Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-07-2012, 06:19 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
Carburetor issue
OK, I started up one of the trucks the other day, and even after it was warmed up, with the choke wide open it was running very rich, to the point that I had clouds of black smoke coming out of the muffler and would flood out at low idle. Last time I ran it, it ran well.
Mixture screws were the same as before, and nothing else was changed.
Anything obvious to look for before I start disassembling the carburetor to look for somthing amiss?
Truck is 1960 F600, 292 V8, stock Holley 2 barrel carburetor with manual choke.
  #2 (permalink)
Old 02-07-2012, 08:48 AM
OverReved OverReved is offline
Garage is empty, add now
OverReved is starting off with a positive reputation.
Sounds like you had a float problem. Float may be stuck or have a hole in it that has let gas inside it. Needle and seat assemble may be stuck open for some reason.
  #3 (permalink)
Old 02-08-2012, 05:16 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
If it has been sitting for a while, you may have some bad gas that is causing the float to stick. Might try running some Seafoam through it, it will likely free up what ever is sticking.
__________________
Walston
http://bigjohnstractor.com/
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
