Code list
Code list
- <LI itxtNodeId="1022" itxtHarvested="0">P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A <LI itxtNodeId="1021" itxtHarvested="0">P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1 <LI itxtNodeId="1020" itxtHarvested="0">P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1 <LI itxtNodeId="1019" itxtHarvested="0">P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1 <LI itxtNodeId="1018" itxtHarvested="0">P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2 <LI itxtNodeId="1017" itxtHarvested="0">P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2 <LI itxtNodeId="1016" itxtHarvested="0">P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2 <LI itxtNodeId="1015" itxtHarvested="0">P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1 <LI itxtNodeId="1014" itxtHarvested="0">P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1 <LI itxtNodeId="1013" itxtHarvested="0">P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1 <LI itxtNodeId="1012" itxtHarvested="0">P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM) <LI itxtNodeId="1011" itxtHarvested="0">P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM) <LI itxtNodeId="1010" itxtHarvested="0">P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2 <LI itxtNodeId="1009" itxtHarvested="0">P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2 <LI itxtNodeId="1008" itxtHarvested="0">P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2 <LI itxtNodeId="1007" itxtHarvested="0">P0068 - Throttle Body Airflow Performance (PCM) <LI itxtNodeId="1006" itxtHarvested="0">P0100 - MAF Sensor Circuit Insufficient Activity <LI itxtNodeId="1005" itxtHarvested="0">P0101 - Mass Air Flow (MAF) Sensor Performance <LI itxtNodeId="1004" itxtHarvested="0">P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency <LI itxtNodeId="1003" itxtHarvested="0">P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency <LI itxtNodeId="1002" itxtHarvested="0">P0104 - Mass Air Flow Circuit Intermittent <LI itxtNodeId="1001" itxtHarvested="0">P0105 - MAP Sensor Circuit Insufficient Activity <LI itxtNodeId="1000" itxtHarvested="0">P0106 - Manifold Absolute Pressure (MAP) System Performance <LI itxtNodeId="999" itxtHarvested="0">P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage <LI itxtNodeId="998" itxtHarvested="0">P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage <LI itxtNodeId="997" itxtHarvested="0">P0109 - Manifold Absolute Pressure Circuit Intermittent <LI itxtNodeId="996" itxtHarvested="0">P0110 - Intake Air Temperature (IAT) Sensor Circuit <LI itxtNodeId="995" itxtHarvested="0">P0111 - Intake Air Temperature (IAT) Sensor Performance <LI itxtNodeId="994" itxtHarvested="0">P0112 - Intake Air Temperature (IAT) Sensor Circuit Low Voltage <LI itxtNodeId="993" itxtHarvested="0">P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage <LI itxtNodeId="992" itxtHarvested="0">P0114 - Intake Air Temperature Circuit Intermittent <LI itxtNodeId="991" itxtHarvested="0">P0115 - Engine Coolant Temperature (ECT) Sensor Circuit <LI itxtNodeId="990" itxtHarvested="0">P0116 - Engine Coolant Temperature (ECT) Sensor Performance <LI itxtNodeId="989" itxtHarvested="0">P0117 - Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage <LI itxtNodeId="988" itxtHarvested="0">P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage <LI itxtNodeId="987" itxtHarvested="0">P0119 - Engine Coolant Temperature Circuit Intermittent <LI itxtNodeId="986" itxtHarvested="0">P0120 - TP System Performance <LI itxtNodeId="985" itxtHarvested="0">P0121 - TP Sensor Circuit Insufficient Activity <LI itxtNodeId="984" itxtHarvested="0">P0122 - Throttle Position (TP) Sensor Circuit Low Voltage <LI itxtNodeId="983" itxtHarvested="0">P0123 - Throttle Position (TP) Sensor Circuit High Voltage <LI itxtNodeId="982" itxtHarvested="0">P0124 - Throttle Position Sensor 1 Circuit Intermittent <LI itxtNodeId="981" itxtHarvested="0">P0125 - Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control <LI itxtNodeId="980" itxtHarvested="0">P0126 - Insufficient ECT for Stable Operation <LI itxtNodeId="979" itxtHarvested="0">P0128 - Coolant Thermostat Below Thermostat Regulating Temperature <LI itxtNodeId="978" itxtHarvested="0">P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 <LI itxtNodeId="977" itxtHarvested="0">P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 <LI itxtNodeId="976" itxtHarvested="0">P0132 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1 <LI itxtNodeId="975" itxtHarvested="0">P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1 <LI itxtNodeId="974" itxtHarvested="0">P0134 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1 <LI itxtNodeId="973" itxtHarvested="0">P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1 <LI itxtNodeId="972" itxtHarvested="0">P0136 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 <LI itxtNodeId="971" itxtHarvested="0">P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2 <LI itxtNodeId="970" itxtHarvested="0">P0138 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2 <LI itxtNodeId="969" itxtHarvested="0">P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2 <LI itxtNodeId="968" itxtHarvested="0">P0140 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2 <LI itxtNodeId="967" itxtHarvested="0">P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2 <LI itxtNodeId="966" itxtHarvested="0">P0142 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 3 <LI itxtNodeId="965" itxtHarvested="0">P0143 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3 <LI itxtNodeId="964" itxtHarvested="0">P0144 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3 <LI itxtNodeId="963" itxtHarvested="0">P0145 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 Slow Response <LI itxtNodeId="962" itxtHarvested="0">P0146 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 3 <LI itxtNodeId="961" itxtHarvested="0">P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3 <LI itxtNodeId="960" itxtHarvested="0">P0150 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 2 Sensor 1 <LI itxtNodeId="959" itxtHarvested="0">P0151 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1 <LI itxtNodeId="958" itxtHarvested="0">P0152 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1 <LI itxtNodeId="957" itxtHarvested="0">P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1 <LI itxtNodeId="956" itxtHarvested="0">P0154 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1 <LI itxtNodeId="955" itxtHarvested="0">P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1 <LI itxtNodeId="954" itxtHarvested="0">P0156 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 2 <LI itxtNodeId="953" itxtHarvested="0">P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2 <LI itxtNodeId="952" itxtHarvested="0">P0158 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2 <LI itxtNodeId="951" itxtHarvested="0">P0159 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 2 <LI itxtNodeId="950" itxtHarvested="0">P0160 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2 <LI itxtNodeId="949" itxtHarvested="0">P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2 <LI itxtNodeId="948" itxtHarvested="0">P0162 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 <LI itxtNodeId="947" itxtHarvested="0">P0163 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Low Voltage <LI itxtNodeId="946" itxtHarvested="0">P0164 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 High Voltage <LI itxtNodeId="945" itxtHarvested="0">P0165 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Slow Response <LI itxtNodeId="944" itxtHarvested="0">P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected <LI itxtNodeId="943" itxtHarvested="0">P0167 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 3 <LI itxtNodeId="942" itxtHarvested="0">P0169 - Fuel Composition Sensor <LI itxtNodeId="941" itxtHarvested="0">P0170 - Fuel Trim Bank 1 <LI itxtNodeId="940" itxtHarvested="0">P0171 - Fuel Trim System Lean Bank 1 <LI itxtNodeId="939" itxtHarvested="0">P0172 - Fuel Trim System Rich Bank 1 <LI itxtNodeId="938" itxtHarvested="0">P0173 - Fuel Trim Bank 2 <LI itxtNodeId="937" itxtHarvested="0">P0174 - Fuel Trim System Lean Bank 2 <LI itxtNodeId="936" itxtHarvested="0">P0175 - Fuel Trim System Rich Bank 2 <LI itxtNodeId="935" itxtHarvested="0">P0176 - Fuel Composition Sensor Circuit <LI itxtNodeId="934" itxtHarvested="0">P0177 - Fuel Composition Sensor Circuit Performance <LI itxtNodeId="933" itxtHarvested="0">P0178 - Fuel Composition Sensor Circuit Low Voltage <LI itxtNodeId="932" itxtHarvested="0">P0179 - Fuel Composition Sensor Circuit High Voltage <LI itxtNodeId="931" itxtHarvested="0">P0180 - Fuel Temperature Sensor 1 Circuit <LI itxtNodeId="930" itxtHarvested="0">P0181 - Fuel Temp. Sensor 1 Circuit Performance <LI itxtNodeId="929" itxtHarvested="0">P0182 - Fuel Temperature Sensor Circuit Low Voltage <LI itxtNodeId="928" itxtHarvested="0">P0183 - Fuel Temperature Sensor Circuit High Voltage <LI itxtNodeId="927" itxtHarvested="0">P0184 - Fuel Temperature Sensor 1 Circuit Intermittent <LI itxtNodeId="926" itxtHarvested="0">P0185 - Fuel Temperature Sensor 2 Circuit <LI itxtNodeId="925" itxtHarvested="0">P0186 - Fuel Temp. Sensor 2 Circuit Performance <LI itxtNodeId="924" itxtHarvested="0">P0187 - Fuel Temperature Sensor 2 Circuit Low Voltage <LI itxtNodeId="923" itxtHarvested="0">P0188 - Fuel Temperature Sensor 2 Circuit High Voltage <LI itxtNodeId="922" itxtHarvested="0">P0189 - Fuel Temperature Sensor 2 Circuit Intermittent <LI itxtNodeId="921" itxtHarvested="0">P0190 - Fuel Rail Pressure Sensor Circuit <LI itxtNodeId="920" itxtHarvested="0">P0191 - Fuel Rail Pressure Sensor Circuit Performance <LI itxtNodeId="919" itxtHarvested="0">P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage <LI itxtNodeId="918" itxtHarvested="0">P0193 - Fuel Rail Pressure Sensor Circuit High Voltage <LI itxtNodeId="917" itxtHarvested="0">P0194 - Fuel Rail Pressure Sensor Circuit Intermittent <LI itxtNodeId="916" itxtHarvested="0">P0195 - Engine Oil Temperature Sensor <LI itxtNodeId="915" itxtHarvested="0">P0196 - Engine Oil Temperature Sensor Performance <LI itxtNodeId="914" itxtHarvested="0">P0197 - Engine Oil Temperature Sensor Low Voltage <LI itxtNodeId="913" itxtHarvested="0">P0198 - Engine Oil Temperature Sensor High Voltage <LI itxtNodeId="912" itxtHarvested="0">P0199 - Engine Oil Temperature Sensor Intermittent <LI itxtNodeId="911" itxtHarvested="0">P0200 - Injector Control Circuit <LI itxtNodeId="910" itxtHarvested="0">P0201 - Injector 1 Control Circuit <LI itxtNodeId="909" itxtHarvested="0">P0202 - Injector 2 Control Circuit <LI itxtNodeId="908" itxtHarvested="0">P0203 - Injector 3 Control Circuit <LI itxtNodeId="907" itxtHarvested="0">P0204 - Injector 4 Control Circuit <LI itxtNodeId="906" itxtHarvested="0">P0205 - Injector 5 Control Circuit <LI itxtNodeId="905" itxtHarvested="0">P0206 - Injector 6 Control Circuit <LI itxtNodeId="904" itxtHarvested="0">P0207 - Injector 7 Control Circuit <LI itxtNodeId="903" itxtHarvested="0">P0208 - Injector 8 Control Circuit <LI itxtNodeId="902" itxtHarvested="0">P0209 - Injector 9 Control Circuit <LI itxtNodeId="901" itxtHarvested="0">P0210 - Injector 10 Control Circuit <LI itxtNodeId="900" itxtHarvested="0">P0211 - Injector 11 Control Circuit <LI itxtNodeId="899" itxtHarvested="0">P0212 - Injector 12 Control Circuit <LI itxtNodeId="898" itxtHarvested="0">P0213 - Cold Start Injector 1 <LI itxtNodeId="897" itxtHarvested="0">P0214 - Cold Start Injector 2 <LI itxtNodeId="896" itxtHarvested="0">P0215 - Engine Shutoff Control Circuit <LI itxtNodeId="895" itxtHarvested="0">P0216 - Injection Timing Control Circuit <LI itxtNodeId="894" itxtHarvested="0">P0217 - Engine Overtemp Condition <LI itxtNodeId="893" itxtHarvested="0">P0218 - Transmission Fluid Overtemperature <LI itxtNodeId="892" itxtHarvested="0">P0219 - Engine Overspeed Condition <LI itxtNodeId="891" itxtHarvested="0">P0220 - APP Sensor 2 Circuit <LI itxtNodeId="890" itxtHarvested="0">P0221 - APP (Throttle Position) Sensor 2 Circuit Performance <LI itxtNodeId="889" itxtHarvested="0">P0222 - APP (Throttle Position) Sensor 2 Circuit Low Voltage <LI itxtNodeId="888" itxtHarvested="0">P0223 - APP (Throttle Position) Sensor 2 Circuit High Voltage <LI itxtNodeId="887" itxtHarvested="0">P0224 - Throttle Position Sensor 2 Intermittent <LI itxtNodeId="886" itxtHarvested="0">P0225 - APP Sensor 3 Circuit <LI itxtNodeId="885" itxtHarvested="0">P0226 - APP Sensor 3 Circuit Performance <LI itxtNodeId="884" itxtHarvested="0">P0227 - APP Sensor 3 Circuit Low Voltage <LI itxtNodeId="883" itxtHarvested="0">P0228 - APP Sensor 3 Circuit High Voltage <LI itxtNodeId="882" itxtHarvested="0">P0229 - Throttle Position Sensor 3 Intermittent <LI itxtNodeId="881" itxtHarvested="0">P0230 - Fuel Pump Relay Control Circuit <LI itxtNodeId="880" itxtHarvested="0">P0231 - Fuel Pump Feedback Circuit Low Voltage <LI itxtNodeId="879" itxtHarvested="0">P0232 - Fuel Pump Feedback Circuit High Voltage <LI itxtNodeId="878" itxtHarvested="0">P0233 - Fuel Pump Secondary Circuit Intermittent <LI itxtNodeId="877" itxtHarvested="0">P0234 - Turbocharger Engine Overboost Condition <LI itxtNodeId="876" itxtHarvested="0">P0235 - Turbocharger Boost Sensor 1 Circuit <LI itxtNodeId="875" itxtHarvested="0">P0236 - Turbocharger Boost System <LI itxtNodeId="874" itxtHarvested="0">P0237 - Turbocharger Boost Sensor Circuit Low Voltage <LI itxtNodeId="873" itxtHarvested="0">P0238 - Turbocharger Boost Sensor Circuit High Voltage <LI itxtNodeId="872" itxtHarvested="0">P0239 - Turbocharger Boost Sensor 2 Circuit <LI itxtNodeId="871" itxtHarvested="0">P0240 - Turbocharger Boost Sensor 2 Performance <LI itxtNodeId="870" itxtHarvested="0">P0241 - Turbocharger Boost Sensor 2 Circuit Low Voltage <LI itxtNodeId="869" itxtHarvested="0">P0242 - Turbocharger Boost Sensor 2 Circuit High Voltage <LI itxtNodeId="868" itxtHarvested="0">P0243 - Turbocharger Wastegate Solenoid 1 <LI itxtNodeId="867" itxtHarvested="0">P0244 - Turbocharger Wastegate Solenoid 1 Performance <LI itxtNodeId="866" itxtHarvested="0">P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage <LI itxtNodeId="865" itxtHarvested="0">P0246 - Turbocharger Wastegate Solenoid 1 High Voltage <LI itxtNodeId="864" itxtHarvested="0">P0247 - Turbocharger Wastegate Solenoid 2 <LI itxtNodeId="863" itxtHarvested="0">P0248 - Turbocharger Wastegate Solenoid 2 Performance <LI itxtNodeId="862" itxtHarvested="0">P0249 - Turbocharger Wastegate Solenoid 2 Low Voltage <LI itxtNodeId="861" itxtHarvested="0">P0250 - Turbocharger Wastegate Solenoid 2 High Voltage <LI itxtNodeId="860" itxtHarvested="0">P0251 - Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector) <LI itxtNodeId="859" itxtHarvested="0">P0252 - Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector) <LI itxtNodeId="858" itxtHarvested="0">P0253 - Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) <LI itxtNodeId="857" itxtHarvested="0">P0254 - Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector) <LI itxtNodeId="856" itxtHarvested="0">P0255 - Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector) <LI itxtNodeId="855" itxtHarvested="0">P0256 - Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector) <LI itxtNodeId="854" itxtHarvested="0">P0257 - Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector) <LI itxtNodeId="853" itxtHarvested="0">P0258 - Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector) <LI itxtNodeId="852" itxtHarvested="0">P0259 - Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector) <LI itxtNodeId="851" itxtHarvested="0">P0260 - Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector) <LI itxtNodeId="850" itxtHarvested="0">P0261 - Cylinder 1 Injector Circuit Low <LI itxtNodeId="849" itxtHarvested="0">P0262 - Cylinder 1 Injector Circuit High <LI itxtNodeId="848" itxtHarvested="0">P0263 - Cylinder 1 Contribution/Balance Fault <LI itxtNodeId="847" itxtHarvested="0">P0264 - Cylinder 2 Injector Circuit Low <LI itxtNodeId="846" itxtHarvested="0">P0265 - Cylinder 2 Injector Circuit High <LI itxtNodeId="845" itxtHarvested="0">P0266 - Cylinder 2 Contribution/Balance Fault <LI itxtNodeId="844" itxtHarvested="0">P0267 - Cylinder 3 Injector Circuit Low <LI itxtNodeId="843" itxtHarvested="0">P0268 - Cylinder 3 Injector Circuit High <LI itxtNodeId="842" itxtHarvested="0">P0269 - Cylinder 3 Contribution/Balance Fault <LI itxtNodeId="841" itxtHarvested="0">P0270 - Cylinder 4 Injector Circuit Low <LI itxtNodeId="840" itxtHarvested="0">P0271 - Cylinder 4 Injector Circuit High <LI itxtNodeId="839" itxtHarvested="0">P0272 - Cylinder 4 Contribution/Balance Fault <LI itxtNodeId="838" itxtHarvested="0">P0273 - Cylinder 5 Injector Circuit Low <LI itxtNodeId="837" itxtHarvested="0">P0274 - Cylinder 5 Injector Circuit High <LI itxtNodeId="836" itxtHarvested="0">P0275 - Cylinder 5 Contribution/Balance Fault <LI itxtNodeId="835" itxtHarvested="0">P0276 - Cylinder 6 Injector Circuit Low <LI itxtNodeId="834" itxtHarvested="0">P0277 - Cylinder 6 Injector Circuit High <LI itxtNodeId="833" itxtHarvested="0">P0278 - Cylinder 6 Contribution/Balance Fault <LI itxtNodeId="832" itxtHarvested="0">P0279 - Cylinder 7 Injector Circuit Low <LI itxtNodeId="831" itxtHarvested="0">P0280 - Cylinder 7 Injector Circuit High <LI itxtNodeId="830" itxtHarvested="0">P0281 - Cylinder 7 Contribution/Balance Fault <LI itxtNodeId="829" itxtHarvested="0">P0282 - Cylinder 8 Injector Circuit Low <LI itxtNodeId="828" itxtHarvested="0">P0283 - Cylinder 8 Injector Circuit High <LI itxtNodeId="827" itxtHarvested="0">P0284 - Cylinder 8 Contribution/Balance Fault <LI itxtNodeId="826" itxtHarvested="0">P0285 - Cylinder 9 Injector Circuit Low <LI itxtNodeId="825" itxtHarvested="0">P0286 - Cylinder 9 Injector Circuit High <LI itxtNodeId="824" itxtHarvested="0">P0287 - Cylinder 9 Contribution/Balance Fault <LI itxtNodeId="823" itxtHarvested="0">P0288 - Cylinder 10 Injector Circuit Low <LI itxtNodeId="822" itxtHarvested="0">P0289 - Cylinder 10 Injector Circuit High <LI itxtNodeId="821" itxtHarvested="0">P0290 - Cylinder 10 Contribution/Balance Fault <LI itxtNodeId="820" itxtHarvested="0">P0291 - Cylinder 11 Injector Circuit Low <LI itxtNodeId="819" itxtHarvested="0">P0292 - Cylinder 11 Injector Circuit High <LI itxtNodeId="818" itxtHarvested="0">P0293 - Cylinder 11 Contribution/Balance Fault <LI itxtNodeId="817" itxtHarvested="0">P0294 - Cylinder 12 Injector Circuit Low <LI itxtNodeId="816" itxtHarvested="0">P0295 - Cylinder 12 Injector Circuit High <LI itxtNodeId="815" itxtHarvested="0">P0296 - Cylinder 12 Contribution/Range Fault <LI itxtNodeId="814" itxtHarvested="0">P0300 - Engine Misfire Detected <LI itxtNodeId="813" itxtHarvested="0">P0301 - Cylinder 1 Misfire Detected <LI itxtNodeId="812" itxtHarvested="0">P0302 - Cylinder 2 Misfire Detected <LI itxtNodeId="811" itxtHarvested="0">P0303 - Cylinder 3 Misfire Detected <LI itxtNodeId="810" itxtHarvested="0">P0304 - Cylinder 4 Misfire Detected <LI itxtNodeId="809" itxtHarvested="0">P0305 - Cylinder 5 Misfire Detected <LI itxtNodeId="808" itxtHarvested="0">P0306 - Cylinder 6 Misfire Detected <LI itxtNodeId="807" itxtHarvested="0">P0307 - Cylinder 7 Misfire Detected <LI itxtNodeId="806" itxtHarvested="0">P0308 - Cylinder 8 Misfire Detected <LI itxtNodeId="805" itxtHarvested="0">P0309 - Cylinder 9 Misfire Detected <LI itxtNodeId="804" itxtHarvested="0">P0310 - Cylinder 10 Misfire Detected <LI itxtNodeId="803" itxtHarvested="0">P0311 - Cylinder 11 Misfire Detected <LI itxtNodeId="802" itxtHarvested="0">P0312 - Cylinder 12 Misfire Detected <LI itxtNodeId="801" itxtHarvested="0">P0313 - Misfire Detected With Low Fuel Level <LI itxtNodeId="800" itxtHarvested="0">P0315 - Crankshaft position (CKP) system variation values are not stored in the PCM memory <LI itxtNodeId="799" itxtHarvested="0">P0318 - Rough Road Sensor Circuit <LI itxtNodeId="798" itxtHarvested="0">P0320 - Ignition/Distributor Engine Speed Input Circuit Malfunction <LI itxtNodeId="797" itxtHarvested="0">P0321 - Ignition/Distributor Engine Speed Input Circuit Range/Performance <LI itxtNodeId="796" itxtHarvested="0">P0322 - IC Module 4X Reference Circuit No Frequency <LI itxtNodeId="795" itxtHarvested="0">P0323 - Ignition/Distributor Engine Speed Input Circuit Intermittent <LI itxtNodeId="794" itxtHarvested="0">P0324 - Knock Sensor (KS) Module Performance <LI itxtNodeId="793" itxtHarvested="0">P0325 - PCM Knock Sensor Circuit <LI itxtNodeId="792" itxtHarvested="0">P0326 - Knock Sensor Circuit Excessive Spark Retard <LI itxtNodeId="791" itxtHarvested="0">P0327 - Knock Sensor Circuit Low Voltage <LI itxtNodeId="790" itxtHarvested="0">P0328 - Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) <LI itxtNodeId="789" itxtHarvested="0">P0329 - Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor) <LI itxtNodeId="788" itxtHarvested="0">P0330 - Knock Sensor (KS) Circuit Bank 2 <LI itxtNodeId="787" itxtHarvested="0">P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2) <LI itxtNodeId="786" itxtHarvested="0">P0332 - Knock Sensor 2 Circuit Low Input (Bank 2) <LI itxtNodeId="785" itxtHarvested="0">P0333 - Knock Sensor 2 Circuit High Input (Bank 2) <LI itxtNodeId="784" itxtHarvested="0">P0334 - Knock Sensor 2 Circuit Intermittent (Bank 2) <LI itxtNodeId="783" itxtHarvested="0">P0335 - CKP Sensor A Circuit Performance <LI itxtNodeId="782" itxtHarvested="0">P0336 - Crankshaft Position (CKP) Sensor A Performance <LI itxtNodeId="781" itxtHarvested="0">P0337 - Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle <LI itxtNodeId="780" itxtHarvested="0">P0338 - Crankshaft Position (CKP) Sensor Circuit High Duty Cycle <LI itxtNodeId="779" itxtHarvested="0">P0339 - Crankshaft Position (CKP) Sensor Circuit Intermittent <LI itxtNodeId="778" itxtHarvested="0">P0340 - Camshaft Position (CMP) Sensor Circuit <LI itxtNodeId="777" itxtHarvested="0">P0341 - Camshaft Position (CMP) Sensor Performance <LI itxtNodeId="776" itxtHarvested="0">P0342 - Camshaft Position Sensor Circuit Low Input <LI itxtNodeId="775" itxtHarvested="0">P0343 - Camshaft Position Sensor Circuit High Input <LI itxtNodeId="774" itxtHarvested="0">P0344 - Camshaft Position Sensor Circuit Intermittent <LI itxtNodeId="773" itxtHarvested="0">P0350 - Ignition Coil Primary/Secondary Circuit Malfunction <LI itxtNodeId="772" itxtHarvested="0">P0351 - Ignition Coil 1 Control Circuit <LI itxtNodeId="771" itxtHarvested="0">P0352 - Ignition Coil 2 Control Circuit <LI itxtNodeId="770" itxtHarvested="0">P0353 - Ignition Coil 3 Control Circuit <LI itxtNodeId="769" itxtHarvested="0">P0354 - Ignition Coil 4 Control Circuit <LI itxtNodeId="768" itxtHarvested="0">P0355 - Ignition Coil 5 Control Circuit <LI itxtNodeId="767">P0356 - Ignition Coil 6 Control Circuit <LI itxtNodeId="766">P0357 - Ignition Coil 7 Control Circuit <LI itxtNodeId="765">P0358 - Ignition Coil 8 Control Circuit <LI itxtNodeId="764">P0359 - Ignition Coil I Primary/Secondary Circuit Malfunction <LI itxtNodeId="763">P0360 - Ignition Coil J Primary/Secondary Circuit Malfunction <LI itxtNodeId="762">P0361 - Ignition Coil K Primary/Secondary Circuit Malfunction <LI itxtNodeId="761">P0362 - Ignition Coil L Primary/Secondary Circuit Malfunction <LI itxtNodeId="760">P0370 - Timing Reference High Resolution Signal A Malfunction <LI itxtNodeId="759">P0371 - IC 24X Reference Circuit Too Many Pulses <LI itxtNodeId="758">P0372 - IC 24X Reference Circuit Missing Pulses <LI itxtNodeId="757">P0373 - Timing Reference High Resolution Signal A Intermittent/Erratic Pulses <LI itxtNodeId="756">P0374 - Timing Reference High Resolution Signal A No Pulses <LI itxtNodeId="755">P0375 - Timing Reference High Resolution Signal B Malfunction <LI itxtNodeId="754">P0376 - Timing Reference High Resolution Signal B Too Many Pulses <LI itxtNodeId="753">P0377 - Timing Reference High Resolution Signal B Too Few Pulses <LI itxtNodeId="752">P0378 - Timing Reference High Resolution Signal B Intermittent/Erratic Pulses <LI itxtNodeId="751">P0379 - Timing Reference High Resolution Signal B No Pulses <LI itxtNodeId="750">P0380 - Glow Plug/Heater Circuit "A" Malfunction <LI itxtNodeId="749">P0381 - Glow Plug/Heater Indicator Circuit Malfunction <LI itxtNodeId="748">P0382 - Exhaust Gas Recirculation Flow Malfunction <LI itxtNodeId="747">P0385 - Crankshaft Position (CKP) Sensor B Circuit <LI itxtNodeId="746">P0386 - Crankshaft Position (CKP) Sensor B Performance <LI itxtNodeId="745">P0387 - Crankshaft Position Sensor B Circuit Low Input <LI itxtNodeId="744">P0388 - Crankshaft Position Sensor B Circuit High Input <LI itxtNodeId="743">P0389 - Crankshaft Position Sensor B Circuit Intermittent <LI itxtNodeId="742">P0400 - Exhaust Gas Recirculation Flow Malfunction <LI itxtNodeId="741">P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient <LI itxtNodeId="740">P0402 - Exhaust Gas Recirculation Flow Excessive Detected <LI itxtNodeId="739">P0403 - Exhaust Gas Recirculation (EGR) Solenoid Control Circuit <LI itxtNodeId="738">P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance <LI itxtNodeId="737">P0405 - Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage <LI itxtNodeId="736">P0406 - Exhaust Gas Recirculation Sensor A Circuit High <LI itxtNodeId="735">P0407 - Exhaust Gas Recirculation Sensor B Circuit Low <LI itxtNodeId="734">P0408 - Exhaust Gas Recirculation Sensor B Circuit High <LI itxtNodeId="733">P0410 - Secondary Air Injection (AIR) System <LI itxtNodeId="732">P0411 - Secondary Air Injection (AIR) System <LI itxtNodeId="731">P0412 - Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1 <LI itxtNodeId="730">P0413 - Secondary Air Injection System Switching Valve A Circuit Open <LI itxtNodeId="729">P0414 - Secondary Air Injection System Switching Valve A Circuit Shorted <LI itxtNodeId="728">P0415 - Secondary Air Injection System Switching Valve B Circuit Malfunction <LI itxtNodeId="727">P0416 - Secondary Air Injection System Switching Valve B Circuit Open <LI itxtNodeId="726">P0417 - Secondary Air Injection System Switching Valve B Circuit Shorted <LI itxtNodeId="725">P0418 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1 <LI itxtNodeId="724">P0419 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2 <LI itxtNodeId="723">P0420 - Catalyst System Low Efficiency <LI itxtNodeId="722">P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1) <LI itxtNodeId="721">P0422 - Catalyst System Low Efficiency Bank 1 <LI itxtNodeId="720">P0423 - Heated Catalyst Efficiency Below Threshold (Bank 1) <LI itxtNodeId="719">P0424 - Heated Catalyst Temperature Below Threshold (Bank 1) <LI itxtNodeId="718">P0430 - Catalyst System Low Efficiency Bank 2 <LI itxtNodeId="717">P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2) <LI itxtNodeId="716">P0432 - Catalyst System Low Efficiency Bank 2 <LI itxtNodeId="715">P0433 - Heated Catalyst Efficiency Below Threshold (Bank 2) <LI itxtNodeId="714">P0434 - Heated Catalyst Temperature Below Threshold (Bank 2) <LI itxtNodeId="713">P0440 - Evaporative Emission (EVAP) System <LI itxtNodeId="712">P0441 - Evaporative Emission Control System Incorrect Purge Flow <LI itxtNodeId="711">P0442 - Evaporative Emission (EVAP) System Small Leak Detected <LI itxtNodeId="710">P0443 - EVAP Purge Solenoid Valve 1 Control Circuit <LI itxtNodeId="709">P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open <LI itxtNodeId="708">P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted <LI itxtNodeId="707">P0446 - EVAP Vent Solenoid Valve Control System <LI itxtNodeId="706">P0447 - Evaporative Emission Control System Vent Control Circuit Open <LI itxtNodeId="705">P0448 - Evaporative Emission Control System Vent Control Circuit Shorted <LI itxtNodeId="704">P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit <LI itxtNodeId="703">P0450 - Fuel Tank Pressure Sensor Circuit <LI itxtNodeId="702">P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance <LI itxtNodeId="701">P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage
- P0453 - Fuel Tank Pressure Sensor Circuit High Voltage
<LI itxtNodeId="699">P0454 - Evaporative Emission Control System Pressure Sensor Intermittent <LI itxtNodeId="698">P0455 - Evaporative Emission (EVAP) System Leak Detected <LI itxtNodeId="697">P0460 - Fuel Level Sensor Circuit <LI itxtNodeId="696">P0461 - Fuel Level Sensor Performance <LI itxtNodeId="695">P0462 - Fuel Level Sensor Circuit Low Voltage <LI itxtNodeId="694">P0463 - Fuel Level Sensor Circuit High Voltage <LI itxtNodeId="693">P0464 - Fuel Level Sensor Circuit Intermittent <LI itxtNodeId="692">P0465 - Purge Flow Sensor Circuit Malfunction <LI itxtNodeId="691">P0466 - Purge Flow Sensor Circuit Range/Performance <LI itxtNodeId="690">P0467 - Purge Flow Sensor Circuit Low Input <LI itxtNodeId="689">P0468 - Purge Flow Sensor Circuit High Input <LI itxtNodeId="688">P0469 - Purge Flow Sensor Circuit Intermittent <LI itxtNodeId="687">P0470 - Exhaust Pressure Sensor Malfunction <LI itxtNodeId="686">P0471 - Exhaust Pressure Sensor Range/Performance <LI itxtNodeId="685">P0472 - Exhaust Pressure Sensor Low <LI itxtNodeId="684">P0473 - Exhaust Pressure Sensor High <LI itxtNodeId="683">P0474 - Exhaust Pressure Sensor Intermittent <LI itxtNodeId="682">P0475 - Exhaust Pressure Control Valve Malfunction <LI itxtNodeId="681">P0476 - Exhaust Pressure Control Valve Range/Performance <LI itxtNodeId="680">P0477 - Exhaust Pressure Control Valve Low <LI itxtNodeId="679">P0478 - Exhaust Pressure Control Valve High <LI itxtNodeId="678">P0479 - Exhaust Pressure Control Valve Intermittent <LI itxtNodeId="677">P0480 - Cooling Fan Relay 1 Control Circuit <LI itxtNodeId="676">P0481 - Cooling Fan Relay 2 Control Circuit <LI itxtNodeId="675">P0482 - Cooling Fan 3 Control Circuit Malfunction <LI itxtNodeId="674">P0483 - Cooling Fan Rationality Check Malfunction <LI itxtNodeId="673">P0484 - Cooling Fan Circuit Over Current <LI itxtNodeId="672">P0485 - Cooling Fan Power/Ground Circuit Malfunction <LI itxtNodeId="671">P0496 - Evaporative Emission (EVAP) System Flow During Non-Purge P0500 - Vehicle Speed Sensor (VSS) Circuit <LI itxtNodeId="669">P0501 - Vehicle Speed Sensor Range/Performance <LI itxtNodeId="668">P0502 - Vehicle Speed Sensor (VSS) Circuit Low Input <LI itxtNodeId="667">P0503 - Vehicle Speed Sensor (VSS) Circuit Intermittent <LI itxtNodeId="666">P0505 - Idle Control System Malfunction <LI itxtNodeId="665">P0506 - Idle Speed Low <LI itxtNodeId="664">P0507 - Idle Speed High <LI itxtNodeId="663">P0510 - Closed Throttle Position Switch Malfunction <LI itxtNodeId="662">P0512 - Start Switch Circuit <LI itxtNodeId="661">P0520 - Engine Oil Pressure Sensor/Switch Circuit Malfunction <LI itxtNodeId="660">P0521 - Engine Oil Pressure Sensor/Switch Circuit Range/Performance <LI itxtNodeId="659">P0522 - Engine Oil Pressure Sensor/Switch Circuit Low Voltage <LI itxtNodeId="658">P0523 - Engine Oil Pressure Sensor/Switch Circuit High Voltage <LI itxtNodeId="657">P0526 - Cooling Fan Speed Sensor Circuit <LI itxtNodeId="656">P0530 - A/C Refrigerant Pressure Sensor Circuit Malfunction <LI itxtNodeId="655">P0531 - A/C Refrigerant Pressure Sensor Circuit Range/Performance <LI itxtNodeId="654">P0532 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage <LI itxtNodeId="653">P0533 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage <LI itxtNodeId="652">P0534 - Air Conditioner Refrigerant Charge Loss <LI itxtNodeId="651">P0550 - Power Steering Pressure (PSP) Switch Circuit <LI itxtNodeId="650">P0551 - Power Steering Pressure Sensor Circuit Range/Performance <LI itxtNodeId="649">P0552 - Power Steering Pressure Sensor Circuit Low Input <LI itxtNodeId="648">P0553 - Power Steering Pressure Sensor Circuit High Input <LI itxtNodeId="647">P0554 - Power Steering Pressure Sensor Circuit Intermittent <LI itxtNodeId="646">P0560 - System Voltage <LI itxtNodeId="645">P0561 - System Voltage Unstable <LI itxtNodeId="644">P0562 - System Voltage Low (TCM) <LI itxtNodeId="643">P0563 - System Voltage High (TCM) <LI itxtNodeId="642">P0564 - Cruise Control Multi-Function Switch Circuit (PCM) <LI itxtNodeId="641">P0565 - Cruise Control On Signal Malfunction <LI itxtNodeId="640">P0566 - Cruise Control Off Signal Malfunction <LI itxtNodeId="639">P0567 - Cruise Control Resume Signal Malfunction <LI itxtNodeId="638">P0568 - Cruise Control Set Signal Malfunction <LI itxtNodeId="637">P0569 - Cruise Control Coast Signal Malfunction <LI itxtNodeId="636">P0570 - Cruise Control Accel Signal Malfunction <LI itxtNodeId="635">P0571 - Cruise Control Brake Switch Circuit <LI itxtNodeId="634">P0573 - Cruise Control/Brake Switch A Circuit High <LI itxtNodeId="633">P0574 - Vehicle Speed Too High - above 110 mph - Cruise Control Disabled <LI itxtNodeId="632">P0575 - Cruise Control Related Malfunction <LI itxtNodeId="631">P0576 - Cruise Control Related Malfunction <LI itxtNodeId="630">P0576 - Cruise Control Related Malfunction <LI itxtNodeId="629">P0578 - Cruise Control Related Malfunction <LI itxtNodeId="628">P0579 - Cruise Control Related Malfunction <LI itxtNodeId="627">P0580 - Cruise Control Related Malfunction <LI itxtNodeId="626">P0600 - Serial Communication Link Malfunction <LI itxtNodeId="625">P0601 - Control Module Read Only Memory (ROM) <LI itxtNodeId="624">P0602 - Control Module Not Programmed <LI itxtNodeId="623">P0603 - Control Module Long Term Memory Reset <LI itxtNodeId="622">P0604 - Control Module Random Access Memory (RAM) <LI itxtNodeId="621">P0605 - Control Module Programming Read Only Memory (ROM) <LI itxtNodeId="620">P0606 - Control Module Internal Performance <LI itxtNodeId="619">P0607 - ECU Malfunction <LI itxtNodeId="618">P0608 - Control Module VSS Output "A" Malfunction <LI itxtNodeId="617">P0609 - Control Module VSS Output "B" Malfunction <LI itxtNodeId="616">P0610 - Control Module Vehicle Options Incorrect <LI itxtNodeId="615">P0615 - Starter Relay Control Circuit <LI itxtNodeId="614">P0616 - Starter Relay Control Circuit Low Voltage <LI itxtNodeId="613">P0617 - Starter Relay Control Circuit High Voltage <LI itxtNodeId="612">P0620 - Generator Control Circuit Malfunction <LI itxtNodeId="611">P0621 - Generator L-Terminal Circuit <LI itxtNodeId="610">P0622 - Generator F-Terminal Circuit <LI itxtNodeId="609">P0625 - Generator F-Terminal Circuit Low Voltage <LI itxtNodeId="608">P0626 - Generator F-Terminal Circuit High Voltage <LI itxtNodeId="607">P0628 - Fuel Pump Relay Control Circuit Low Voltage <LI itxtNodeId="606">P0629 - Fuel Pump Relay Control Circuit High Voltage <LI itxtNodeId="605">P0638 - Throttle Actuator Control (TAC) Command Performance <LI itxtNodeId="604">P0641 - PCM voltage out of tolerance condition on the 5-volt reference circuit <LI itxtNodeId="603">P0645 - Air Conditioning (A/C) Clutch Relay Control Circuit <LI itxtNodeId="602">P0646 - Air Conditioning (A/C) Clutch Relay Control Circuit <LI itxtNodeId="601">P0647 - Air Conditioning (A/C) Clutch Relay Control Circuit <LI itxtNodeId="600">P0650 - Malfunction Indicator Lamp (MIL) Control Circuit <LI itxtNodeId="599">P0651 - PCM voltage out of tolerance condition on the 5-volt reference circuit <LI itxtNodeId="598">P0654 - Engine RPM Output Circuit Malfunction <LI itxtNodeId="597">P0655 - Engine Hot Lamp Output Control Circuit Malfucntion <LI itxtNodeId="596">P0656 - Fuel Level Output Circuit Malfunction <LI itxtNodeId="595">P0660 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit <LI itxtNodeId="594">P0661 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Voltage <LI itxtNodeId="593">P0662 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Voltage <LI itxtNodeId="592">P0685 - Engine Controls Ignition Relay Control Circuit (PCM) <LI itxtNodeId="591">P0691 - Cooling Fan Relay Control Circuit Low Voltage <LI itxtNodeId="590">P0693 - Cooling Fan Relay Control Circuit Low Voltage <LI itxtNodeId="589">P0692 - Cooling Fan Relay Control Circuit High Voltage <LI itxtNodeId="588">P0694 - Cooling Fan Relay Control Circuit High Voltage <LI itxtNodeId="587">P0700 - Transmission Control System Malfunction <LI itxtNodeId="586">P0701 - Transmission Control System Range/Performance <LI itxtNodeId="585">P0702 - Transmission Control System Electrical <LI itxtNodeId="584">P0703 - Brake Switch Circuit Malfunction <LI itxtNodeId="583">P0704 - Clutch Switch Input Circuit Malfunction <LI itxtNodeId="582">P0705 - Trans Range Switch Circuit <LI itxtNodeId="581">P0706 - Trans Range Switch Performance <LI itxtNodeId="580">P0707 - Transmission Range Sensor Circuit Low Input <LI itxtNodeId="579">P0708 - Transmission Range Sensor Circuit High Input <LI itxtNodeId="578">P0709 - Transmission Range Sensor Circuit Intermittent <LI itxtNodeId="577">P0710 - Transmission Fluid Temperature Sensor Circuit Malfunction <LI itxtNodeId="576">P0711 - TFT Sensor Circuit Range/Performance <LI itxtNodeId="575">P0712 - Transmission Fluid Temperature (TFT) Sensor Circuit Low Input <LI itxtNodeId="574">P0713 - Transmission Fluid Temperature (TFT) Sensor Circuit High Input <LI itxtNodeId="573">P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent <LI itxtNodeId="572">P0715 - Input/Turbine Speed Sensor Circuit Malfunction <LI itxtNodeId="571">P0716 - Input Speed Sensor Circuit Intermittent <LI itxtNodeId="570">P0717 - Input Speed Sensor Circuit Low Input <LI itxtNodeId="569">P0718 - Input/Turbine Speed Sensor Circuit Intermittent <LI itxtNodeId="568">P0719 - Brake Switch Circuit Low Input <LI itxtNodeId="567">P0720 - Output Speed Sensor Circuit Malfunction <LI itxtNodeId="566">P0721 - Output Speed Sensor Range/Performance <LI itxtNodeId="565">P0722 - Output Speed Sensor Circuit Low Input <LI itxtNodeId="564">P0723 - Output Speed Sensor Intermittent <LI itxtNodeId="563">P0724 - Brake Switch Circuit High Input <LI itxtNodeId="562">P0725 - Engine Speed Input Circuit <LI itxtNodeId="561">P0726 - Engine Speed Input Circuit Range/Performance <LI itxtNodeId="560">P0727 - Engine Speed Circuit No Signal <LI itxtNodeId="559">P0728 - Engine Speed Input Circuit Intermittent <LI itxtNodeId="558">P0730 - Incorrect Gear Ratio <LI itxtNodeId="557">P0731 - Incorrect 1st Gear Ratio <LI itxtNodeId="556">P0732 - Incorrect 2nd Gear Ratio <LI itxtNodeId="555">P0733 - Incorrect 3rd Gear Ratio <LI itxtNodeId="554">P0734 - Incorrect 4th Gear Ratio <LI itxtNodeId="553">P0735 - Gear 5 Incorrect ratio <LI itxtNodeId="552">P0736 - Reverse incorrect gear ratio <LI itxtNodeId="551">P0740 - TCC Enable Solenoid Circuit Electrical <LI itxtNodeId="550">P0741 - TCC System Stuck Off <LI itxtNodeId="549">P0742 - TCC System Stuck On <LI itxtNodeId="548">P0743 - TCC Enable Solenoid Circuit Electrical <LI itxtNodeId="547">P0744 - Torque Converter Clutch Circuit Intermittent <LI itxtNodeId="546">P0745 - Pressure Control Solenoid Malfunction <LI itxtNodeId="545">P0746 - Pressure Control Solenoid Performance or Stuck Off <LI itxtNodeId="544">P0747 - Pressure Control Solenoid Stuck On <LI itxtNodeId="543">P0748 - Pressure Control Solenoid Circuit Electrical <LI itxtNodeId="542">P0749 - Pressure Control Solenoid Intermittent <LI itxtNodeId="541">P0750 - Shift Solenoid A Malfunction <LI itxtNodeId="540">P0751 - 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear <LI itxtNodeId="539">P0752 - 1-2 Shift Solenoid Valve Performance - No Second or Third Gear <LI itxtNodeId="538">P0753 - 1-2 Shift Solenoid Circuit Electrical <LI itxtNodeId="537">P0754 - Shift Solenoid A Intermittent <LI itxtNodeId="536">P0755 - Shift Solenoid B Malfunction <LI itxtNodeId="535">P0756 - 2-3 Shift Solenoid Valve Performance - No First or Second Gear <LI itxtNodeId="534">P0757 - 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear <LI itxtNodeId="533">P0758 - 2-3 Shift Solenoid Circuit Electrical <LI itxtNodeId="532">P0759 - Shift Solenoid B Intermittent <LI itxtNodeId="531">P0760 - Shift Solenoid C Malfunction <LI itxtNodeId="530">P0761 - Shift Solenoid C Performance or Stuck Off <LI itxtNodeId="529">P0762 - Shift Solenoid C Stuck On <LI itxtNodeId="528">P0763 - Shift Solenoid C Electrical <LI itxtNodeId="527">P0764 - Shift Solenoid C Intermittent <LI itxtNodeId="526">P0765 - Shift Solenoid D Malfunction <LI itxtNodeId="525">P0766 - Shift Solenoid D Performance or Stuck Off <LI itxtNodeId="524">P0767 - Shift Solenoid D Stuck On <LI itxtNodeId="523">P0768 - Shift Solenoid D Electrical <LI itxtNodeId="522">P0769 - Shift Solenoid D Intermittent <LI itxtNodeId="521">P0770 - Shift Solenoid E Malfunction <LI itxtNodeId="520">P0771 - Shift Solenoid E Performance or Stuck Off <LI itxtNodeId="519">P0772 - Shift Solenoid E Stuck On <LI itxtNodeId="518">P0773 - Shift Solenoid E Electrical <LI itxtNodeId="517">P0774 - Shift Solenoid E Intermittent <LI itxtNodeId="516">P0780 - Shift Malfunction <LI itxtNodeId="515">P0781 - 1-2 Shift Malfunction <LI itxtNodeId="514">P0782 - 2-3 Shift Malfunction <LI itxtNodeId="513">P0783 - 3-4 Shift Malfunction <LI itxtNodeId="512">P0784 - 4-5 Shift Malfunction <LI itxtNodeId="511">P0785 - 3-2 Shift Solenoid Circuit Electrical <LI itxtNodeId="510">P0786 - Shift/Timing Solenoid Range/Performance <LI itxtNodeId="509">P0787 - Shift/Timing Solenoid Low <LI itxtNodeId="508">P0788 - Shift/Timing Solenoid High <LI itxtNodeId="507">P0789 - Shift/Timing Solenoid Intermittent <LI itxtNodeId="506">P0790 - Normal/Performance Switch Circuit Malfunction <LI itxtNodeId="505">P0801 - Reverse Inhibit Control Circuit Malfunction <LI itxtNodeId="504">P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction <LI itxtNodeId="503">P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction <LI itxtNodeId="502">P0850 - Park/Neutral Position (PNP) Switch Circuit <LI itxtNodeId="501">P0856 - Powertrain Indicated Traction Control Malfunction <LI itxtNodeId="500">P0894 - Transmission Component Slipping <LI itxtNodeId="499">P0897 - PCM detects a calculated transmission fluid life of 10 percent or less <LI itxtNodeId="498">P0962 - Line Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM) <LI itxtNodeId="497">P0963 - Line Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM) <LI itxtNodeId="496">P0966 - Clutch Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM) <LI itxtNodeId="495">P0967 - Clutch Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM) <LI itxtNodeId="494">P0970 - Shift Pressure control (PC) Solenoid Control Circuit Low Voltage (TCM) <LI itxtNodeId="493">P0971 - Shift Pressure Control (PC) Solenoid Control High Voltage (TCM) <LI itxtNodeId="492">P0973 - PCM detects an open or short to ground in the 1-2 SS valve circuit <LI itxtNodeId="491">P0974 - PCM detects a continuous short to voltage in the 1-2 SS valve circuit <LI itxtNodeId="490">P0976 - PCM detects a continuous open or short to ground in the 2-3 SS valve circuit <LI itxtNodeId="489">P0977 - PCM detects a continuous short to voltage in the 2-3 SS valve circuit <LI itxtNodeId="488">P0979 - Shift Solenoid (SS) 3 Control Circuit Low Voltage (TCM) <LI itxtNodeId="487">P0980 - Shift Solenoid (SS) 3 Control Circuit High Voltage (TCM) <LI itxtNodeId="486">P0982 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM) <LI itxtNodeId="485">P0983 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM) <LI itxtNodeId="484">P0985 - Shift Solenoid (SS) 5 Control Circuit Low Voltage (TCM) <LI itxtNodeId="483">P0986 - Shift Solenoid (SS) 5 Control Circuit High Voltage (TCM) <LI itxtNodeId="482">P1031 - Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1 <LI itxtNodeId="481">P1032 - Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1 <LI itxtNodeId="480">P1101 - Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow <LI itxtNodeId="479">P1105 - Secondary Vacuum Sensor Circuit <LI itxtNodeId="478">P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage <LI itxtNodeId="477">P1107 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage <LI itxtNodeId="476">P1108 - BARO to MAP Sensor Comparison Too High <LI itxtNodeId="475">P1109 - Secondary Port Throttle System <LI itxtNodeId="474">P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage <LI itxtNodeId="473">P1112 - Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage <LI itxtNodeId="472">P1113 - Intake Resonance Switchover Solenoid Control Circuit <LI itxtNodeId="471">P1114 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage <LI itxtNodeId="470">P1115 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage <LI itxtNodeId="469">P1116 - ECT Signal Unstable or Intermittent <LI itxtNodeId="468">P1117 - Engine Coolant Temp. Signal Out-Of-Range Low <LI itxtNodeId="467">P1118 - Engine Coolant Temp. Signal Out-Of-Range High <LI itxtNodeId="466">P1119 - ECT Signal Out-Of-Range With TFT Sensor <LI itxtNodeId="465">P1120 - Throttle Position (TP) Sensor 1 Circuit <LI itxtNodeId="464">P1121 - Throttle Position (TP) Sensor Circuit Intermittent High Voltage <LI itxtNodeId="463">P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage <LI itxtNodeId="462">P1125 - Accelerator Pedal Position (APP) System <LI itxtNodeId="461">P1130 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1 <LI itxtNodeId="460">P1131 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2 <LI itxtNodeId="459">P1132 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1 <LI itxtNodeId="458">P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1 <LI itxtNodeId="457">P1134 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1 <LI itxtNodeId="456">P1135 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1 <LI itxtNodeId="455">P1136 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1 <LI itxtNodeId="454">P1137 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage <LI itxtNodeId="453">P1138 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage <LI itxtNodeId="452">P1139 - Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2 <LI itxtNodeId="451">P1140 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2 <LI itxtNodeId="450">P1141 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2 <LI itxtNodeId="449">P1143 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage <LI itxtNodeId="448">P1144 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage <LI itxtNodeId="447">P1145 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3 <LI itxtNodeId="446">P1153 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1 <LI itxtNodeId="445">P1154 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
<LI itxtNodeId="444">P1155 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1 <LI itxtNodeId="443">P1156 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1 <LI itxtNodeId="442">P1157 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage <LI itxtNodeId="441">P1158 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage <LI itxtNodeId="440">P1159 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2 <LI itxtNodeId="439">P1161 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2 <LI itxtNodeId="438">P1163 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage <LI itxtNodeId="437">P1164 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage <LI itxtNodeId="436">P1165 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3 <LI itxtNodeId="435">P1170 - Bank to Bank Fuel Trim Offset <LI itxtNodeId="434">P1171 - Fuel System Lean During Acceleration <LI itxtNodeId="433">P1172 - Fuel Transfer Pump Flow Insufficient <LI itxtNodeId="432">P1185 - Engine Oil Temperature Circuit <LI itxtNodeId="431">P1186 - EOT Circuit Performance <LI itxtNodeId="430">P1187 - EOT Sensor Circuit Low Voltage <LI itxtNodeId="429">P1188 - EOT Sensor Circuit High Voltage <LI itxtNodeId="428">P1189 - Engine Oil Pressure (EOP) Switch Circuit <LI itxtNodeId="427">P1190 - Engine Vacuum Leak <LI itxtNodeId="426">P1191 - Intake Air Duct Air Leak <LI itxtNodeId="425">P1200 - Injector Control Circuit <LI itxtNodeId="424">P1201 - (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance <LI itxtNodeId="423">P1202 - (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency <LI itxtNodeId="422">P1203 - (Alt. Fuel) Gas Mass Sensor Circuit High Frequency <LI itxtNodeId="421">P1211 - Mass Air Flow Circuit Intermittent High <LI itxtNodeId="420">P1212 - Mass Air Flow Circuit Intermittent Low <LI itxtNodeId="419">P1214 - Injection Pump Timing Offset <LI itxtNodeId="418">P1215 - Ground Fault Detection Indicated <LI itxtNodeId="417">P1216 - Fuel Solenoid Response Time Too Short <LI itxtNodeId="416">P1217 - Fuel Solenoid Response Time Too Long <LI itxtNodeId="415">P1218 - Injection Pump Calibration Circuit <LI itxtNodeId="414">P1219 - Throttle Position Sensor Reference Voltage <LI itxtNodeId="413">P1220 - Throttle Position (TP) Sensor 2 Circuit <LI itxtNodeId="412">P1221 - Fuel Pump Secondary Circuit Low <LI itxtNodeId="411">P1222 - Injector Control Circuit Intermittent <LI itxtNodeId="410">P1225 - Injector Circuit Cylinder 2 Intermittent <LI itxtNodeId="409">P1228 - Injector Circuit Cylinder 3 Intermittent <LI itxtNodeId="408">P1231 - Injector Circuit Cylinder 4 Intermittent <LI itxtNodeId="407">P1234 - Injector Circuit Cylinder 5 Intermittent <LI itxtNodeId="406">P1237 - Injector Circuit Cylinder 6 Intermittent <LI itxtNodeId="405">P1240 - Injector Circuit Cylinder 7 Intermittent <LI itxtNodeId="404">P1243 - Injector Circuit Cylinder 8 Intermittent <LI itxtNodeId="403">P1245 - Intake Plenum Switchover Valve <LI itxtNodeId="402">P1250 - Early Fuel Evaporation Heater Circuit <LI itxtNodeId="401">P1257 - Supercharger System Overboost <LI itxtNodeId="400">P1258 - Engine Coolant Overtemperature - above 268°F - Protection Mode Active <LI itxtNodeId="399">P1260 - Last Test Failed Failed SCC ENTER:More Info. <LI itxtNodeId="398">P1270 - Accelerator Pedal Position Sensor A/D Converter Error <LI itxtNodeId="397">P1271 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation <LI itxtNodeId="396">P1272 - Accelerator Pedal Position Sensor 2 <LI itxtNodeId="395">P1273 - "Accelerator Pedal Position Sensor 1 <LI itxtNodeId="394">P1274 - Injectors Wired Incorrectly <LI itxtNodeId="393">P1275 - Accelerator Pedal Position (APP) Sensor 1 Circuit <LI itxtNodeId="392">P1276 - Accelerator Pedal Position Sensor 1 Circuit Performance <LI itxtNodeId="391">P1277 - Accelerator Pedal Position Sensor 1 Circuit Low Voltage <LI itxtNodeId="390">P1278 - Accelerator Pedal Position Sensor 1 Circuit High Voltage <LI itxtNodeId="389">P1280 - Accelerator Pedal Position (APP) Sensor 2 Circuit <LI itxtNodeId="388">P1281 - Accelerator Pedal Position Sensor 2 Circuit Performance <LI itxtNodeId="387">P1282 - Accelerator Pedal Position Sensor 2 Circuit Low Voltage <LI itxtNodeId="386">P1283 - Accelerator Pedal Position Sensor 2 Circuit High Voltage <LI itxtNodeId="385">P1285 - Accelerator Pedal Position Sensor 3 Circuit <LI itxtNodeId="384">P1286 - Accelerator Pedal Position Sensor 3 Circuit Performance <LI itxtNodeId="383">P1287 - Accelerator Pedal Position Sensor 3 Circuit Low Voltage <LI itxtNodeId="382">P1288 - Accelerator Pedal Position Sensor 3 Circuit High Voltage <LI itxtNodeId="381">P1300 - Ignitor Circuit <LI itxtNodeId="380">P1305 - Ignition Coil 2 Primary Feedback Circuit <LI itxtNodeId="379">P1310 - Ignition Coil 3 Primary Feedback Circuit <LI itxtNodeId="378">P1315 - Ignition Coil 4 Primary Feedback Circuit <LI itxtNodeId="377">P1320 - IC 4X Reference Circuit Intermittent <LI itxtNodeId="376">P1321 - Electronic Ignition System Fault Line <LI itxtNodeId="375">P1322 - EI System or Ignition Control Extra or Missing <LI itxtNodeId="374">P1323 - IC 24X Reference Circuit Low Frequency <LI itxtNodeId="373">P1324 - Crank RPM Too Low <LI itxtNodeId="372">P1335 - CKP Circuit <LI itxtNodeId="371">P1336 - Crankshaft Position (CKP) System Variation Not Learned <LI itxtNodeId="370">P1345 - Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation <LI itxtNodeId="369">P1346 - Intake Camshaft Position [CMP] Sensor System Performance <LI itxtNodeId="368">P1350 - Ignition Control System <LI itxtNodeId="367">P1351 - Ignition Coil Control Circuit High Voltage <LI itxtNodeId="366">P1352 - IC Output High/Pulse Detected when GND_Cyl. 2 <LI itxtNodeId="365">P1353 - IC Output High/Pulse Detected when GND_Cyl. 3 <LI itxtNodeId="364">P1354 - IC Output High/Pulse Detected when GND_Cyl. 4 <LI itxtNodeId="363">P1355 - IC Output High/Pulse Detected when GND_Cyl. 5 <LI itxtNodeId="362">P1356 - IC Output High/Pulse Detected when GND_Cyl. 6 <LI itxtNodeId="361">P1357 - IC Output High/Pulse Detected when GND_Cyl. 7 <LI itxtNodeId="360">P1358 - IC Output High/Pulse Detected when GND_Cyl. 8 <LI itxtNodeId="359">P1359 - Ignition Coil Group 1 Control Circuit <LI itxtNodeId="358">P1360 - Ignition Coil Group 2 Control Circuit <LI itxtNodeId="357">P1361 - Ignition Coil Control Circuit Low Voltage <LI itxtNodeId="356">P1362 - IC Cylinder 2 Not Toggling After Enable <LI itxtNodeId="355">P1363 - IC Cylinder 3 Not Toggling After Enable <LI itxtNodeId="354">P1364 - IC Cylinder 4 Not Toggling After Enable <LI itxtNodeId="353">P1365 - IC Cylinder 5 Not Toggling After Enable <LI itxtNodeId="352">P1366 - IC Cylinder 6 Not Toggling After Enable <LI itxtNodeId="351">P1367 - IC Cylinder 7 Not Toggling After Enable <LI itxtNodeId="350">P1368 - IC Cylinder 8 Not Toggling After Enable <LI itxtNodeId="349">P1370 - IC 4X Reference Circuit Too Many Pulses <LI itxtNodeId="348">P1371 - IC 4X Reference Circuit Too Few Pulses <LI itxtNodeId="347">P1372 - Crankshaft Position (CKP) Sensor A-B Correlation <LI itxtNodeId="346">P1374 - 3X Reference Circuit <LI itxtNodeId="345">P1375 - IC 24X Reference Circuit High Voltage <LI itxtNodeId="344">P1376 - Ignition Ground Circuit <LI itxtNodeId="343">P1377 - IC Cam Pulse To 4X Reference Pulse <LI itxtNodeId="342">P1380 - Misfire Detected - Rough Road Data Not Available <LI itxtNodeId="341">P1381 - Misfire Detected - No Communication with Brake Control Module <LI itxtNodeId="340">P1390 - Wheel Speed Sensor 1 - G - Sensor Circuit <LI itxtNodeId="339">P1391 - Wheel Speed Sensor 1 - G - Sensor Circuit Performance <LI itxtNodeId="338">P1392 - Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage <LI itxtNodeId="337">P1393 - Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage <LI itxtNodeId="336">P1394 - Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent <LI itxtNodeId="335">P1395 - Wheel Speed Sensor 2 - G - Sensor Circuit <LI itxtNodeId="334">P1396 - Wheel Speed Sensor 2 - G - Sensor Circuit Performance <LI itxtNodeId="333">P1397 - Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage <LI itxtNodeId="332">P1398 - Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage <LI itxtNodeId="331">P1399 - Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent <LI itxtNodeId="330">P1403 - Exhaust Gas Recirculation System Valve 1 <LI itxtNodeId="329">P1404 - Exhaust Gas Recirculation (EGR) Closed Position Performance <LI itxtNodeId="328">P1405 - Exhaust Gas Recirculation System Valve 3 <LI itxtNodeId="327">P1406 - EGR Valve Pintle Position Circuit <LI itxtNodeId="326">P1407 - EGR Air Intrusion in Exhaust Supply to EGR Valve <LI itxtNodeId="325">P1408 - Intake Manifold Pressure Sensor Circuit <LI itxtNodeId="324">P1409 - EGR Vacuum System Leak <LI itxtNodeId="323">P1410 - Fuel Tank Pressure System <LI itxtNodeId="322">P1415 - Secondary Air Injection (AIR) System Bank 1 <LI itxtNodeId="321">P1416 - Secondary Air Injection (AIR) System Bank 2 <LI itxtNodeId="320">P1418 - Secondary Air Injection System Relay A Control Circuit High <LI itxtNodeId="319">P1420 - Intake Air Low Pressure Switch Circuit Low Voltage <LI itxtNodeId="318">P1421 - Intake Air Low Pressure Switch Circuit High Voltage <LI itxtNodeId="317">P1423 - Intake Air High Pressure Switch Circuit High Voltage <LI itxtNodeId="316">P1431 - Fuel Level Sensor 2 Circuit Performance <LI itxtNodeId="315">P1432 - Fuel Level Sensor 2 Circuit Low Voltage <LI itxtNodeId="314">P1433 - Fuel Level Sensor 2 Circuit High Voltage <LI itxtNodeId="313">P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge <LI itxtNodeId="312">P1442 - EVAP Vacuum Sw. High Voltage During Ign. On <LI itxtNodeId="311">P1450 - Barometric Pressure Sensor Circuit <LI itxtNodeId="310">P1451 - Barometric Press. Sensor Performance <LI itxtNodeId="309">P1460 - Cooling Fan Control System <LI itxtNodeId="308">P1480 - Cooling Fan 1 Control Circuit High <LI itxtNodeId="307">P1481 - Cooling Fan Speed Sensor Circuit <LI itxtNodeId="306">P1482 - Cooling Fan Speed Output Circuit <LI itxtNodeId="305">P1483 - Engine Cooling System Performance <LI itxtNodeId="304">P1484 - Cooling Fan System Performance <LI itxtNodeId="303">P1500 - Starter Signal Circuit <LI itxtNodeId="302">P1501 - Theft Deterrent System <LI itxtNodeId="301">P1501 - Vehicle Speed Sensor Circuit Intermittent <LI itxtNodeId="300">P1502 - Theft Deterrent Fuel Enable Signal Not Received <LI itxtNodeId="299">P1503 - Theft Deterrent Fuel Enable Signal Not Correct <LI itxtNodeId="298">P1504 - Vehicle Speed Output Circuit <LI itxtNodeId="297">P1508 - Idle Speed Low - Idle Air Control (IAC) System Not Responding <LI itxtNodeId="296">P1509 - Idle Speed High - Idle Air Control (IAC) System Not Responding <LI itxtNodeId="295">P1510 - Throttle Control System Performance - Throttle Limitation Active <LI itxtNodeId="294">P1511 - Throttle Control System - Backup System Performance <LI itxtNodeId="293">P1514 - Airflow to TP Sensor Correlation High <LI itxtNodeId="292">P1515 - Electronic Throttle System Throttle Position <LI itxtNodeId="291">P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance <LI itxtNodeId="290">P1517 - Electronic Throttle Module <LI itxtNodeId="289">P1518 - Electronic Throttle Module to PCM Communication <LI itxtNodeId="288">P1519 - Throttle Actuator Control (TAC) Module Internal Circuit <LI itxtNodeId="287">P1520 - Transmission Range Switch Circuit <LI itxtNodeId="286">P1521 - Transmission Engaged at High Throttle Angle <LI itxtNodeId="285">P1522 - Park/Neutral to Drive/Reverse at High RPM <LI itxtNodeId="284">P1523 - Throttle Closed Position Performance <LI itxtNodeId="283">P1524 - Throttle Closed Position Performance <LI itxtNodeId="282">P1525 - Throttle Body ServiceRequired <LI itxtNodeId="281">P1526 - Minimum Throttle Position Not Learned <LI itxtNodeId="280">P1527 - Transmission Range to Pressure Switch Correlation <LI itxtNodeId="279">P1528 - Governor <LI itxtNodeId="278">P1529 - Heated Windshield Request Problem <LI itxtNodeId="277">P1530 - Throttle Actuator Control (TAC) Module Internal Circuit <LI itxtNodeId="276">P1531 - A/C Low Side Temperature Sensor Fault <LI itxtNodeId="275">P1532 - A/C Evaporator Temp. Sens. Circuit Low Voltage <LI itxtNodeId="274">P1533 - A/C Evaporator Temp. Sens. Circuit High Voltage <LI itxtNodeId="273">P1534 - A/C High Side Temp. Sensor Low Voltage <LI itxtNodeId="272">P1535 - A/C High Side Temperature Sensor Circuit <LI itxtNodeId="271">P1536 - Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled <LI itxtNodeId="270">P1537 - A/C Request Circuit Low Voltage <LI itxtNodeId="269">P1538 - A/C Request Circuit High Voltage <LI itxtNodeId="268">P1539 - A/C Clutch Status Circuit High Voltage <LI itxtNodeId="267">P1540 - Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled <LI itxtNodeId="266">P1541 - A/C High Side Over Temperature <LI itxtNodeId="265">P1542 - A/C System High Pressure High Temperature <LI itxtNodeId="264">P1543 - A/C System Performance <LI itxtNodeId="263">P1544 - A/C Refrigerant Condition Very Low <LI itxtNodeId="262">P1545 - Air Conditioning (A/C) Clutch Relay Control Circuit <LI itxtNodeId="261">P1546 - A/C Clutch Status Circuit Low Voltage <LI itxtNodeId="260">P1547 - A/C System Performance Degraded <LI itxtNodeId="259">P1548 - A/C Recirculation Circuit <LI itxtNodeId="258">P1551 - Throttle Valve Rest Position Not Reached During Learn <LI itxtNodeId="257">P1554 - Cruise Control Feedback Circuit <LI itxtNodeId="256">P1555 - Electronic Variable Orifice Output <LI itxtNodeId="255">P1558 - Cruise Control Servo Indicates Low <LI itxtNodeId="254">P1559 - Cruise Control Power Management Mode <LI itxtNodeId="253">P1560 - Transaxle Not in Drive - Cruise Control Disabled <LI itxtNodeId="252">P1561 - Cruise Vent Solenoid <LI itxtNodeId="251">P1562 - Cruise Vacuum Solenoid <LI itxtNodeId="250">P1563 - Cruise Vehicle Speed/Set Speed Difference Too High <LI itxtNodeId="249">P1564 - Vehicle Acceleration Too High - Cruise Control Disabled <LI itxtNodeId="248">P1565 - Cruise Servo Position Sensor <LI itxtNodeId="247">P1566 - Engine RPM Too High - Cruise Control Disabled <LI itxtNodeId="246">P1567 - Active Banking Control Active - Cruise Control Disabled <LI itxtNodeId="245">P1568 - Cruise Servo Stroke Greater than Commanded in Cruise <LI itxtNodeId="244">P1569 - Cruise Servo Stroke High While not in Cruise <LI itxtNodeId="243">P1570 - Traction Control Active - Cruise Control Disabled <LI itxtNodeId="242">P1571 - Traction Control Torque Request Circuit <LI itxtNodeId="241">P1572 - ASR Active Circuit Low Too Long <LI itxtNodeId="240">P1573 - PCM/EBTCM Serial Data Circuit <LI itxtNodeId="239">P1574 - Stoplamp Switch Circuit <LI itxtNodeId="238">P1575 - Extended Travel Brake Switch Circuit <LI itxtNodeId="237">P1576 - BBV Sensor Circuit High Voltage <LI itxtNodeId="236">P1577 - BBV Sensor Circuit Low Voltage <LI itxtNodeId="235">P1578 - BBV Sensor Circuit Low Vacuum <LI itxtNodeId="234">P1579 - P/N to D/R at High Throttle Angle - Power Reduction Mode Active <LI itxtNodeId="233">P1580 - Cruise Move Circuit Low Voltage <LI itxtNodeId="232">P1581 - Cruise Move Circuit High Voltage <LI itxtNodeId="231">P1582 - Cruise Direction Circuit Low Voltage <LI itxtNodeId="230">P1583 - Cruise Direction CircuitHigh Voltage <LI itxtNodeId="229">P1584 - Cruise Control Disabled <LI itxtNodeId="228">P1585 - Cruise Control Inhibit Output Circuit <LI itxtNodeId="227">P1586 - Cruise Control Brake Switch 2 Circuit <LI itxtNodeId="226">P1587 - Cruise Control Clutch Control Circuit Low <LI itxtNodeId="225">P1588 - Cruise Control Clutch Control Circuit High <LI itxtNodeId="224">P1599 - Engine Stall or Near Stall Detected <LI itxtNodeId="223">P1600 - TCM Internal Watchdog Operation <LI itxtNodeId="222">P1601 - Serial Comm. Problem With Device 1 <LI itxtNodeId="221">P1602 - Knock Sensor (KS) Module Performance <LI itxtNodeId="220">P1603 - Loss of SDM Serial Data <LI itxtNodeId="219">P1604 - Loss of IPC Serial Data <LI itxtNodeId="218">P1605 - Loss of HVAC Serial Data <LI itxtNodeId="217">P1606 - Serial Communication Problem With Device 6 <LI itxtNodeId="216">P1607 - Serial Communication Problem With Device 7 <LI itxtNodeId="215">P1608 - Serial Communication Problem With Device 8 <LI itxtNodeId="214">P1609 - Loss Of TCS Serial Data <LI itxtNodeId="213">P1610 - Loss of PZM Serial Data <LI itxtNodeId="212">P1611 - Loss of CVRTD Serial Data <LI itxtNodeId="211">P1612 - Loss of IPM Serial Data <LI itxtNodeId="210">P1613 - Loss of DIM Serial Data <LI itxtNodeId="209">P1614 - Loss of RIM Serial Data <LI itxtNodeId="208">P1615 - Loss of VTD Serial Data <LI itxtNodeId="207">P1617 - Engine Oil Level Switch Circuit <LI itxtNodeId="206">P1619 - Engine Oil Life Monitor Reset Circuit <LI itxtNodeId="205">P1620 - Low Coolant Circuit <LI itxtNodeId="204">P1621 - Control Module Long Term Memory Performance <LI itxtNodeId="203">P1622 - Cylinder Select <LI itxtNodeId="202">P1623 - Transmission Temp Pull-Up Resistor <LI itxtNodeId="201">P1624 - Customer Snapshot Requested - Data Available <LI itxtNodeId="200">P1625 - TCM System Reset <LI itxtNodeId="199">P1626 - Theft Deterrent Fuel Enable Signal Not Received <LI itxtNodeId="198">P1627 - A/D Performance <LI itxtNodeId="197">P1628 - ECT Pull-Up Resistor <LI itxtNodeId="196">P1629 - Theft Deterrent System - Cranking Signal <LI itxtNodeId="195">P1630 - Theft Deterrent Learn Mode Active <LI itxtNodeId="194">P1631 - Theft Deterrent Start Enable Signal Not Correct <LI itxtNodeId="193">P1632 - Theft Deterrent Fuel Disable Signal Received <LI itxtNodeId="192">P1633 - Ignition 0 Switch Circuit <LI itxtNodeId="191">P1634 - Ignition 1 Switch Circuit <LI itxtNodeId="190">P1635 - 5 Volt Reference Circuit <LI itxtNodeId="189">P1636 - PCM Stack Overrun <LI itxtNodeId="188">P1637 - Generator L-Terminal Circuit <LI itxtNodeId="187">P1638 - Generator F-Terminal Circuit <LI itxtNodeId="186">P1639 - 5 Volt Reference 2 Circuit <LI itxtNodeId="185">P1640 - Driver-1-Input High Voltage <LI itxtNodeId="184">P1641 - Malfunction Indicator Lamp (MIL) Control Circuit <LI itxtNodeId="183">P1642 - Vehicle Speed Output Circuit <LI itxtNodeId="182">P1643 - Engine Speed Output Circuit <LI itxtNodeId="181">P1644 - Traction Control Delivered Torque Output Circuit <LI itxtNodeId="180">P1645 - Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit <LI itxtNodeId="179">P1646 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit <LI itxtNodeId="178">P1647 - Driver 1 Line 7 <LI itxtNodeId="177">P1650 - Control Module Output B Circuit <LI itxtNodeId="176">P1651 - Fan 1 Relay Control Circuit <LI itxtNodeId="175">P1652 - Powertrain Induced Chassis Pitch Output Circuit <LI itxtNodeId="174">P1653 - Oil Level Lamp Control Circuit <LI itxtNodeId="173">P1654 - Cruise Control Inhibit Output Circuit <LI itxtNodeId="172">P1655 - EVAP Purge Solenoid Control Circuit <LI itxtNodeId="171">P1656 - Driver 2 Line 6 <LI itxtNodeId="170">P1657 - 1-4 Upshift Solenoid Control Circuit <LI itxtNodeId="169">P1658 - Starter Enable Relay Control Circuit <LI itxtNodeId="168">P1660 - Cooling Fan Control Circuits <LI itxtNodeId="167">P1661 - MIL Control Circuit <LI itxtNodeId="166">P1662 - Cruise Lamp Control Circuit <LI itxtNodeId="165">P1663 - Oil Life Lamp Control Circuit <LI itxtNodeId="164">P1664 - 1-4 Upshift Lamp Control Circuit <LI itxtNodeId="163">P1665 - Driver 3 Line 5 <LI itxtNodeId="162">P1666 - Driver 3 Line 6 <LI itxtNodeId="161">P1667 - Reverse Inhibit Solenoid Control Circuit <LI itxtNodeId="160">P1669 - ABS Unit Expected <LI itxtNodeId="159">P1670 - Driver 4 <LI itxtNodeId="158">P1671 - Driver 4 Line 1 <LI itxtNodeId="157">P1672 - Low Engine Oil Level Lamp Control Circuit <LI itxtNodeId="156">P1673 - Engine Hot Lamp Control Circuit <LI itxtNodeId="155">P1674 - Tachometer Control Circuit <LI itxtNodeId="154">P1675 - EVAP Vent Solenoid Control Circuit <LI itxtNodeId="153">P1676 - Driver 4 Line 6 <LI itxtNodeId="152">P1677 - Driver 4 Line 7 <LI itxtNodeId="151">P1680 - Driver 5 (ECU Malfunction) <LI itxtNodeId="150">P1681 - Driver 5 Line 1 <LI itxtNodeId="149">P1682 - Driver 5 Line 2 <LI itxtNodeId="148">P1683 - Driver 5 Line 3 <LI itxtNodeId="147">P1684 - Driver 5 Line 4 <LI itxtNodeId="146">P1685 - Driver 5 Line 5 <LI itxtNodeId="145">P1686 - Driver 5 Line 6 <LI itxtNodeId="144">P1687 - Driver 5 Line 7 <LI itxtNodeId="143">P1689 - Delivered Torque Circuit Fault <LI itxtNodeId="142">P1690 - ECM Loop Overrun <LI itxtNodeId="141">P1691 - Coolant Gage Circuit Low Voltage <LI itxtNodeId="140">P1692 - Coolant Gage Circuit High Voltage <LI itxtNodeId="139">P1693 - Tachometer Circuit Low Voltage <LI itxtNodeId="138">P1694 - Tachometer Circuit High Voltage <LI itxtNodeId="137">P1695 - Remote Keyless Entry Circuit Low <LI itxtNodeId="136">P1696 - Remote Keyless Entry Voltage High <LI itxtNodeId="135">P1700 - Transmission Control Module (TCM) Requested MIL Illumination <LI itxtNodeId="134">P1701 - Trans. MIL Request Circuit <LI itxtNodeId="133">P1705 - P/N Signal Output Circuit <LI itxtNodeId="132">P1719 - Incorrect Shifting Detected (TCM) <LI itxtNodeId="131">P1740 - Torque Reduction Signal Circuit <LI itxtNodeId="130">P1743 - TP Signal from ECM <LI itxtNodeId="129">P1760 - TCM Supply Voltage Interrupted <LI itxtNodeId="128">P1779 - Engine Torque Delivered to TCM Signal <LI itxtNodeId="127">P1780 - Park/Neutral Position [PNP] Switch Circuit <LI itxtNodeId="126">P1781 - Engine Torque Signal Circuit <LI itxtNodeId="125">P1790 - Transmission Control Module Checksum <LI itxtNodeId="124">P1791 - Transmission Control Module Loop <LI itxtNodeId="123">P1791 - Throttle/Pedal Position Signal (2000+) <LI itxtNodeId="122">P1792 - Transmission Control Module Reprogrammable Memory <LI itxtNodeId="121">P1792 - ECM to TCM Engine Coolant Signal <LI itxtNodeId="120">P1793 - Transmission Control Module Stack Overrun <LI itxtNodeId="119">P1793 - Wheel Speed Signal (2000+) <LI itxtNodeId="118">P1795 - CAN Bus - Throttle Body Position <LI itxtNodeId="117">P1800 - TCM Power Relay Control Circuit <LI itxtNodeId="116">P1801 - Performance Selector Switch Failure <LI itxtNodeId="115">P1804 - Ground Control Relay <LI itxtNodeId="114">P1810 - TFP Valve Position Switch Circuit <LI itxtNodeId="113">P1811 - Maximum Adapt and Long Shift <LI itxtNodeId="112">P1812 - Transmission Over Temperature Condition <LI itxtNodeId="111">P1813 - Torque Control <LI itxtNodeId="110">P1814 - Torque Converter Overstressed <LI itxtNodeId="109">P1815 - Transmission Range Switch - Start In Wrong Range <LI itxtNodeId="108">P1816 - TFP Valve Position Sw. - Park/Neu. With Drive Ratio <LI itxtNodeId="107">P1817 - TFP Valve Position Sw. - Reverse With Drive Ratio <LI itxtNodeId="106">P1818 - TFP Valve Position Sw. - Drive Without Drive Ratio <LI itxtNodeId="105">P1819 - Internal Mode Switch - No Start\Wrong Range <LI itxtNodeId="104">P1820 - Internal Mode Switch Circuit A Low <LI itxtNodeId="103">P1822 - Internal Mode Switch Circuit B High <LI itxtNodeId="102">P1823 - Internal Mode Switch Circuit P Low <LI itxtNodeId="101">P1825 - Internal Mode Switch - Invalid Range <LI itxtNodeId="100">P1826 - Internal Mode Switch Circuit C - High <LI itxtNodeId="99">P1831 - Pressure Control (PC) Solenoid Power Circuit - Low Voltage <LI itxtNodeId="98">P1832 - Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage <LI itxtNodeId="97">P1833 - A/T Solenoids Power Circuit - Low Voltage <LI itxtNodeId="96">P1834 - Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage <LI itxtNodeId="95">P1835 - Kick-Down Switch Circuit <LI itxtNodeId="94">P1836 - Kick-Down Switch Failed Open <LI itxtNodeId="93">P1837 - Kick-Down Switch Failed Short <LI itxtNodeId="92">P1842 - 1-2 Shift Solenoid Circuit Low Voltage <LI itxtNodeId="91">P1843 - 1-2 Shift Solenoid Circuit High Voltage <LI itxtNodeId="90">P1844 - Torque Reduction Signal Circuit Desired By TCM <LI itxtNodeId="89">P1845 - 2-3 Shift Solenoid Circuit Low Voltage <LI itxtNodeId="88">P1847 - 2-3 Shift Solenoid Circuit High Voltage <LI itxtNodeId="87">P1850 - Brake Band Apply Solenoid Circuit <LI itxtNodeId="86">P1851 - Brake Band Apply Solenoid Performance <LI itxtNodeId="85">P1852 - Brake Band Apply SolenoidLow Voltage <LI itxtNodeId="84">P1853 - Brake Band Apply Solenoid High Voltage <LI itxtNodeId="83">P1860 - TCC PWM Solenoid Circuit Electrical <LI itxtNodeId="82">P1864 - Torque Converter Clutch Circuit <LI itxtNodeId="81">P1865 - 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage <LI itxtNodeId="80">P1866 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage <LI itxtNodeId="79">P1867 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage <LI itxtNodeId="78">P1868 - Transmission Fluid Life <LI itxtNodeId="77">P1870 - Transmission Component Slipping <LI itxtNodeId="76">P1871 - Undefined Gear Ratio <LI itxtNodeId="75">P1873 - TCC Stator Temp. Switch Circuit Low <LI itxtNodeId="74">P1874 - TCC Stator Temp. Switch Circuit High <LI itxtNodeId="73">P1875 - 4WD Low Switch Circuit Electrical <LI itxtNodeId="72">P1884 - TCC Enable/Shift Light Circuit <LI itxtNodeId="71">P1886 - Shift Timing Solenoid <LI itxtNodeId="70">P1887 - TCC Release Switch Circuit <LI itxtNodeId="69">P1890 - ECM Data Input Circuit <LI itxtNodeId="68">P1890 - Throttle Position Signal Input <LI itxtNodeId="67">P1891 - Throttle Position Sensor PWM Signal Low <LI itxtNodeId="66">P1892 - Throttle Position Sensor PWM Signal High <LI itxtNodeId="65">P1893 - Engine Torque Signal Low Voltage <LI itxtNodeId="64">P1894 - Engine Torque Signal High Voltage <LI itxtNodeId="63">P1895 - TCM to ECM Torque Reduction Circuit <LI itxtNodeId="62">P2008 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit <LI itxtNodeId="61">P2009 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage <LI itxtNodeId="60">P2010 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage <LI itxtNodeId="59">P2066 - Fuel Level Sensor 2 Performance <LI itxtNodeId="58">P2067 - Fuel Level Sensor 2 Circuit Low Voltage <LI itxtNodeId="57">P2068 - Fuel Level Sensor 2 Circuit High Voltage <LI itxtNodeId="56">P2096 - Post Catalyst Fuel Trim System Low Limit <LI itxtNodeId="55">P2097 - Post Catalyst Fuel Trim System High Limit <LI itxtNodeId="54">P2098 - Post Catalyst Fuel Trim System Low Limit <LI itxtNodeId="53">P2099 - Post Catalyst Fuel Trim System High Limit <LI itxtNodeId="52">P2100 - Throttle Actuator Control (TAC) Motor Control Circuit <LI itxtNodeId="51">P2101 - Control Module Throttle Actuator Position Performance <LI itxtNodeId="50">P2105 - Throttle Actuator Control (TAC) System - Forced Engine Shutdown <LI itxtNodeId="49">P2107 - Throttle Actuator Control (TAC) Module Internal Circuit <LI itxtNodeId="48">P2108 - Throttle Actuator Control (TAC) Module Performance <LI itxtNodeId="47">P2119 - Throttle Closed Position Performance <LI itxtNodeId="46">P2120 - Accelerator Pedal Position (APP) Sensor 1 Circuit <LI itxtNodeId="45">P2121 - Accelerator Pedal Position (APP) Sensor 1 Performance <LI itxtNodeId="44">P2122 - Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage <LI itxtNodeId="43">P2123 - Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage <LI itxtNodeId="42">P2125 - Accelerator Pedal Position (APP) Sensor 2 Circuit <LI itxtNodeId="41">P2127 - Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage <LI itxtNodeId="40">P2128 - Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage <LI itxtNodeId="39">P2135 - Throttle Position (TP) Sensor 1-2 Correlation <LI itxtNodeId="38">P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation <LI itxtNodeId="37">P2176 - Minimum Throttle Position Not Learned <LI itxtNodeId="36">P2500 - Generator L-Terminal Circuit Low Voltage <LI itxtNodeId="35">P2501 - Generator L-Terminal Circuit High Voltage <LI itxtNodeId="34">P2535 - Ignition 1 Switch Circuit High Voltage (PCM) <LI itxtNodeId="33">P2610 - ECU Malfunction <LI itxtNodeId="32">P2763 - Short to voltage in the TCC Solenoid <LI itxtNodeId="31">P2764 - Open or Short to ground in the TCC PWM solenoid valve circuit <LI itxtNodeId="30">P2A00 - HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 (PCM) <LI itxtNodeId="29">P2A01 - HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 2 (PCM)
P3000 - Hacking AWH Data
