Latest spark plug TSB
I can't read so I just watch this
How to- Change Spark Plugs on Ford 3 valve modular engines Autolite - YouTube
I really don't believe that of so many thousand FTE members that one hasn't jumped all over me with TSB 08-7-6 and 25 lb ft
Thanks to at least one (doofuss) that supplied a good You Tube video to help some with disassembly. etc
I'm going to order the $60 Lisle (LIS65600) Broken Spark Plug Remover for Ford just in case - and if I don't need it, then I'll either sell it or stick it in my tool box for possible future use
Now that I have (hopefully) the latest TSB, a "Lisle 65600 - Broken Plug Remover for Ford 3 Valve", a brand new deep 9/16" 6 point socket, along with the new plugs, boots and springs, anti seize and carb cleaner am just about ready for the project. It just needs to warm up a little bit more.
Having that Lisle tool on hand just seems to be a good idea instead of making a panic run to try to find one locally - eventually, someone here will be getting a chance to purchase it at a reasonable price as the next truck will probably be a diesel
These marks can be found on the right side end, viewed looking at the exhaust ports. Heads are the same left and right so these would be at the front on right side, rear on the left. I believe even the PI heads had but 3-4 threads in the plug holes---could be mistaken but obviously the best way is to visually check.
Irelands Child says:
I just went through that 'fiasco' doing the rear brakes - pads, then became calipers and rotors, then e-brake backing plates, then seals, then a hub bearing which meant a 2 hour brake job became a 2 week project (Rock Auto for most parts - NAPA is way too expensive) Thankfully that truck is the second vehicle, but needed to pull a 5th wheel camper
