Serpentine tensioner assembly bolt - Ford Truck Enthusiasts Forums
Old 02-06-2012, 07:33 PM
fridgeddiesel fridgeddiesel is offline
fridgeddiesel is starting off with a positive reputation.
My serpentine belt tensioner assembly mounting bolt sheared off. Luckily it happened while the truck was stopped at idle and I shut it down before damaging the part, belt and other idlers.
Trying to find a new bolt to replace the old one but NO ONE has a listing for this bolt. Even Ford does not have a listing for this bolt. They sell the whole assembly with a new bolt for $170. Napa sells the assembly for $70 but it does not come with the bolt. It is a torx head case hardened bolt and a regular case hardened bolt causes the idler to rub the bolt head. I am searching junk yards but so far no luck.
Anyone have a source for these bolts or a modified bolt that would work in this application?
Thanks for any help.
Old 02-06-2012, 08:32 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Don't know if this is the correct one but found it on the sticky above ...
Serpentine Belt Pully Bolt, RH Thread T50
(Napa) 56040
Old 02-06-2012, 08:56 PM
Nope that is the Idler bolt. The bolt that mounts the tensioner assembly to the motor uses the same T50 wrench but is case hardened and 4"-5" long.
Old 02-07-2012, 12:17 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I just did the SD double pulley mod, I 'might' be able to find my old tensioner bolt. Let me know if you want me to look for it, I'll mail it to you.
Old 02-07-2012, 01:25 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
What if you get something like the aftermarket Gates tensioner with the longer arm? Then a standard grade 8 hex head bolt should stay clear of the pulley. 'Course, that's $60-ish, but at least that's less than $170.
Old 02-07-2012, 07:58 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I should have one of these laying around someplace as well. Let me know if you don't or cannot find your Glenn, and I will see if I can locate mine.
Old 02-07-2012, 08:42 AM
I will find out this morning if I have had any luck with the salvage yards. If not I would gladly take you up on the offer!
Old 02-07-2012, 09:10 AM
Let us know what you find. I am pretty sure I would be able to locate mine.
Old 02-07-2012, 01:44 PM
No luck on any fronts finding an OEM bolt. It is a M10 X 1.5 thread and I did find a bolt that may work. Couldn't find any "Grade 8" metric bolts but this one is stamped CHS 8.8 on the head. That is Class 8.8 and I am guessing the CHS means Case Hardened Steel. It is a hex head but I think I can keep it from rubbing the idler and will just have to pull the tensioner idler off to install it to the mounting bracket. I have to pull it all apart and take off the mounting bracket to drill out and extract the sheared bolt that is in there.
I will let you know how it goes. If anyone knows that this bolt is not strong enough for my application, let me know. Thanks
Old 02-07-2012, 02:13 PM
IIRC, 8.8 is equivalent to Grade 5, and 10.9 is equivalent to Grade 8. I always get mixed up with an International engine in a '90s vintage Ford truck, what's metric and what's inchy.
Old 02-07-2012, 05:15 PM
If you still want one of the stock bolts, I will look tonight and see if i can find mine. PM me your address if you still need it and I can drop it in the mail tomorrow.
Old 02-07-2012, 05:35 PM
Or, I found mine, let me know if you want it. I'll never need it, Nate or me, doesn't matter.
Old 02-07-2012, 06:04 PM
Thanks guys. I fixed it using a M10 x 1.5 x 100 bolt. I didn't need to modify the bolt length, head or anything. Taking the idler pulley off the tensioner made it easier to install but the bolt can be removed without taking the idler off. There is just enough room so the idler does not hit the bolt head. Drilled out and removed the sheared bolt and replaced both the other idlers on the alternator bracket as they were starting to feel a little rough. All in all it took 1.5 hrs to get everything working again.
It seams that the bolt they used originally is not a Grade 8 bolt. It was easy to drill out, relatively soft. I could not find a Class 10.9 bolt in the 100 length so I used what I could get locally. I will PM you guys if this bolt does not hold up and have you send me the OEM one. Thanks much for the offer!
Old 02-07-2012, 08:14 PM
Good deal. Glad you got it back together.
Old 02-10-2012, 11:03 AM
brooksbronco17's Avatar
brooksbronco17 brooksbronco17 is offline
brooksbronco17 is starting off with a positive reputation.
That is so wierd. My uncles sheared last night when he was idleing next to our shop. Found the head of the bolt right under his truck. Will try your regular bolt in there too If Ford doesn't have one. So glad I found this thread.
93 Ranger Splash Tensioner PtownBubba88 Ranger & B-Series 9 01-28-2014 08:30 AM
Idler Pulley to the Right of the Alternator on V10 jh818 Excursion - King of SUVs 7 09-28-2013 08:34 PM
Serpantine belt jumps off fuelhog450 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 04-13-2013 03:58 PM
Tensioner assembly woes bentring Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 04-28-2012 08:48 PM
Idler Pully Replacement dwild 1997 - 2003 F150 8 07-13-2011 07:46 PM
Tags
88, assembly, bolt, chs, escape, f250, f350, ford, forum, idler, serpentine, size, stamped, tension, tensioner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
