1953 f100 3spd Floor Shift Conversion - Ford Truck Enthusiasts Forums
Old 02-06-2012, 08:04 AM
larry53deluxe larry53deluxe is offline
larry53deluxe is starting off with a positive reputation.
I have a 1953 F100 with a 3 speed on the column. I would like to convert it to a floor shifter. Is there another Ford model that I can take the shifter and linkage that will work on my 3 speed transmission? I have the 215 6 cylinder.
Old 02-06-2012, 09:08 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
You are going to need an after market shifter that will bolt to the bsckside or the case
Old 02-06-2012, 10:39 AM
Dale Fairfax Dale Fairfax is offline
Dale Fairfax is starting off with a positive reputation.
I'm sure that somebody on this site (who has put a late model driveline in their truck) has a floor shift 3 speed for your truck. That would be better than a cobbled Shifter that wasn't designed for the app.
Quote:
Maybe some help harleyjohn45 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 10-16-2015 10:49 PM
3-speed Shifter Linkage ratrod1923 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 06-30-2014 02:22 PM
1953 - 1956 T5 swap pic request carbs & chrome 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-11-2011 01:00 PM
1953 Transmission Question 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 09-17-2011 04:14 PM
3 speed floor shifter caroc1964 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-04-2009 04:23 PM
Tags
1953, 1960, 351, 53, 54, conversion, coverter, engine, f100, floor, ford, sedan, shift, shifter, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
