Different way to carry spare tire?
I'm looking for a different way to carry my spare tire.
I'd like to use one of those hang off rear door tire carriers, But
A friend said they cause bad wear on the door hinges and the one that is frame mounted is tooo much $ this
Suggestions?
PS. underneath is becoming a storage area, inside not enough space and no roof rack.
Suggestions?
If you want to mount it outside the vehicle - you'll need to pony up the $$ for the heavy duty tire carrier. The back is about your only option as mounting it up front could cause access and cooling problems.
I suppose you could use one of those hitch-haul racks and stash it there, but that would only work if you're not planning on towing anything and would look rather shabby.
I concur, but what is the norm is dented/caved doors from owners backing into items, not realizing how much room it takes beyond the bumper.
Seen several stories about new cars being sold w/o spare tire. Some say tires are so reliable carrying canned Fix-A-Flat, or a 12V plug in compressor & tire plug kit, may give greater security than traditional spare tire, lug wrench & jack.
I know "too much $" but do they make Run Flat tires in your size? Ever consider deleting spare tire completely?
Do they make compact Temporary, Space Saver spares in your size?
For years I carried a gas can that fit/maximized space inside spare wheel in '85 Club Wagon. Spare was horizontal, under bed platform, on floor.
Design didn't work w/92's spare tire cable hoist. But in a pinch utilized that space too. Lowered the spare & filled wheel w/tire chains, tow rope, jumper cables, tie down ratchets & straps, then cranked it back up. Have carried stones for a FL sweat lodge. Yes, the items can get wet & dirty, unless you bag 'em, but they're out of the way, reasonably secure, lower COG & are easily at hand.
My F150 came from factory w/spare hoisted outside up. PITA to check/add air. Flipped it over, outside down, so valve stem is easily accessed & dish of wheel can hold/conceal rugged items. Built 2/98 its spare has never been needed. I haven't had a flat on the road since at least '94.
Beware, FORD cable hoists suffer neglect & are prone to rust. Had to cut off failing exposed cable, swedge new end on & lube hoist on '92 before I'd trust it.
And I've used it on my tractor. I bought the stuff for tubes but after using it, and it worked, I realized I didn't have a tube in it.
the other problem with the spare-tire-in-a-can products is that they have a tendency to corrode the wheel and destroy it. 2000ford2000, i would suggest having that tractor tire you mentioned worked on before it corrodes the rim out.
i once had a chrome wheel rust through from the inside out because a previous owner used those canned products. that was the only flat i've had that didn't destroy the tire, more often i have large chunks of tread fly off or cords break suddenly, leaving a gaping wound in the tread.
