Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #16 (permalink)
Old 02-09-2012, 09:09 PM
sixty9cougar's Avatar
sixty9cougar sixty9cougar is offline
Garage is empty, add now
sixty9cougar is starting off with a positive reputation.
ICP = Injection Control Pressure.
IPR =Injection Pressure Regulator
  #17 (permalink)
Old 02-09-2012, 09:34 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
2003 Ford F-350
BLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to allBLADE35 is a name known to all
Im thinking its a standpipe or dummey plug that when it cools down the seal shrinks and it begins to leak off HPO pressure it takes a longer crank to fill the HPO system back up and start
the HPO rails ontop the injectors need to come off to change those
Now its not very common to leak at the HPO rail to injector connection but
Theres an oring in the top of the injector that seals the HPO Rail to the injector its not very common for it to leak here to change those theres a little clip that needs to be pulled of the top of the Injector and then the oring fished out and a new one installed
I think if it were the STC fitting it would leak constantly and your Icp would be low number and IPR% would be High number so I dont think its the STC fitting
__________________
Benny
2003 6.0, 4X4 srw, short box, born on 3/28/03 Moog ball joints,DC POWER 190A ALT
4 inch turbo back magnaflo exhaust,no kitty, 6 in. lift, BFG 315/75r16, python remote start alarm,pioneer system2 12''subs 1600watt amps ,scangaugeII,coolant filter, blue fuel pres spring, Fresh oil cooler 6/1/11 Final Charge Cat EC-1 rated Silicate Free ELC coolant, Sinister Full egr deleate, Mobil 1 5w-40syn,updatedHPO screen,updated oil filter stand pipe
  #18 (permalink)
Old 02-12-2012, 12:46 AM
run6.0run's Avatar
run6.0run run6.0run is offline
run6.0run is gaining momentum as a positive member of FTE.
I think I read recently that there is a company that sells the injector o ring kit that includes the top o ring for the injector.
  #19 (permalink)
Old 02-12-2012, 02:48 AM
cartmanea cartmanea is offline
cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.
The Alliant Power kit has them, AP0002. I ordered them from Oregon Fuel Injection. It is a pain to replace the top injector though, you need a very good punch and some patience. I replaced all the o-rings in mine when I had them out.
Oregon Fuel Injection, diesel fuel injection pump, turbo, injector and diesel performance product specialist.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Icon springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac, Off Road Tech winch bumper
- ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost), Banks Technicooler, Garrett PowerMax VGT
Currently wrecked... again. Rebuild to come.
  #20 (permalink)
Old 02-12-2012, 07:11 AM
Thanks for all the info guys. Hopefully I'll have some time next weekend to do an air test and find out where the leak is.
Tags
03, 60, 60l, bad, diesel, f250, ford, icp, injector, ipr, irp, pressure, regulator, symptoms, syptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
