ground wire on hood - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
ground wire on hood
Old 02-07-2012, 11:23 AM
97ranger xlt's Avatar
97ranger xlt 97ranger xlt is offline
97ranger xlt is starting off with a positive reputation.
Post ground wire on hood
there is a braided ground wire connecting the bottom of the hood on the passenger side to somewhere in the engine compartment. mine is snapped clean off. been that way for a while..
what is this ground for? is it necessary to replace?
thanks in advance for your replies
Old 02-07-2012, 11:29 AM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
You'll probably need it if you have a light under your hood. Not necessary though.
Old 02-07-2012, 11:47 AM
Quote:
thanks, but there is no under hood light installed on my truck.. (kind of wish there was..
could this ground have anything to do with am radio noise suppression?
Old 02-07-2012, 12:45 PM
Bruker's Avatar
Bruker Bruker is offline
Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.
Due to the motion of air across the top of the hood, static electricity can build up to the point where it will actually attract lightning. The ground strap is used to dissapate the static charge so your truch does not become a lightning magnet.
Just kidding.
Old 02-07-2012, 01:57 PM
Quote:
Just kidding.
i wouldn't want to play against you in balderdash.. lol
Old 02-07-2012, 02:13 PM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
The ground strap on the hood is for EMI/RFI suppression that the vehicles computers will appreciate having in place!!!!!
Old 02-07-2012, 02:24 PM
Quote:
ahhh so .. that's maybe why it's right near to the connection under the
hood for the ECM?
Old 02-07-2012, 07:02 PM
anyone else got a theory ? bueller?
Old 02-09-2012, 12:29 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
pawpaw is right. Besides the computers, the strap should guard against spark static in the radio or cb.
Old 02-09-2012, 12:36 PM
thanks guys, now i have to find a source for a replacement somewhere..
Old 02-09-2012, 03:12 PM
mfp4073's Avatar
mfp4073 mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.mfp4073 is gaining momentum as a positive member of FTE.
Cant speak to the truck, might be for a light that was never installed. On aircraft all of the control surfaces are grounded to the frame. static electricity will build up on the surface and then discharge through the bearings for that surface creating a mini arc welding effect.
Cant see this happening on truck though, so ground for non installed underhood light(edit: meaning I am guessing for hood light grounding purposes). I cannot believe that the hood is not grounded enough through the springs to discharge any static built up from the nominal air velocity across the hood.
Old 02-09-2012, 04:01 PM
Bruker's Avatar
Hmmm... I was actually kind of close.
Old 02-10-2012, 01:05 AM
mfp4073's Avatar
Quote:
You can buy them almost anywhere, auto part stores, radio shack, etc. If you really wanted to be cheap you could take a piece of wire and screw it into each side and it would do the same thing. But honestly I wouldnt worry about it.
Old 02-10-2012, 01:31 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
I might add, and this is just theoretical, but having all the body panels properly grounded can affect corrosion. While in theory everything should be covered with paint, if the hood and the rest of the car have slightly different electrical charges, you could get galvanization in the hinges where they meet. Perhaps having the strap can provide an easier cleaner path for charges to disperse. Just theory, and maybe it makes no difference whatsoever. I wouldn't worry about it.
Old 02-10-2012, 09:32 AM
i actually got a little interference today in the am radio... never noticed that before.
Ground Wire, easy to replace? (Rat) AggieFord 6.7L Power Stroke Diesel 1 01-21-2017 05:11 AM
Grounding Straps/Wires--How Many? kindorotten 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-21-2016 10:18 AM
Hood ground loop question Millam 1967 - 1972 F-100 & Larger F-Series Trucks 5 08-04-2015 11:05 PM
Wiring a Power Inverter to My Upfitter ?? chemoman 1999 to 2016 Super Duty 11 10-06-2011 11:04 AM
Ground Wire rmalottwtes30 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 04-08-2008 05:34 PM
Tags
60, 94, 99, braided, clean, diesel, explorer, f150, forum, ground, grounds, hinge, hood, located, raptor, strap, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
