what shims for a 6 inch lift
The driveshaft angle at the pinion and the angle at the t-case output have to be the same angle (well, opposite... sort of.) Let's say you have 2* at the t-case. You must also have 2* at the driveshaft. Otherwise, you get a nasty vibration. Let me demonstrate through a crude picture:
This is the t-case "l"
This is your drive shaft "\"
And this is your axle pinion "L"
Your driveshaft should have the equal (but opposite) angle:
l
.L
Like that, but I'm trying to work with letters and symbols, so it's not the best example lol
l
.L
If I recall correctly, it has to be within 2* of eachother. They have to be at least 2* from being a straight shot also to keep the u-joints moving. You may end up needing to rework your t-case mounts if you lift it too high, but I don't know where the "too high" point is.
If you are running U joints, then the pinion needs to be parallel with the transfer case. (Although I have never have felt any vibrations from having the pinion angled up a little.)
If you have a double cardan joint at the transfer case, then you'll want to point the pinion directly at the transfer case.
The Best way to accomplish this is not with shims but with a grinder, or plasma cutter and a welder. Cut the welds off of the spring perch grind it smooth, and re-weld with the pinion pointed in the proper direction. That will take a little more time, but it comes out cleaner, and offers more adjustability.
Pirate4x4.Com - Extreme Four Wheel Drive
Billy welcome to FTE, you are in the 73-79 section, try that question here.
1978 - 1996 Big Bronco - Ford Truck Enthusiasts Forums
