Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Sign in using an external account
Register Forgot Password?
Brakes, Steering, Suspension, Tires, & Wheels Click Here
  #1 (permalink)
Old 02-06-2012, 07:59 PM
79 F350 79 F350 is offline
Garage is empty, add now
79 F350 is starting off with a positive reputation.
replacing the master cylinder in a 79 F 350
I'm brand new to this forum and I don't know if I'm posting in the right section, I figure if not I will be redirected. I was wondering if there was how to on doing the MC replacement? The brake pedal goes to the floor almost every time you press on the brake, any ideas ?
Jake
  #2 (permalink)
Old 02-09-2012, 12:46 PM
Lazy K Lazy K is offline
Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.
You need to check that the rear brake shoes are good along with the brake shoe springs and stuff. You then need to make sure the rear shoes are fully adjusted up.
You should also check for any fluid leaks in the system.
Replacing the master cyl is easy. Disconnect brake pipes, remove nuts holding master cyl to booster and remove master cyl. Bench bleed the new master cyl and fit. You will then need to bleed both front and rear brakes.
Tags
79, cylinder, f150, f350, ford, master, remove, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
