Another 1996 5.8 cam question.
I'm building a 5.8 to put in my truck and Ive got almost all of the parts.
Is MAF and I'm looking to build a tourqe MONSTER, not a high reving dragstrip engine.
The parts that I already have are:
gt40 3bar heads
Typhoon intake
Ford Racing shorty headers which I know I'm going to get crap about but they flow better than stock and I can't get through inspection anywhere here with longtubes.
And I'm building a custom dual exhaust. (Dual from manifold to exit)
It's going to have a manual trans one way or the other. I dont expect the M5OD to last long but until I'm forced to swap in a ZF that's what I'll be running.
I'm having trouble choosing a tourqy cam for a MAF 5.8L
Thanks for all your advice in advance
gt40 3bar heads
Typhoon intake
There are others that know a lot more about the EFI stuff than I do, but something along these lines will net you lots of torque down low in the RPM band.
Lunati 510A1LUN - Lunati Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com
on
My suggestion is the Comp 35-510-8 if you're really serious that you only want a 0-4000rpm powerband, if you would like even a little bit more go with the Comp 35-320-8.
Browsing Summit Racing for other similar possibilities...
http://www.summitracing.com/parts/ISK-371257-265/
http://www.summitracing.com/parts/CRN-444211/
Professor Overdrive is a complete moron when it comes to Fords. The stock F4TE cam boosted with full roller 1.7 rockers is a good-un.
Isky Racing Cams 371257-265 - Isky Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com
Crane Cams 444211 - Crane Hydraulic Roller Camshafts - Overview - SummitRacing.com
If I do go with stronger springs, aren't I going to have to run pushrod guides as well? Or will the GT40 springs suffice.
You only need pushrod guides if changing rocker styles. The pedestal rockers are aligned with the valves via the channels under the (paired)rockers. The springs are kept in place via the valve guide bosses inside the springs. Sometimes, the only benefit of stronger springs is for controling the valvetrain in the upper rpms. Those cams may work fine with the stock springs in your application You mentioned not wanting a high reving dragstrip motor, so I assume you're not going to rev it past, what? 5 grand ? You could always upgrade the springs later (with the heads on the motor) and do the cam now. This operation only takes a couple hours at best and can be done with the engine in the truck and the heads in place.
Haha Yes, I usually never rev higher than 5000 RPM. I figured that they required different springs because the stock springs couldn't handle the extra lift.
I'm going to tear the head down to clean the valves and replace the seals anyway so I might as well replace them now it they actually need it.
