FAQ - truck cab interchange?
#46
I wish I had a lift that's the way I would do it but I don't have one. So I'll figure it out. I just wanted to be sure the fenders could hold the weight of the font clip and the extra weight won't bent the roof when I lift it off. As for the speed sensor I'll figure something out. Thanks for the help.
#47
What ever you do, don't lift with anything rigid like chain or cable, it will bend the cab roof line. A lift strap is pretty much the only option. However, I have heard of using 4x4's to lift by, but seems a little risky to me, but there are ways to reduce possibility of slippage. Definitely have the doors off though, as they will likely be damaged if left in place.
#48
#49
Tow straps aren't rated for vertical lifting. If you could get an actual lift strap, you could possibly use the looped ends to go around the 4x4, then lift at the center.I have used regular lift straps but not the 4x4, but also have not tried putting the cab on anything... The clip was off as well. Seems most times, I tear them down, rather than go back together.
#52
Done, thanks for the suggestion.
Ford Truck Enthusiasts Forums - View Single Post - '80-'86 Tech Tips, Tricks and Projects:
#54
#56
Hey, thanks for all the info here - I have a further question: my truck is a '86 F250 with 6.9 diesel, and I've found a cab from a '89 F350 7.3 diesel. What's my best plan regarding the wiring harness? The '89 cab has been cut up fairly badly and I'm wondering if it's best to try and use my old dash and harness? thanks again !
#57
If going for a cab in the 1980-1986 range... the best matches are...
1980-1983
1984-1986
The firewall holes for the wires and components will line up best with those.
As for the DMV issue, it varies from state to state. California goes by the frame vin for instance. Make sure what you can and cannot do in your state. Very wise idea.
1980-1983
1984-1986
Does anyone know why the 1980-83 cab is not as good of a match to an 84 to 86?
I bought a 1985 that had a better cab included. The cab is from a 1980.
Thanks in advance for any info.
KO
#59
#60
Are the clutch pedals different.... um, yes, as I recall, you will need a pedal assembly specific to a hydraulic clutch but I can't remember the exact details as to why or how they're different... IIRC the actuator arm - the piece extending off the pedal assembly - is different between the mechanical vs hydraulic clutches and that piece can be changed individually... don't remember what other specific differences there might be, though. It's been talked about in the main 80-86 forum (you are in the FAQs sub-forum right now), might go searching through the archives in there.
berlincam86
74
03-17-2019 09:26 AM
Alec Blanchard
06-08-2016 05:54 PM
90F250351
02-05-2007 10:43 AM
1997, 2000, 86, 87, berlincam86, cab, cabs, enterchange, f150, f350, ford, frame, interchange, interchangeable, truck
