You should have at least 400 psi at the icp and 24-27% duty cycle on ipr during cranking. I have found there are many causes. How are your fuel filters? Do you have good pressure on fuel? Last oil change, what is the level. I know much of this is redundent but I have found to look at everything. Everyone will need more info to really give assistance.
God Bless and good luck
  #3 (permalink)
Old 02-07-2012, 09:26 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 is gaining momentum as a positive member of FTE.critterf1 is gaining momentum as a positive member of FTE.
My '03 won't crank with less than 500 on the ICP.
__________________
Speed is a question of money. How fast "CAN" you go?
  #4 (permalink)
Old 02-07-2012, 09:30 PM
eagleinms,
The values I gave are in PSI for the ICP & % for the IPR. The FICM voltage is always at 47.5 to 48. I have also checked every wire loom i can find for chaffing and loose connections and I didn't find any. The fuel filters where changed 5K miles ago, and I don't have a way to check fuel pressure.(I don't think that the SG can read fuel pressure?) I just changed the oil last week, so the oil level is good. I've had this problem ever since I bought the truck and it has been very frustrating.
Also, I scan for codes periodically and there are never any to retrieve.
  #5 (permalink)
Old 02-07-2012, 10:12 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
2003 Ford F-350
BLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to all
Quote:
ICP = 0
IPR = 14.4
Cranking motor:
ICP = 65
IPR = 77
It looks like you have a HPO leak
IPR% looks good for Key On Engine Off
Cranking IPR% looks good but ICP is way to low ICP needs a Minimum of 500 psi to run My truck Idels at 640 ICP when up to normal temp
Program the SGII for ICP Volts to
from the sound of it the HPO Bleeds off as it sits with the truck Off and It takes longer crank time to fill the HPO system back up
What Year is the truck???
__________________
Benny
2003 6.0, 4X4 srw, short box, born on 3/28/03 Moog ball joints,DC POWER 190A ALT
4 inch turbo back magnaflo exhaust,no kitty, 6 in. lift, BFG 315/75r16, python remote start alarm,pioneer system2 12''subs 1600watt amps ,scangaugeII,coolant filter, blue fuel pres spring, Fresh oil cooler 6/1/11 Final Charge Cat EC-1 rated Silicate Free ELC coolant, Sinister Full egr deleate, Mobil 1 5w-40syn,updatedHPO screen,updated oil filter stand pipe
  #6 (permalink)
Old 02-08-2012, 05:55 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman is a splendid one to beholdnpccpartsman is a splendid one to beholdnpccpartsman is a splendid one to beholdnpccpartsman is a splendid one to beholdnpccpartsman is a splendid one to beholdnpccpartsman is a splendid one to beholdnpccpartsman is a splendid one to beholdnpccpartsman is a splendid one to behold
ICP = 0
IPR = 14.4
Cranking motor:
ICP = 65
IPR = 77
I would pull the IPR and check it first. If the screen is good then you're probably "OK". If not then replace the valve and retest. You might also want to pull the ICP sensor wire and crank the truck to see if a biased sensor is causing your start problem.
__________________
Payin it Forward one post at a time
I look at it like this: The advice is free and you get what you pay for; use it or dont my truck still runs fine. From a very well respected friend....Thanks
  #7 (permalink)
Old 02-08-2012, 03:30 PM
cartmanea cartmanea is offline
cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.
Quote:
Cranking is the engine turning over. You can crank it no problem, but the injectors won't fire.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Icon springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac, Off Road Tech winch bumper
- ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost), Banks Technicooler, Garrett PowerMax VGT
Currently wrecked... again. Rebuild to come.
  #8 (permalink)
Old 02-08-2012, 06:34 PM
Blade35,
The truck is a 2006.
  #9 (permalink)
Old 02-08-2012, 06:49 PM
BLADE35's Avatar
2003 Ford F-350
Blade35,
You have the Good HPOpump so it shouldnt be that
That year is known for STC Fitting standpipe and or dummey plug issues have you changed any of these parts yet
So It runs just takes some extra Crank time right I beleive its got a HPO leak
When its up to Normal temp 190ECT whats your ICP & IPR% at Idel
__________________
Benny
  #10 (permalink)
Old 02-09-2012, 06:00 PM
Blade35,
When idling at normal operating temp 188 ECT, the ICP is 580 and the IPR is 22. Is their a kit that I can buy that has a new stand pipe and dummy plugs? Do you know of detailed repair procedure for this fix?
Thanks
  #11 (permalink)
Old 02-09-2012, 06:09 PM
With those numbers, you don't have a leak, or at least not anything significant. I have heard of a similar symptom caused by a minor air leak, which allows the HPOP to drain out over night when the truck is parked either nose down or nose up (I forget). Anyway, if it's always nose down slightly where you park it, try turning it around and see if it still does it.
__________________
  #12 (permalink)
Old 02-09-2012, 06:23 PM
It doesn't matter if its nose down, nose up, or sitting flat. It always does it. It will fire up quickly like it should if you start 30 minutes after you shut it down. But after about 2 1/2 hrs the crank time starts to get longer.
  #13 (permalink)
Old 02-09-2012, 06:49 PM
BLADE35's Avatar
2003 Ford F-350
Blade35,
Thanks
Those numbers are good no majoir leak BUT
So I take it that right when you first start cranking ICP is way Low and after a 5-7 second crank the ICP will shoot up and start sound about right
If so^^^^^^^^^^ sounds like a HPO seal or maybe even an Injector seal shrinks and bleeds off pressure this might be a Hard one to find
you might even have to air test when Cold IDK
__________________
Benny
  #14 (permalink)
Old 02-09-2012, 08:55 PM
jl4407's Avatar
jl4407 jl4407 is offline
jl4407 is starting off with a positive reputation.
Stupid question, what does icp and irp stand for
  #15 (permalink)
Old 02-09-2012, 09:00 PM
That's what I was afraid of. I'm not too comfortable messing with the injectors. If its an injector seal do I just change out the injector?
Tags
03, 60, 60l, bad, diesel, f250, ford, icp, injector, ipr, irp, pressure, regulator, symptoms, syptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
