FAQ - truck cab interchange? - Ford Truck Enthusiasts Forums
'80-'86 FAQs (Frequently Asked Questions) Calculators, specififications, automotive terms and acronyms.
Old 03-19-2011, 06:15 PM
berlincam86 berlincam86 is offline
berlincam86 is starting off with a positive reputation.
I have a 83 ford f350 that the cab is rotted. what years will fit with little to no modification? Id like the newest cab possible.
Old 03-19-2011, 06:27 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
80-86 is a direct swap, no modifications
87-91 bolts on as do the doors, but you will need to modify the cab to accept your dash or modify the harness if you pan on using the newer dash.
92-97 bolts on as do the doors, but you will need to modify the cab to accept your dash or modify the harness if you pan on using the newer dash.
Old 03-19-2011, 06:31 PM
perfect thats exactly what i wanted to know. Thank you. the newer cabs will mount without mods but i will have to modify the wiring. thats it right?
Old 03-19-2011, 08:57 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
You will also have to drill a hole in the floor for the speedo cable as the 92+ cabs use digital odo's.
Old 03-19-2011, 08:59 PM
ok thats nothing. is there anything else i should know?
Old 03-19-2011, 09:00 PM
The seat belt retractor is by the floor in 1987+ cabs. In yours, it should be by your head.
Other than that, and different fire-wall cab connectors/holes nothing is different in the metal.
Old 03-19-2011, 09:04 PM
ok thanks for the info i want to stay in the 80-86 range but if i can get one newer for the right price i just want to know ill be able to use it.
Old 03-19-2011, 09:11 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
A big can of worms is the title and vin. Everyone has their theories and methods on how to overcome this, just make sure you make a plan that's going to work for you and the local DMV when you register it and then possibly try to sell it later.
Old 03-19-2011, 09:12 PM
Grind off the old plate off the old cab and stick on the new cab!
Old 03-19-2011, 09:36 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Better advice would be to consult the DMV (or whatever it's called in your location) and ask them about this kind of thing.
Some areas allow transfering the VIN plate, some areas require the title to be reissued with the VIN of the salvage cab, and some places will require titles for both cabs be presented at an inspection, where a new VIN will be created for the vehicle.
Going about this the wrong way, can land a person in jail, or having a vehicle siezed which is then crushed and/or parted out.
Doing a little research beforehand can save a lot of time/money/greif later.......
Old 03-20-2011, 04:43 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
If going for a cab in the 1980-1986 range... the best matches are...
1980-1983
1984-1986
The firewall holes for the wires and components will line up best with those.
As for the DMV issue, it varies from state to state. California goes by the frame vin for instance. Make sure what you can and cannot do in your state. Very wise idea.
Old 03-20-2011, 05:04 PM
where would the frame vin be? i was just planning on registering it under the new cabs title. ive never really known new york state to go by a frame vin.
Old 03-20-2011, 06:11 PM
It's under the cab, along the top of the passenger side frame rail, and also closer to the front between the coil spring pack, and radiator support area.
1981-1986 have a partial vin number stamped on the frame.
1980 has the full vin number.
Old 03-20-2011, 09:45 PM
Franklin2's Avatar
Quote:
Going by the replacement cab's vin is a good plan. Not many people know about the frame vin, just the one staring at them under the windshield. You would not be doing any grinding and swapping plates, so you can avoid that legality problem also. Your cab door jamb sticker will probably not match the way the truck is equipped, but I would not worry about that either. You will have to pay the registration to get the title swapped in your name(you are after all getting a new 86 truck correct?) and get the tags swapped, and you may have to pay a little bit more in taxes since the 86 is probably worth more than the earlier truck.
Old 03-23-2011, 09:47 AM
Ok so will i have to change the fenders and radiator support for the newer cabs? what year cabs can i use mine to?
cab steps gbkeith 2017 Super Duty 1 02-05-2017 01:12 PM
55 cab vs 56 cab kys911t 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-24-2017 08:41 PM
Cab to Frame Bolts BlueFord65 1961 - 1966 F-100 & Larger F-Series Trucks 1 06-28-2016 09:33 PM
Will a 94 ranger reg cab shell fit a 2000 ranger reg cab? jonwho Ranger & B-Series 3 11-02-2012 11:50 PM
reg cab on a crew cab frame Mark223 1999 to 2016 Super Duty 2 01-18-2010 11:46 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 2000, 86, 87, berlincam86, cab, cabs, enterchange, f150, f350, ford, frame, interchange, interchangeable, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
