Starter Drive
Old 02-04-2012, 01:55 PM
fireball14513's Avatar
fireball14513
fireball14513 is offline
Starter Drive
Just picked up a new starter drive for my 60 F100 and notice that it will not work it seems to be longer than the one I took off.Is ther a replacement starter drive for the shorter shaft starter that I have? or am I just not seeing it correctly? Thanks Mark
Old 02-04-2012, 06:27 PM
fireball14513
OK I bought a BWD starter drive it calls for a SD553P well when looking around I found a SD595P that looks just like the one I took off...I feel thier is 2 different sizes one for the longer shaft starter and one for a short shaft starter...Keep you posted when iot come in Mark
Old 02-04-2012, 08:16 PM
spurredon's Avatar
spurredon
spurredon is offline
What engine are you working with?
Old 02-05-2012, 04:49 AM
critterf1's Avatar
critterf1
critterf1 is offline
Sometimes this helps.
Old 02-05-2012, 07:56 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
ICM-11350-C .. Bendix 'inertia' Starter Drive.
1954/60 applications: F100/800 223 (M/T) / F100/250 292 (M/T & A/T) / F350/800 292 (M/T).
1961/64 is not the same, because Ford changed the starters in 1961.
B6C-11350-A .. Bendix 'inertia' Starter Drive.
Applications: 1954/64 F100/250 223 (A/T).
These Bendix drives are about 5" long when wound, are retained on the shaft of the armature by a roll pin.
The roll pin is hidden by the large coil spring. So, the spring has to be unwound to R&R the drive.
needhelp49
06-13-2013 10:14 PM
64STYLE
07-12-2007 09:37 PM
Young_unn
23
11-18-2005 07:04 AM
Chevythunder7578
02-06-2004 10:59 PM
jhuffer
08-09-2003 02:01 PM
Quick Reply: Starter Drive
