1968 F100 starter Issues - Ford Truck Enthusiasts Forums
Old 02-06-2012, 11:38 AM
HankR1966 HankR1966 is offline
HankR1966 is starting off with a positive reputation.
Hello all,
I have a 1968 f100 that is driving me crazy. Issue: Went to crank it and just got the old "slow speed turn from the motor", as if not enough juice to kick it over. Tried jumping it off but no luck, however, after I turn key off, starter kept stayed engaged and kept trying to start. How is this possible if key in off position? Solenoid? Switch? Wiring? I replaced solenoid, still no luck. Tried new switch, still no luck. traced wiring as much as I could but didn't see anything wrong. Would a starter cause this? If so, please explain. I do not understand how a starter gets power and stays engaged if key is off.
Old 02-06-2012, 06:40 PM
60F100 60F100 is offline
60F100 is starting off with a positive reputation.
I have had this happen. First have the starter checked. Sounds like it is drawing to much current. Something is causing the solenoid to stick in the closed position. I know of only three things that will cause this.
1. The starter is drawing enough current to cause the contacts in the solenoid to get hot and stick.
2. 12 volts is staying applied to the start contact on the solenoid.
3. It is a crappy solenoid made in China or some such place.
Ford starters require a good 12volt supply to the starter. This means you should have a fully charged battery, a good solenoid and good leads between the battery and the solenoid and between the solenoid and the starter. The starter mounting bolts should be clean and tight as this is the ground. Also make sure the ground wire is good between the engine block and the battery neg terminal. Make sure all connections are clean and tight. Hope this gets you started in the right direction
Old 02-06-2012, 09:13 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
I'd go with a faulty soleniod. If it was "bad" and the contacts weren't making good connection it would make the starter turn slow(like a dead battery). There again, if they did weld themselves together from being burnt too bad, it would allow the starter to continue cranking with the key "off".
Make sure you have good battery cables. I've seen ones that look okay, but the ends are almost broke inside the insulation. Only a few strands of copper holding them together.
Old 02-07-2012, 09:04 AM
Thanks guys, we'll try a starter and go from there. Thanks again!
Old 02-07-2012, 09:17 AM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
Mine would stick because of low battery voltage. New cables and battery cured it.
Help! Starter issues Roswell Georgia Chapter 8 02-10-2016 09:08 AM
Truck Runs with Keys Removed Jmschneider 1973 - 1979 F-100 & Larger F-Series Trucks 18 10-13-2015 12:51 AM
Ignition problem Dwilson37 Computer Chips & Tuners 2 06-12-2015 01:22 PM
starter stays engaged with key off! ideas? jxnslotcar 1961 - 1966 F-100 & Larger F-Series Trucks 21 06-26-2013 12:45 AM
Starter staying engaged bayslayer 1987 - 1996 F150 & Larger F-Series Trucks 1 12-05-2011 05:26 PM
Tags
1966, 1967, 1968, 1972, 352, 68, block, broken, engine, f100, ford, located, problems, slow, solenoid, starter, starting, terminal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
