HOWTO - Steering Box Rebuild - Ford Truck Enthusiasts Forums
Old 02-10-2011, 08:58 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
<table style="background-color: rgb(218, 222, 235); text-align: left; width: 810px;" cellpadding="5" cellspacing="0" border="1"><tbody><tr><td style="vertical-align: top;">
End outermost table definition
-->Provided by Encho
<table style="background-color: rgb(244, 244, 254); text-align: left; width: 800px;" cellpadding="5" cellspacing="0" border="1"> <tbody> <tr> <td style="vertical-align: top;">
Ford (87 - 96 F-150/Bronco) Steering Box Rebuild
Quote:
Originally Posted by Encho View Post
Steering Box removal:
The first thing i did was separating the lines (High pressure and return) from the box, in order to be able to do that you'll need to take the snokel and the rubber tubes that link the throttle body and the air box (MAF equiped models will have only one tube). Use the 5/16 socket to loose the clamps on both tubes in order to separate them from the airbox, so you can then place them out of the way. To remove the snorkel use both hands and press on the plastic pieces clipping it to the airbox while pulling the snorkel. This is how your engine bay should be looking, now you have access to the top of the SB:
(frontal view) Notice the top of the airbox to the right. The tubes should be placed in a spot where they won't interfere with your work or get bent.
</td></tr></tbody></table>
End close of outermost table
FAQ - Exploded View Diagrams (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 07:00 PM
FAQ - How to determine if engine is a 302 or 351W ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 12:20 PM
HOWTO - Rear Window Replacement ctubutis '80-'86 HOWTO's 0 02-13-2011 12:44 PM
FAQ - Wheel Technical Information (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-08-2011 08:18 PM
FAQ - Fuse box diagram ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 01-25-2011 09:24 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
adjustment, compression gauge, compression stroke, distributor cap, exhaust stroke, firing order, hydraulic valves, tdc, top dead center
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
