Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-04-2012, 09:34 PM
tsbrewers tsbrewers is offline
Garage is empty, add now
tsbrewers is starting off with a positive reputation.
Sway bar question
hey all, I have a '93 E150 and I would like to add a sway bar to the front. Money is a little tight, so I picked up a used sway bar from a junk yard. anyway, the bushings in the control arms were out of round, so i didn't take them, just the bar and the brackets.
So I am planning on buying a new bushing set, and was wondering if I need anything special for the ones in the control arm? I do not have a sway bar now, will I need anything beyond just the bushing? is there a metal ring that I need too?
This is what I am thinking about ordering, any help is appreciated. It is a 1" bar that was taken from an '95 or so E250. The type that "stabs" in to the control arms.
Energy Suspension 4-5142G - Energy Suspension Sway Bar Bushings - Overview - SummitRacing.com
Brew
  #2 (permalink)
Old 02-05-2012, 01:19 AM
wizzy214's Avatar
wizzy214 wizzy214 is offline
1999 Ford E-Series Van
wizzy214 is starting off with a positive reputation.
looks like the same ones i have for my sway bar.
what does your sway bar mount to?
pics?
is it like this?
http://www.ford-trucks.com/forums/11...gger-ones.html
  #3 (permalink)
Old 02-05-2012, 07:15 AM
JWA's Avatar
JWA JWA is offline
2000 Ford E-Series Van
JWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant futureJWA has a brilliant future
Brew those bushings would do the trick just fine. I installed the ProThane versions on a '97 E250 and they made a world of difference. Of course since all sway bar bushings were shot anyway so no where to go but up.
If I can give you any install tips I'm glad to share what I recall. It wasn't difficult technically although getting the old parts out and fitting the new I-Beam bushings was a bit of a challenge. Lemme know!
Wiz did you ever get your Addco bar fitted, installed and tested? I'd be interested knowing what your impressions are after a few miles.
  #4 (permalink)
Old 02-05-2012, 09:28 AM
pics?
is it like this?
Nope, it is the factory bar that stabs in to the control arm. Here is a picture from andrewzx92000 and his steering stabilizer thread.
100_9705 | Flickr - Photo Sharing!
This is the way mine will work. I just wasn't sure if I needed a metal sleeve first since mine did not have a bar from the factory, or if the bushings are all I needed. Thanks,
Brew
  #5 (permalink)
Old 02-05-2012, 11:27 PM
wizzy214's Avatar
is that a steering stablilzer? the shock?
  #6 (permalink)
Old 02-06-2012, 08:08 AM
Yup, the shock in that picture is a steering stabilizer. It helps with the way our vans like to wander all over the roads. Here is a link to that original thread about adding one to our trucks.
http://www.ford-trucks.com/forums/10...ering-fix.html
  #7 (permalink)
Old 02-06-2012, 03:29 PM
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Many mistake the need for a steering stabilizer due to worn steering and suspension components, they need checked first, the stabilizer just limits the roads ability to yank the wheel from your hands.
I want a sway bar for my 73, I plan to update the steering to that of the 75+, the arrangement is ahead of the axle, not behind.
__________________
My wheelchair has yet to stop me from wrenching on my vans.
  #8 (permalink)
Old 02-23-2012, 12:34 AM
LN323 LN323 is offline
LN323 is starting off with a positive reputation.
I too just bought a sway bar from the junkyard. It was a rear sway bar plus I got some leaf springs. Long story short, I went to O'Reilly's and NAPA to look for replacement bushing kits. NAPA in my area only carried MOOG and I happen t like Energy Suspension components. O'Reilly's in my area could get either, but the Energy Suspension stuff was cheaper. Woot!
So, I bought the kit for the front as well as the back (my E-150 already had a front sway bar). Each kit was $28.99 plus tax. I thought it was a very good price and the kit included the sway bar bushings plus the end link bushings with hardware. Have to wait one week to get them, but I'm sure I won't be disappointed. I'll try o post pictures when I get them.
  #9 (permalink)
Old 02-23-2012, 07:13 AM
Thanks, I tried to do the same thing, but neither autozone, nor O'reillys could tell me if the kit included all 4 bushings for the front, or just two. Plus when I emailed Energy with the same question, I didn't even get a response, so Energy was out for me.
I ended up getting just the Moog poly control arm bushings from amazon for $10. The ones to the frame really looked ok.
Brew
Tags
06, 2001, bar, bushing, e250, f150, ford, links, oriellys, stabilizer, sway, wandering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
