1998 Ranger 4 wheel drive problems. - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-06-2012, 03:53 PM
ddt4812 ddt4812 is offline
ddt4812 is starting off with a positive reputation.
I have a 98 Ranger 4x4, 3.0L engine. It will not go into 4 wheel drive. After the vehicle starts, the 4HI and 4LO lights flash about 4 times. There is power at the switch, I've put a new motor on at the transfer case but I am still getting no power at the motor. I've checked all the fuses and they are good as well. Can any of you tell me if you have had this problem, or what you think it may be?
Old 02-08-2012, 12:41 PM
Bump..... Plz help
Old 02-09-2012, 07:20 PM
joew900 joew900 is offline
joew900 is starting off with a positive reputation.
On my old 88 Ranger I had a similar problem and it turned out to be corroded wire in the harness going to motor at the transfer case. I hope this helps as it was by pure chance I found it. Man I really miss that old girl. 219,000 miles when I got rid of it.
Old 02-09-2012, 07:51 PM
Joejoecat Joejoecat is offline
Joejoecat is starting off with a positive reputation.
Have you checked your relays ?
Old 02-09-2012, 10:10 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
Old 02-10-2012, 12:32 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
If it has the harness with the big square plug that goes through the floor, check that plug for corrosion.
2001 Ford Ranger stuck in 4 wheel drive therookster Ranger & B-Series 5 11-27-2016 08:50 PM
1999 Ranger transfer case motor hardware Bman57 Ranger & B-Series 4 08-14-2015 11:02 AM
That strange 60 to 65 MPH vibration towing my boat ARK Ranger 2009 - 2014 F150 20 11-12-2013 01:59 PM
4WD vacuum line '98 Ranger PUZZLED gpdickert Ranger & B-Series 1 07-04-2013 10:01 PM
2002 ford ranger 4x4 mattcomparato Ranger & B-Series 2 12-16-2009 07:36 PM
Tags
1998, 4hi, 4lo, 4wheel, drive, flashing, ford, light, mercury, mountaineer, problems, ranger, shooting, times, trouble, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
