4.2L Rear Main Seal Install Tool? - Ford Truck Enthusiasts Forums
Old 02-06-2012, 03:34 PM
stevenn1's Avatar
stevenn1 stevenn1 is offline
stevenn1 is starting off with a positive reputation.
Question 4.2L Rear Main Seal Install Tool?
OTC Tools #7786
The web site for this install tool says it works with the Ford 3.8L V6 & so on. It does not say anything about the Ford 4.2L V6. Both blocks are identical, except the 4.2L has a bigger stroke, so I hear. Both blocks do have a 1 piece seal. So, will this tool install the Rear Main Seal in the 4.2L motor also?
Ford Rear Main Seal Installer | OTC Tool Manufacturer for Cars and Trucks
Old 06-03-2012, 07:17 AM
stevenn1's Avatar
Tried it & it did work.
Knuckle Seal Tool SnowPlowDriver 1999 to 2016 Super Duty 1 12-10-2016 08:35 PM
Anyone know the dimensions for the Hub seal installer for 05+ Yahiko 6.0L Power Stroke Diesel 17 08-16-2016 08:43 PM
Looking for the rear main seal / wear ring installer tool carguy3j 1999 - 2003 7.3L Power Stroke Diesel 10 08-02-2016 05:34 PM
4.0L V6 OHV Cologne engine, Rear Seal Leak? FYI 96_4wdr Aerostar 9 10-27-2014 01:53 AM
4.2L rear main seal design changes? BobKoos 3.8 & 4.2L V6 0 09-17-2012 06:21 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
02, 1998, 2000, 2003, 370, 42, 42l, f150, ford, installer, main, piece, rear, repair, seal, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
