Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 02-05-2012, 11:17 AM
Blown349 Blown349 is offline
Garage is empty, add now
Blown349 is starting off with a positive reputation.
The Mtn. Bolt = 93, 4X4, F150 Flare Side, 351W, and 2.1l Kenne Bell Supercharger
I hope it qualifies for this sub-forum.
Click the image to open in full size.
Desktop Dyno 2000 power curves for this build. DD 2000 is 13% optimistic, so about 430ftlbs of torque and 350 horses at the Flywheel.
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
The build so far: Roller 351W, 2.1l Kenne Bell Flowzilla Twin Screw Blower at 7lbs of boost, Lightning lower intake, World Products Windsor Sr. heads (200cc int. run 2.02int 1.60exh.), Crane roller cam 364215 (Lobe center 112, duration 260int 270exh .445int & .470ex) Comps Rollin' rockers, Mass air conversion, 90mm Lightning MAF, 42lb inj., 75mm Accufab throttle body, 10" Cone filter, BBK in-line 50gph fuel pump, JBA stainless shorties, Bassani Stainless "Y" pipe 3", Flowmaster 70 series with 18" Magnaflow glass pack, TwEECer tuned FLY1/AHACA Truck EECIV for engine and Transmission/E4OD Management.
I have spun the stock torque converter clutch but have a Punisher E4OD Transmission Precision - Stallion triple clutch torque converter with about a 2,200rpm stall on the way! I am also embarrassed to say that it has a stock 31 spline 8.8 rear end.
I need a stronger carrier with traction device and probably some alloy shafts. What do you all suggest?
  #2 (permalink)
Old 02-06-2012, 10:18 AM
No need to answer my question unless you want to comment. I have chosen a Yukon Dura Grip Posi, Yukon alloy shafts, and have a master install kit coming...........
  #3 (permalink)
Old 02-07-2012, 11:23 AM
Killer Ride Killer Ride is offline
Killer Ride is starting off with a positive reputation.
I don't think that any body is on this forum(crickets chirping)
But I think its a great build. Throttle body is a little small, a nice big single blade or a double 65MM would really flow. Do you have a tuner? If you don't I would say your estimate on power might be a little low. And a good tune from a reputable tuner might make it really Rock.
And you have Headers. Long tubes would be the best, but shorty's work good too and the 3'' pipe is great ( that's what I'm runn'in) as SC motors respond very well to freed up back pressure on that side. Lotta air/fuel in, lotta exhaust out! I have a Lowered '01 F-150 with a transplanted L-motor/trans in it and a few small bolt ons and a home port. 410HP/510ftTQ
So I cant answer your 4X shaft questions. Oh and I'm new to this forum
Looks good,
John
  #4 (permalink)
Old 02-07-2012, 01:27 PM
Looks good,
John
It's Tweecer tuned and a bigger t-body might help some, but it makes the power down low and is done by 5,000rpm.
Yer rig sounds fun as well!
Thanks!
  #5 (permalink)
Old 02-07-2012, 06:14 PM
I'm not familiar with Tweecer. Is it a programmer?
Yea mine is fun,and like yours Torque down low is insane. Also like yours mine is pretty much done by like 5,2-5,400rpms.
I haul around 800-900lbs around in tools 24/7 so the low down tq is great to get things rolling and also for traction! He HE He
Sports bikes, Rice burners just dont stand a chance
Id like to know a little more about Tweecer. If you dont mind. Always trying to learn something new
  #6 (permalink)
Old 02-07-2012, 06:42 PM
Yes, The TwEECer -- EEC-IV user programmable module
  #7 (permalink)
Old 02-20-2012, 04:25 PM
I got the tranny in and it hammers the gears! WJW! The new tranny/torque converter is awesome! I went back to the stock calibration for TV pressure before I tried it, glad I did, it shifts plenty snappy without additional pressure. I can catch second gear, Errrk! Click the image to open in full size.
The brake stall before was about 1,800rpm, then the rear brakes would loose and tire spin ensued. Now it is about 2,300rpm. I hear it wind-up a bit more before I go.
I can only launch slowly with or without tire spin, but timed a 7.5 in the 0-60. I had 7.8 before the tranny/TC change and tune. Now If I can get the rear end done it should launch better, maybe gain another .2 seconds. This is at 5,400' south of Littleton CO. That leaves 16-20% of the power out of the equation because of the thinner air and less oxygen.
This thing gained a pound of boost! I was getting about 7lbs and now with this torque converter it's 8lbs!
  #8 (permalink)
Old 02-20-2012, 05:49 PM
Blurry94's Avatar
Blurry94 Blurry94 is online now
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Very nice ride.
The stock 31 spline axles can support plenty of power. I still run them in mine with an Eaton LSD.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
Tags
1987, 351, 351w, bell, blot, dyno, f150, f350, flare, ford, headers, jba, kenne, sale, side, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
