Carburetor issue
Old 02-07-2012, 06:19 AM
3414's Avatar
3414
3414 is offline
Carburetor issue
OK, I started up one of the trucks the other day, and even after it was warmed up, with the choke wide open it was running very rich, to the point that I had clouds of black smoke coming out of the muffler and would flood out at low idle. Last time I ran it, it ran well.
Mixture screws were the same as before, and nothing else was changed.
Anything obvious to look for before I start disassembling the carburetor to look for somthing amiss?
Truck is 1960 F600, 292 V8, stock Holley 2 barrel carburetor with manual choke.
Old 02-07-2012, 08:48 AM
OverReved's Avatar
OverReved
OverReved is offline
Sounds like you had a float problem. Float may be stuck or have a hole in it that has let gas inside it. Needle and seat assemble may be stuck open for some reason.
Old 02-08-2012, 05:16 AM
Walston's Avatar
Walston
Walston is offline
If it has been sitting for a while, you may have some bad gas that is causing the float to stick. Might try running some Seafoam through it, it will likely free up what ever is sticking.
Carter78F150
05-18-2013 08:44 AM
Mustang65432
02-07-2011 12:13 AM
outsource77
07-09-2009 04:52 PM
72f100(460)
16
01-11-2006 03:47 PM
walterdanek
02-04-2002 09:09 PM
Quick Reply: Carburetor issue
