Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Towing and Hauling Guides
- How to Hitch a Fifth Wheel
Step by step instructions for do-it-yourself repairs
5th wheel prep package
Traditional fifth wheel hitches have ugly rails bolted to the bed floor, that is what most out there use. Reese developed the system Ford adopted. Your looking for their Elite series hitch, Reese offers 18&25k lbs rated hitches. The B&W hitch is nice as well, rated for 19k if memory serves me correctly.
On my few week old F350 FX4 I chose to go with the old style rails across the bed design. It may not be the cleanest look or newest production, but it is tried and proven to work time after time. I ordered the quick mount bolt on mounting kit which bolts straight to the frame with no holes to drill through the frame. You do still have to drill through the bed to mount the rails to the frame adapter.
Any how, the other reason I went with the old style rail system is that the slots in the rails allow the rails to do double duty as tie down points for the hooks on the end of tie down straps.....almost worth the price just for that function at times.
I was also looking at the Reese Elite 25K for my 6.5' box but the specs do not mention that it has the slider option which could be used in some turning situations. Any thoughts.
From ford it does not come with a slider. I have the 25k Reese from Ford and with only one pull so far I really like it. Haven't pulled the hitch out yet but I like the fact it leaves the bed clean and flat.
I bought my Reese Elite independently from Ford. Reese has an 18K with Slider for short bed trucks.
Reese Elite 5th Wheel Hitches and Gooseneck Ball Hitches.
One mechanic I talked to says the Reese 18K will be fine and it will fit the Ford factory 5th wheel prep kit. If I go with the Husky 26KGlider, there is an adaptor plate for the Ford prep as well.
#28
Yep, Reese make the factory prep so the Reese Elite fits. The Ford hitch is just a Reese Elite with a Ford sticker on it. Average price on the web is around 1200 for the 18k and 1600 for the 25k. With an 18k GVWR and almost 4k on the pin, your right at the limit of the 18k. If it was me, I'd spend the extra 400 for the 25k. You didn't mention if your 350 was a DRW truck. That much pin weight is a lot for a SRW.
#30
