Loud beeping coming from under Dash.. - Ford Truck Enthusiasts Forums
Old 02-07-2012, 04:31 PM
JessieDM's Avatar
JessieDM JessieDM is offline
JessieDM is starting off with a positive reputation.
1994 F150XL, 4.9L, E40D
So... I think I may have caused a problem under the dash of my truck.
My truck has vinyl interior, and vinyl mat floor. Every time I've washed the truck, I've sprayed out the floor in the interior. Never had an issue doing this... until now. I know, I know... I'm an idiot.
Since I sprayed it out, I now have a beeping sound that's coming from under the drivers side of the dash. The truck will still start and drive fine, but whenever I shut the truck off, the beeping begins. I think I've found the source of the sound, but I can't be sure. It seems to be coming from a black box with blue connecting plugs.
The beep sounds like a slow alarm clock... beep..(1 second of silence)..beep..(1 second of silence)..beep.. and so on in this fashion. It beeps about 5 times, then stops for about 5 seconds, then beeps again in the same pattern. It does this about 3 times before it silences for a long time.
I suspect the beep is coming back periodically as the truck sits because I've heard it beeping in the middle of the night, plus my battery is no longer holding a charge, so I think it's running it down.
Any ideas as to what this is?
Thanks guys
Old 02-08-2012, 01:32 PM
Bronkenstein Bronkenstein is offline
Bronkenstein is starting off with a positive reputation.
It could be your airbag sensor. If i remember correctly if the bulb was pulled or blown for the airbag light in the dash it would beep instead of flash.
Old 02-08-2012, 01:51 PM
Roger T. Pipe's Avatar
Roger T. Pipe Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
Quote:
100% correct on the airbag light being blown. If its removed or blown out, it'll beep instead so as to alert the driver. I believe this will also happen if the CEL is blown too, but I'm not sure.
Roger
Old 02-08-2012, 05:15 PM
76250_4x4's Avatar
76250_4x4 76250_4x4 is offline
76250_4x4 is starting off with a positive reputation.
my truck does this if i turn my ignition between the run and on position (like in between the two when i shut it off) kinda wonderd what it was but i believed it was because of my worn out key switch. My airbag light works btw
Old 02-08-2012, 05:46 PM
JessieDM's Avatar
Hmmm..
My airbag light works. I know this because after my ECM went out, I replaced it with a new ECM and now all it does is blink constantly. It still blinks.
The only time I hear the beeping is when I shut the truck off.
I guess this is a moot point because I just sold the truck yesterday , but for the sake of diagnosis, I'll still post about it.
Old 07-21-2013, 05:07 PM
Wcheckman Wcheckman is offline
Wcheckman is starting off with a positive reputation.
Got same problem, mines a 94 f150
Recently a black box started beeping under driver side dash only when truck is off. My air bag light flash and is fine. Does anyone have anything else on how to stop it , can I disconnect the box or will it mess with air bags, driver bag hasn't worked in couple year, so not worried if they won't work.
Old 07-21-2013, 05:08 PM
Also it is 5.0 if that matters
Old 07-22-2013, 06:32 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Only when the key switch is off you say? The airbag module should only squawk at you with the key ON. Unless it failed or something.
Where exactly is this black box? The only box I know of that is capable of making noise deliberately is the airbag diagnostic monitor, but that's a BLUE box. At least it's blue on every older Ford that I've seen, before they started using the newer data recorder type.
Old 07-22-2013, 05:22 PM
Thanks but figured it out, I didn't know the air bag light gave off a code too. It says I have code 32 -Driver Side Air Bag Circuit High Resistance or Open. You wouldn't know how to fix that would ya? I don't get why it's just now started beeping, driver side air bag never worked lol, had it checked out over 4-5 years ago cause cruise cont and horns didn't work and we were told it was the airbag and it wouldn't go off if in a wreak,and we never got it fixed. my truck never been in a wreak luckily. Family owned since 94. Is there way to clear code?
Old 07-22-2013, 05:30 PM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
When you say beep, is it the same tone as the one you get when the truck starts? It sounds like it could be that. That's a black box. I disconnected mine since the beep is so annoying.
Old 07-22-2013, 05:45 PM
No , it's a black box with green front, bout twice as big a black box for door tones, which is behind black and green box. I fixed it tho, just unplugged the air bag module and no more beeping but airbag light stays on when key on but it all good
Old 03-26-2014, 03:10 PM
Davie J. Davie J. is offline
Davie J. is starting off with a positive reputation.
Speaking of "black boxes", I just removed the dash from my 1987 F250 and I don't know what half of the stuff under there is. In particular, there is a black box to the right of the pedal structure that says "8 Cylinder Black Box" and is preceeded by a long alpha-numeric chain. I have read the posts about a recording device that can be read but this doesn't seem like it would be one of those. Plus, I don't know if they had that stuff in 1987. I'd like to remove anything under there that isn't necessary for the operation of my newly rebuilt, non-computer/emmissions-control engine. Any help would be greatly appreciated.
Old 10-17-2015, 02:50 PM
ponypower ponypower is offline
ponypower is starting off with a positive reputation.
beeping
Just now my F150 started this beeping. When I turn the key off the loud beeping starts. 5 times, quits then beeps 5 more times...in total 5 series of 5 beeps. Now--the airbag warning bulb is not burned out--that still flashes. It has flashed off and on for 3 years now. If I shut the truck off and then restart it the flashing usually quits. The flashing was still there this morning--I wasn't going far so I just left it flashing.
The beeping....is not the same warning beep I would get from the truck otherwise--open door, lights left on, seat belt undone--none of those things. This truck buzzes, not beeps--and in truth the warning buzzer hasn't worked in years.
I am scrapping the truck shortly--after I take it to town once more to have the hitch cut off it--I would just like to know for sure what the beep is trying to tell me before I drive it again.
There was an odd smell in the cab this morning--not sure it was quite the same as the smell another similar truck had when the alternator caught fire....but maybe? A "hot" smell--chemical or perhaps melting plastic? Is there anything that would beep a warning if it started to burn? ?
Truck beeps at me 25 times shadyEats Ranger & B-Series 13 06-15-2015 03:00 PM
Random Beeping pdqtimetrialer 1978 - 1996 Big Bronco 8 04-03-2011 07:41 PM
GEM beeping ztodd377 1999 - 2003 7.3L Power Stroke Diesel 16 03-19-2011 07:27 AM
Getting these strange beeps from Dashboard greatone111 2004 - 2008 F150 11 11-15-2010 11:26 AM
beeping coming from under dash bigboy34 Explorer, Sport Trac, Mountaineer & Aviator 11 08-11-2006 12:14 PM
Tags
150, 1994, 94, beeping, beeps, black, box, coming, dash, f150, ford, international, loud, straight, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
