Will this PTO bolt to my Transmission? - Ford Truck Enthusiasts Forums
Old 02-06-2012, 02:55 AM
packratF350's Avatar
packratF350 packratF350 is offline
packratF350 is starting off with a positive reputation.
First off, I'd like to thank the guys that posted pics of their engine compartments for me a while ago...they were invaluable in getting my truck up and running again!
One of the trucks I am parting out has a PTO driven winch on it. I'm considering installing it on my flatbed instead of an electric unit (this will be used to operate a tow sling, GIN poles and loading the deck with whatever).
Donor truck:
early to mid 70's Ford 4 speed (reverse is right and back = NP435??)
PTO is mounted to the passenger side of the transmission.
My truck:
'94 F-350 with a ZF5 5 speed. I'm not even sure at this moment if it has a PTO opening, been too busy with getting it running to date and this idea just popped into my head tonight.
any thoughts or advise?
Old 02-06-2012, 07:31 AM
frederic's Avatar
frederic frederic is online now
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
I don't think the older stuff mounts on it though, but I'm not sure. I can answer the other question though - your ZF has two PTO take-off ports. You have a PTO cover on each side - for two accessories.
Old 02-06-2012, 10:09 AM
I've been doing some other research into this, and I found a rebuild shop that says basically, due to the design of this transmission, its not a very good idea to run a PTO for any length of time with it (and specifically mentions tow trucks and winches) due to internal heat build-up. Any thoughts here?
Old 02-06-2012, 10:20 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
That is a load of crap. If it was so bad for the trans, then why did Ford have the provisions put into it for a PTO
Old 02-06-2012, 10:25 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
I agree with Brad. There wouldn't be one if it couldn't take it. The ZF trannys are tough as it is, and it shouldn't have any adverse effects on anything else. I'd say go for it.
Old 02-06-2012, 12:08 PM
quote from the rebuild place...http://www.standardtransmission.com/ford_zf.html
Quote:
In late 1987, Ford introduced the 5speed ZF transmission in the F250, F350, & F450 trucks. They were available for gas as well as diesel models. The easiest way to identify the unit is to see that it has power take off (pto) opening plates on the lower sides of the unit. ZF transmissions are reliable units that should provide good service when taken care of properly. Keep in mind that the ZF has 6 constant mesh mainshaft gears, so there is a considerable amount of potential for heat buildup. It is never a good idea to leave the truck idling with a pto engaged, such as in tow truck applications. The unit was redesigned in '96 and had small, but significant changes. The synchro teeth were enlarged to provide longer life and more positive shifts, and the bearing retainer was designed to be replaced without having to disassemble the case. The case was beefed up also with this design.
Old 02-06-2012, 01:33 PM
Quote:
Originally Posted by packratF350 View Post
quote from the rebuild place...Ford ZF Transmissions
That means dont leave the PTO in for hours on end. Neither a tow truck or winch will be used for more than 30min at a clip
Old 02-06-2012, 01:57 PM
Ok then that question is taken care of.
Back to the original question, anyone think the PTO off hte older transmission will bolt onto the ZF and work properly? Or am I wasting my time and should just go with my original plan and use an electric winch?
Old 02-06-2012, 02:06 PM
The ZF uses a 6 bolt PTO. I cant remember what the NP435 or T18 uses
Old 02-06-2012, 02:11 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I think I heard somewhere in my travels that there are 2 different ones out there, one coarse toothed gear and one fine. You might just need to try it if nobody can tell you for sure. Is there a tag on the unit you want to install with make/ model? I'd try googling that and see what you can come up with.
Old 02-06-2012, 04:47 PM
I dont know yet...I need to dig it out of the pasture/bushes as I get caught up on other projects so we can tear into it.. I will be pulling the engine/trans, PTO powered deck winch and the gin poles off it as well.
I'll keep you all updated as to weather it will work or not when I get that far!
Old 02-06-2012, 04:57 PM
hootvan hootvan is offline
hootvan is starting off with a positive reputation.
You need to get the model off of the PTO and the actual transmission model number and I could tell you if it would fit. It may be as simple as changing the input gear on the PTO to make it fit the new transmission. There should be no problem with overheating as you won't run continously.
Old 02-07-2012, 09:18 AM
I'll hit you up as soon as I get into working on it! Thanks!
PTO Pump Swap misterfisher 1987 - 1996 F150 & Larger F-Series Trucks 1 12-09-2013 07:13 PM
1994 F Super Duty Dump Truck Build shawbran 1987 - 1996 F150 & Larger F-Series Trucks 12 07-07-2011 04:09 PM
2011 PTO in action? 2005bigwhite 1999 to 2016 Super Duty 0 02-08-2011 08:06 AM
Pto scatgo 1994.5 - 1997 7.3L Power Stroke Diesel 5 08-23-2009 11:53 AM
What about a shaft drive pto winch? mando jake Offroad & 4x4 12 08-11-2009 01:15 AM
Tags
477, 94, add, bolt, deisel, dump, engine, explorer, f350, ford, power, pto, ptotruck, pull, speed, sportrac, transmission, truck, zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
