1996 F150 oil pressure gauge behavior - Ford Truck Enthusiasts Forums
Old 02-05-2012, 03:11 PM
virginiacreeper virginiacreeper is offline
virginiacreeper is starting off with a positive reputation.
The oil pressure gauge in my 1996 F150 will flip back and forth rapidly when I come to a stop after driving about twenty miles. If I put the tranny in either neutral or park it goes back to where it is supposed to be and it does the same as soon as the truck starts moving again. If the engine is turned off for a few minures it will indicate normally again while ilding but will start flipping again at a stop after a few miles. The oil sending unit has been replaced twice and there are no weird noises coming from the engine. The oil level is normal and there is no froth or contaminants in the oil. I did notice that the holes around the outer edge of the old filter were quite a bit bigger than on the new one I put on today when the oil was changed. Is the oil pump getting ready to go south on me or is there something else I should look at?? Any ideas out there?
Old 02-05-2012, 03:15 PM
xxshine xxshine is offline
xxshine is starting off with a positive reputation.
There is the thought of a dirty pickup screen at the pump.
Old 02-06-2012, 08:31 AM
hotrod351's Avatar
hotrod351 hotrod351 is offline
hotrod351 is starting off with a positive reputation.
if the oil sending unit for a 96 is like a 90 then i wouldnt worry about it. there really not a sending unit, more of a idiot light sender. sometimes my gauge will read high and other times it will read low, been doing that for 70,000 miles. ive read that there is a sending unit, think its off a mustang, that will actually make the gauge read right. but like i said the sending unit is a small idiot light sender.
2002 F-150 Won't turn over lblackwood82 1997 - 2003 F150 6 09-10-2016 07:03 AM
Oil Pressure Gauge Drops To Zero ~ChipsAhoy~ 1997 - 2003 F150 26 05-12-2016 11:30 AM
0 oil pressure at idle and metal shavings on drain plug Dcnnnghm 1999 - 2003 7.3L Power Stroke Diesel 10 04-04-2016 05:35 PM
HELP…Strange oil pressure behavior Mr-Pipeline Modular V10 (6.8l) 30 05-17-2010 10:13 PM
F150 Fluttering oil pressure guage binkley 1987 - 1996 F150 & Larger F-Series Trucks 42 08-06-2002 02:43 PM
Tags
150, 1996, 96, f150, ford, gauge, guage, high, idiot, normal, oil, pressure, presure, reading, sensing, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
