ICM location - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
ICM location
Old 02-06-2012, 04:50 PM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
ICM location
I want pull the ICM off my dads 00 F250 and see if mines bad in my 96. Can anyone tell me where it can be found?
Old 02-06-2012, 04:59 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
IDM or PCM?
The IDM is located in the drivers side fender well. You will need to remove the wheel well liner, it is interchangeable.
The PCM is in the cab. You need to pull the connector in the engine bay though. It is not interchangeable.
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Behind the Drivers side fender under the fender liner.
Old 02-06-2012, 05:13 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
I'd like to kick the designer that put the damn thing there squarely in the nuts...
Old 02-06-2012, 06:15 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Might be the same person who decided to put the tire changing tools right on top of the boiling hot radiator....
Old 02-06-2012, 07:11 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
just me when if i took it out i would move it to under hood.
X2 kick the guy.
Old 02-06-2012, 07:32 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Here you go:
On your '00:
On your '96:
Old 10-21-2016, 12:59 PM
Stephen Spence Stephen Spence is offline
Stephen Spence is starting off with a positive reputation.
I had a blowout on front passenger tire and a wire was cut my truck want crank unless I crawl under it and jump the solenoid and my alternator want charge the batteries now and alternator tests good.
Old 10-21-2016, 01:01 PM
Quote:
Please help..
Old 10-21-2016, 01:33 PM
Rikster-7700's Avatar
Rikster-7700 Rikster-7700 is offline
Rikster-7700 has a good reputation on FTE.Rikster-7700 has a good reputation on FTE.Rikster-7700 has a good reputation on FTE.
You may want to start your own thread, this one is 4 years old? A bit more detail would also be nice. Year and model of truck, location of cut wire etc.
We are usually pretty quick on this forum, but you will still have to sometimes wait more than thirty minutes for a reply?
Have you checked all your fuses? Have you repaired the cut wire?
simple ICM question? esbrian 1987 - 1996 F150 & Larger F-Series Trucks 15 07-23-2016 08:04 AM
Intermittent Stall Ghosttowner 1987 - 1996 F150 & Larger F-Series Trucks 0 12-29-2014 06:51 PM
Ignition Control Module Trip443 1987 - 1996 F150 & Larger F-Series Trucks 8 10-18-2014 05:31 PM
Can't Find ICM!! Iantiler Ranger & B-Series 8 04-18-2011 12:31 PM
Icm socket size? ac700wildcat 1987 - 1996 F150 & Larger F-Series Trucks 7 02-19-2011 12:16 PM
Tags
01, 2000, 2003, 2004, 73, 73l, diesel, f350, f450, ford, icm, liter, location, removing, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
